That PCB mic looks worthy of a test buy, Thanks for the info. Can you show the parts and circuit on the output to get the gain of 20?
In your circuit you have directly connected the mic to the line in pins. I wanted to know if there is a requirement of pre-amplification stage for that or connecting the mic to line in directly gives a good quality output?
HiThe Texas Instruments AIC3206 has a programmable gain pre-amp. So, yes, you can connect a microphone directly to this chip without any additional amplification. For electret microphones, you do need to be sure that you provide a microphone bias (which can be either from the AIC or from your own bias voltage supply), but no additional amplification is needed.
Chip
