Teensy with PCM5102a Module via I2S
JayShoe
I purchased an inexpensive PCM5102a module from ebay.
I put a teensy on a breadboard with it, and connected it using the information on this page
https://www.pjrc.com/teensy/td_libs_AudioOutputI2S.html
I used this code to hopefully passthrough the USB->I2S
#include <SerialFlash.h>
AudioInputUSB            usb1;           //xy=200,69  (must set Tools > USB Type to Audio)
AudioOutputI2S           i2s1;           //xy=365,94
AudioConnection          patchCord1(usb1, 0, i2s1, 0);
AudioConnection          patchCord2(usb1, 1, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=302,184
  AudioMemory(12);
Here is the breadboard
I'm relatively new to this, but I had great success wiring up an Audio Shield to the teensy and proving my application. The above situation is not working. Does anyone have any advice on what I should do to get this to work? Could it be the "long i2s lines" issue? I don't know how much shorter I can get.
Thanks for your help.
Jay
Update: I figured it out.
PCM5102A / Teensy 3.6
VCC = Vin
3.3v = NC
GND = GND
FLT = GND
SCL = GND (also works connected to 11 /MCL)
BCK = BCK (9)
DIN = TX (22)
LCK = LCRLK (23)
FMT = GND
XMT = 3.3V (HIGH)
There is a noticeable difference in sound quality over my PC port or audio shield.
And now I'm going to work on getting the ADC working. I'll post my results when I know.
I got the ADC working now too on my project. It's a PCM1808 module, another cheap board from ebay.
Here are the connections for the PCM1808 module.
FMT = GND
MD1 = GND
MD0 = GND
GND = GND
3.3V = 3.3V
5V = VIN
BCK = BCK (9)
OUT = RX (13)
LRC = LRCLK (23)
SCK = MCL (11)
GND = GND
3.3V = 3.3V
Here is a picture of the breadboard now. Yes, it's a mess but I managed to make it work.
It sounds really nice! I'm actually quite impressed by the quality of the sound overall. My application is a simple passthrough USB Audio and I2S input through to the outputs.
*** On a side note, I seemed to have lost the ability to edit my posts. I hope it wasn't because I deleted a photo in the earlier post. Maybe it's a time-out setting once you've edited? Moderators, can you explain why I've lost that ability and possibly reinstate? I look forward to contributing. Thanks!
everyone loses the ability to re-edit a post after 2 hours. This was done to prevent some ravage individuals from mass deleting their posts when they were upset
Hello Teensy,
Would it make sense to create a Teensy Audio Bridge? Would anyone else be interested in that?
From my experience with my project, and digital audio projects in general it seems that there should be some type of standardized connector for I2C/I2S Audio Connections. From my initial analysis, it appears that the Teensy 3.6 could have 4+ I2C/I2S lines exposed (more research?). If used in tandem with TDM multiplexed lines this could result in an insane amount of inputs/outputs connected to the Teensy.
I've seen other projects with similar connectors, but I haven't seen an I2S bridge before like what I'm talking about. What's different from the bridge I'm thinking about is that it would have no functionality other than simplifying connections to other sound modules. FreeDSP has a standardized connector but it's almost always fixed to the existing codec/DSP card. I've attached a PDF of their connector diagram (FREEDSP-HEADER-CONNECTOR.pdf). More details can be found at this link. https://github.com/freeDSP/WIKI-AND-GENERAL-TOPICS/wiki/freeDSP-Guidelines
The Teensy Audio Bridge connectors would enable system designers to plug in modules with ease. Just solder the end of a ribbon cable onto the module to the right pins, and then connect it to the expansion connector of the bridge. For modules designed for this project the correct pins would be in the right spot making connections even easier. The project may also encourage designers to release more reference modules (codec, adc, and dac, bluetooth, ethernet, hdmi, etc) which would further expand the possibilities of DIY audio engineers to create the system they want/need.
Possible Features??
- Single 8+ pin connector to supply power, data, clocks, control, and gpio to any audio module.
- Optional external 12v dc power supply? (for op amps? more power? cleaner power than USB?)
- Regulate and Filter the power for high quality 12v?, 5v, 3.3v supplies to each port?
- Assist with filtering DGND and AGND possibly?
- Optional external clock? Crystal?
- Long I2S isolation?
- TDM modules can have a daisy chain function for daisy chaining the multiplexed I2S lines?
- Memory socket/port?
  • FREEDSP-HEADER-CONNECTOR.pdf
It also thwarts the spam bots which post something that looks like an ordinary comment or question, but later edit it to spam.
Admittedly, we're doing much better with the spam problem lately, mostly due to a lot of work that's gone into blocking IP numbers and ranges.
Good question. If you do make such a thing, maybe try building just a few and put then on Tindie.
Having just mentioned spam... generally it's ok to post 1 or 2 threads here about a Teensy-related product you've made, and it usually ok to reply about it when it really does address the needs of whoever's asking.
We can also put a link to your Tindie page on the Teensy Products page, if it's meant to work with Teensy.
Hi Paul,
Thank you very much for your reply. I have been actively working on this project.
I was able to get this project moving with the sample parts, but now it's time for me to get it working with the target ADC and DAC modules. The plan is to work on those modules separately, with an "Audio bridge port" connector. The Teensy is the goal for now, but the plan is that by modularizing it we could theoretically use the modules on any MCU/DSP. This might open up the possibility to sell more of these individual modules to any maker for tinkering with high quality audio. In contrast, the bridge might make it easier for makers to hack together just the system they need, with simple modules like the ones that I've demonstrated above.
The Teensy Bridge schematic is attached to this reply. I based these connections off of the SGTL5000 schematics. By the way, I would recommend maybe adjusting the text on the audio shield description page to show the following information. It took some digging and comparing to come up with this simple chart.
I expose Shield 1 and Shield 2 pins two times so that you ultimately get 4 Bridge Connectors. The ADC/DAC modules that I'm designing have all ADC, and all DAC on the boards. Using this shield you'll be able to connect 2 of each as required by any given project. But this could be modified for a TDM mode strategy that could allow the shield to have a ton of inputs and outputs. I am making the decision now to design the boards for "single mode" or instead create modules with multiples of each DAC/ADC to utilize the full potential of the TDM with minimal "audio bridge ports" and cables. Obviously, having too many cables could make this cumbersome.
One possible configuration of my modules could include 16 inputs (two modules connected to Audio_Bridge_Port_Female_A1 and Audio_Bridge_Port_Female_B1) and 16 outputs (two modules connected to Audio_Bridge_Port_Female_A2 and Audio_Bridge_Port_Female_B2) if I designed my modules with maximum capacity (8 inputs and outputs on each)... Ultimately I want to design one module for each purpose (inputs/outputs) but have the ability to expand by adding input or output modules as required for any given project. But I'm also trying to avoid having too many channels on each module resulting in too much for the smaller requirements in smaller projects.
My modules will have > 110 SNR inputs and outputs. I'm going for highly-respectable sound quality - but not uber expensive audiophile grade.
How many DMIPS is the Teensy 3.6? How does it compare to an STM-32F767ZI for example? While the Teensy has proven itself to work just fine in my initial experiment, I'm nervous about having too many inputs and outputs and how it will fair. Any advice is greatly appreciated as I think about this project all the time! :)
  • TEENSY_AUDIO_BRIDGE_C1.pdf
I don't know. I've done a *lot* of benchmarking, but always with real applications (eg, how fast can USB transfer really go), pretty much never these sorts of benchmarks. Maybe Manitou would know?
Generic info online says Cortex-M4 is 1.25 DMIPS/MHz, so at 180 MHz, that's be 225. What that really means, I have no idea!
That chip is probably faster, since it's Cortex-M7. But M7 has a lot of complex details. L1 cache and TCM sizes matter...
The audio library has functions to report the CPU and memory usage. Use those to get an idea of how much you're consuming.
Software optimization and careful design to fully leverage peripherals and DMA often matters much more than raw CPU speed. For example, in benchmarking a couple years ago where a PC transmitted data to various Arduino compatible boards, the old 8 bit Teensy 2.0 turned out to be faster in sustained receiving than some of the should-have-been-much-faster 32 bit boards. The software side makes a tremendous difference. The reality of the complex peripherals in these modern 32 bit chip is many months or even years of work needed for good driver-level software. Benchmarks like DMIPS don't show you how a complex application depending on the platform's drivers will really perform. The software supplied varies tremendously in quality & performance, so unless you're going to write all the low-level code fully from scratch, best to do real-world tests which include the platform's libraries. :)
Although this doesn't pertain to the PCM5102a, I didn't want to create a new thread because this project is related (let me know if I should). I purchased a PCM5242EVM and I've successfully connected it up to a Teensy. I chose the PCM5242 after much research on an easy to use, high quality device. It boasts 114db SNR and can drive both balanced (pro audio) and single ended (consumer audio) lines. It's perfect for a reasonably spec'd audio mixer. (costs $3.50 | 1ku).
For testing purposes I created a prototype "Audio Bridge" which is exposing 4 rows of "I2S/I2C" lines. The design is based on the "FreeDSP Expansion Connector" and it just makes it easier to connect everything up without thinking too hard and counting pins. It would also allow me to connect up 2 (or up to 4) of these PCM5242 to the same I2S/I2C line once I have it configured in TDM mode...
Right now I have the TI Purepath Console connected from the PC->USB->PCM5242EVM. This is controlling the I2C signals only and initializing the DAC. Then I have PC->USB->Teensy which is then sending the I2S signal to the PCM5242. So the Purepath initializes the DAC and the Teensy sends the I2S data. It's working, and sounds GREAT. Using the PurePath Console I can see all the different registers and settings, and there is a way to export the XML.
So now I have to figure out how to disconnect the Purepath I2C control (SDA/SCL) and connect it to the Teensy so that it can initialize the DAC (rather than the way it is now with the Purepath Console doing it). I could use some help with the drivers. Question: How do I go about converting this XML to the required I2C firmware driver? I'll be looking into this so any advice will be greatly appreciated. I'll share the PCM5242 firmware back to the teensy project once it works.
I'll probably start by looking at the code for the Teensy Hearing Aid (TLV320AIC3206). At least it's a comparable TI chip... Here goes! :)
<?xml version="1.0"?>
<properties>
	<header>PCM5242</header>
	<component name="HF4MP">
		<property name="I2CAddress1" value="215"/>
		<property name="Input" value="LR2"/>
		<property name="Phase" value="0"/>
	</component>
	<component name="HF6DBE">
		<property name="AvgWin" value="100.0"/>
		<property name="I2CAddress1" value="22"/>
		<property name="I2CLength1" value="12"/>
		<property name="LowerMixing" value="-30.0"/>
		<property name="UpperMixing" value="-10.0"/>
	</component>
	<component name="HF1DRC1">
		<property name="Attack0" value="50.0"/>
		<property name="Attack1" value="20.0"/>
		<property name="Attack2" value="2.5"/>
		<property name="c0" value="1"/>
		<property name="c1" value="1"/>
		<property name="c2" value="1"/>
		<property name="CurrentRate" value="Rate48"/>
		<property name="CurrentTarget" value="PCM5242"/>
		<property name="Decay0" value="150.0"/>
		<property name="Decay1" value="60.0"/>
		<property name="Decay2" value="7.5"/>
		<property name="Energy0" value="100.0"/>
		<property name="Energy1" value="40.0"/>
		<property name="Energy2" value="5.0"/>
		<property name="EnergyAveragingMethod" value="AlphaFilter"/>
		<property name="GainControlType" value="CompressionAndExpansion"/>
		<property name="I2CAddress1" value="5"/>
		<property name="I2CLength1" value="100"/>
		<property name="Instances" value="3"/>
		<property name="k0" value="0.0"/>
		<property name="k1" value="0.0"/>
		<property name="k2" value="0.0"/>
		<property name="MaxThreshold" value="12.0"/>
		<property name="MaxX" value="12.0"/>
		<property name="MaxY" value="12.0"/>
		<property name="MinThreshold" value="-124.0"/>
		<property name="MinX" value="-124.0"/>
		<property name="MinY" value="-124.0"/>
		<property name="MT1" value="80.0"/>
		<property name="MT2" value="20.0"/>
		<property name="NegSatLevel" value="-48.0"/>
		<property name="Offset0" value="0.0"/>
		<property name="Offset1" value="0.0"/>
		<property name="Offset2" value="0.0"/>
		<property name="OffsetType" value="0"/>
		<property name="Ratio0" value="1.0"/>
		<property name="Ratio1" value="1.0"/>
		<property name="Ratio2" value="1.0"/>
		<property name="RatioType0" value="1.0"/>
		<property name="RatioType1" value="0.0"/>
		<property name="RatioType2" value="0.0"/>
		<property name="Regions" value="3"/>
		<property name="SatLevel" value="48"/>
		<property name="Threshold1" value="-80.0"/>
		<property name="Threshold2" value="-20.0"/>
		<property name="WriteToBoard" value="False"/>
	</component>
	<component name="HF2DBEBQHIGH">
		<property name="ActiveGangList" value=""/>
		<property name="AliasOf" value="None"/>
		<property name="CoefDefaultQ" value="23"/>
		<property name="CoefWidth" value="24"/>
		<property name="DisplayName" value="None"/>
		<property name="GangList" value=""/>
		<property name="HasAlias" value="False"/>
		<property name="I2CAddress1" value="177"/>
		<property name="I2CAddress2" value="182"/>
		<property name="I2CLength1" value="20"/>
		<property name="I2CLength2" value="20"/>
		<property name="Inst1_A1" value="0"/>
		<property name="Inst1_A2" value="0"/>
		<property name="Inst1_B0" value="0.99999988079071044921875"/>
		<property name="Inst1_B1" value="0"/>
		<property name="Inst1_B2" value="0"/>
		<property name="Inst1_Bandwidth" value="1000.0"/>
		<property name="Inst1_CornerFrequency" value="180.0"/>
		<property name="Inst1_FilterSubType" value="Linkwitz Riley 2"/>
		<property name="Inst1_FilterType" value="All Pass"/>
		<property name="Inst1_Gain" value="5.0"/>
		<property name="Inst1_On" value="1"/>
		<property name="Inst1_PB" value="0.5"/>
		<property name="Inst1_Q" value="8.6"/>
		<property name="Inst1_Scale" value="1.0"/>
		<property name="Inst2_A1" value="0"/>
		<property name="Inst2_A2" value="0"/>
		<property name="Inst2_B0" value="0.99999988079071044921875"/>
		<property name="Inst2_B1" value="0"/>
		<property name="Inst2_B2" value="0"/>
		<property name="Inst2_Bandwidth" value="2000.0"/>
		<property name="Inst2_CornerFrequency" value="14000.0"/>
		<property name="Inst2_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst2_FilterType" value="All Pass"/>
		<property name="Inst2_Gain" value="-6.0"/>
		<property name="Inst2_On" value="1"/>
		<property name="Inst2_PB" value="0.5"/>
		<property name="Inst2_Q" value="0.707"/>
		<property name="Inst2_Scale" value="1.0"/>
		<property name="Instances" value="2"/>
		<property name="IsGanged" value="False"/>
		<property name="Rate12" value="False"/>
		<property name="Rate16" value="False"/>
		<property name="Rate176" value="False"/>
		<property name="Rate192" value="False"/>
		<property name="Rate24" value="False"/>
		<property name="Rate32" value="False"/>
		<property name="Rate44" value="True"/>
		<property name="Rate48" value="False"/>
		<property name="Rate8" value="False"/>
		<property name="Rate88" value="False"/>
		<property name="Rate96" value="False"/>
		<property name="ShowComposite" value="False"/>
	</component>
	<component name="HF6DBEBQLOW">
		<property name="I2CAddress1" value="62"/>
		<property name="I2CAddress2" value="67"/>
		<property name="I2CAddress3" value="72"/>
		<property name="I2CAddress4" value="77"/>
		<property name="I2CAddress5" value="82"/>
		<property name="I2CLength3" value="20"/>
		<property name="I2CLength4" value="20"/>
		<property name="I2CLength5" value="20"/>
		<property name="Inst1_B0" value="0.99999988079071"/>
		<property name="Inst1_Bandwidth" value="1.0"/>
		<property name="Inst1_CornerFrequency" value="1.0"/>
		<property name="Inst1_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst1_Gain" value="0.0"/>
		<property name="Inst1_Q" value="0.707"/>
		<property name="Inst2_B0" value="0.99999988079071"/>
		<property name="Inst2_Bandwidth" value="1.0"/>
		<property name="Inst2_CornerFrequency" value="10.0"/>
		<property name="Inst2_Gain" value="0.0"/>
		<property name="Inst3_A1" value="0"/>
		<property name="Inst3_A2" value="0"/>
		<property name="Inst3_B0" value="0.99999988079071"/>
		<property name="Inst3_B1" value="0"/>
		<property name="Inst3_B2" value="0"/>
		<property name="Inst3_Bandwidth" value="1.0"/>
		<property name="Inst3_CornerFrequency" value="100.0"/>
		<property name="Inst3_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst3_FilterType" value="All Pass"/>
		<property name="Inst3_Gain" value="0.0"/>
		<property name="Inst3_On" value="1"/>
		<property name="Inst3_PB" value="0.5"/>
		<property name="Inst3_Q" value="0.707"/>
		<property name="Inst3_Scale" value="1.0"/>
		<property name="Inst4_A1" value="0"/>
		<property name="Inst4_A2" value="0"/>
		<property name="Inst4_B0" value="0.99999988079071"/>
		<property name="Inst4_B1" value="0"/>
		<property name="Inst4_B2" value="0"/>
		<property name="Inst4_Bandwidth" value="0.0"/>
		<property name="Inst4_CornerFrequency" value="0.0"/>
		<property name="Inst4_FilterSubType" value="None"/>
		<property name="Inst4_FilterType" value="All Pass"/>
		<property name="Inst4_Gain" value="0.0"/>
		<property name="Inst4_On" value="1"/>
		<property name="Inst4_PB" value="0.5"/>
		<property name="Inst4_Q" value="0.707"/>
		<property name="Inst4_Scale" value="1.0"/>
		<property name="Inst5_A1" value="0"/>
		<property name="Inst5_A2" value="0"/>
		<property name="Inst5_B0" value="0.99999988079071"/>
		<property name="Inst5_B1" value="0"/>
		<property name="Inst5_B2" value="0"/>
		<property name="Inst5_Bandwidth" value="0.0"/>
		<property name="Inst5_CornerFrequency" value="0.0"/>
		<property name="Inst5_FilterSubType" value="None"/>
		<property name="Inst5_FilterType" value="All Pass"/>
		<property name="Inst5_Gain" value="0.0"/>
		<property name="Inst5_On" value="1"/>
		<property name="Inst5_PB" value="0.5"/>
		<property name="Inst5_Q" value="0.707"/>
		<property name="Inst5_Scale" value="1.0"/>
		<property name="Instances" value="5"/>
	</component>
	<component name="HF3BQROM2">
		<property name="AliasOf" value=""/>
		<property name="I2CAddress1" value="43"/>
		<property name="I2CAddress2" value="48"/>
		<property name="I2CAddress3" value="53"/>
		<property name="I2CAddress4" value="58"/>
		<property name="I2CAddress5" value="63"/>
		<property name="Inst1_A1" value="0.43848812580108642578125"/>
		<property name="Inst1_B0" value="0.0615117549896240234375"/>
		<property name="Inst1_B1" value="0.03075587749481201171875"/>
		<property name="Inst1_CornerFrequency" value="1000.0"/>
		<property name="Inst1_FilterType" value="Low Pass"/>
		<property name="Inst1_Q" value="1.0"/>
		<property name="Inst2_A1" value="0.9662277698516845703125"/>
		<property name="Inst2_A2" value="-0.93660199642181396484375"/>
		<property name="Inst2_B1" value="-0.9662277698516845703125"/>
		<property name="Inst2_B2" value="0.93660199642181396484375"/>
		<property name="Inst2_Bandwidth" value="500.0"/>
		<property name="Inst2_CornerFrequency" value="500.0"/>
		<property name="Inst2_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst2_Q" value="1.0"/>
		<property name="Inst3_A1" value="0.98337256908416748046875"/>
		<property name="Inst3_A2" value="-0.9677989482879638671875"/>
		<property name="Inst3_B0" value="0.99999988079071044921875"/>
		<property name="Inst3_B1" value="-0.98337256908416748046875"/>
		<property name="Inst3_B2" value="0.9677989482879638671875"/>
		<property name="Inst3_Bandwidth" value="250.0"/>
		<property name="Inst3_CornerFrequency" value="250.0"/>
		<property name="Inst3_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst3_Q" value="1.0"/>
		<property name="Inst4_A1" value="0.99175202846527099609375"/>
		<property name="Inst4_A2" value="-0.98376977443695068359375"/>
		<property name="Inst4_B0" value="0.99999988079071044921875"/>
		<property name="Inst4_B1" value="-0.99175202846527099609375"/>
		<property name="Inst4_B2" value="0.98376977443695068359375"/>
		<property name="Inst4_Bandwidth" value="125.0"/>
		<property name="Inst4_CornerFrequency" value="125.0"/>
		<property name="Inst4_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst4_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst4_Q" value="1.0"/>
		<property name="Inst5_A1" value="0.99585950374603271484375"/>
		<property name="Inst5_A2" value="-0.991786956787109375"/>
		<property name="Inst5_B0" value="0.99999988079071044921875"/>
		<property name="Inst5_B1" value="-0.99585950374603271484375"/>
		<property name="Inst5_B2" value="0.991786956787109375"/>
		<property name="Inst5_Bandwidth" value="63.0"/>
		<property name="Inst5_CornerFrequency" value="63.0"/>
		<property name="Inst5_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst5_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst5_Q" value="1.0"/>
	</component>
	<component name="HF7BQComposite">
		<property name="ComponentList" value="HF7BQLow,HF7BQMid,HF7BQHigh"/>
		<property name="IsParallel" value="True"/>
		<property name="MixerName" value="HF7DRCMixer"/>
	</component>
	<component name="HF2DRCMixer">
		<property name="Gain1" value="0.999999880791"/>
		<property name="Gain2" value="-0.999999880791"/>
		<property name="Gain3" value="0.999999880791"/>
		<property name="I2CAddress" value="0"/>
	</component>
	<component name="Framework">
		<property name="3262CoefWidth" value="24"/>
		<property name="ADCAdaptive" value="False"/>
		<property name="AutoWriteState" value="True"/>
		<property name="AutoWriteStateDelay" value="100"/>
		<property name="DACAdaptive" value="True"/>
		<property name="DACAdaptive1" value="False"/>
		<property name="DACAdaptive2" value="False"/>
		<property name="DefaultI2C" value="152"/>
		<property name="DeviceName" value="PCM5242"/>
		<property name="DeviceType" value="PCM52XX"/>
		<property name="HF1CFG" value="HF1CFG.cfg"/>
		<property name="HF2CFG" value="HF2CFG.cfg"/>
		<property name="HF3CFG" value="HF3CFG.cfg"/>
		<property name="HF4CFG" value="HF4CFG.cfg"/>
		<property name="HF5CFG" value="HF5CFG.cfg"/>
		<property name="HF6CFG" value="HF6CFG.cfg"/>
		<property name="HybridFlow" value="8"/>
		<property name="HybridFlowMono" value="None"/>
		<property name="I2CAddress1" value="0"/>
		<property name="I2CLength1" value="1"/>
		<property name="MonoI2C" value="154"/>
		<property name="SampleRate" value="48kHz"/>
		<property name="StereoI2C" value="152"/>
		<property name="TargetType" value="AIC3xxx"/>
		<property name="USBType" value="AIC_TUSB1020B"/>
	</component>
	<component name="HF3DBEBQSENSE">
		<property name="I2CAddress1" value="98"/>
		<property name="I2CAddress2" value="103"/>
		<property name="Inst1_A1" value="0.49349737167358398437500"/>
		<property name="Inst1_B0" value="0.99349737167358398437500"/>
		<property name="Inst1_B1" value="-0.49674868583679199218750"/>
		<property name="Inst1_Bandwidth" value="120"/>
		<property name="Inst1_CornerFrequency" value="100"/>
		<property name="Inst1_FilterType" value="High Pass"/>
		<property name="Inst2_A1" value="0.48707830905914306640625"/>
		<property name="Inst2_A2" value="0.0"/>
		<property name="Inst2_B0" value="0.01292145252227783203125"/>
		<property name="Inst2_B1" value="0.006460666656494140625"/>
		<property name="Inst2_B2" value="0.0"/>
		<property name="Inst2_CornerFrequency" value="200.0"/>
		<property name="Inst2_FilterType" value="Low Pass"/>
		<property name="LowerSensing" value="40.0"/>
		<property name="UpperSensing" value="160.0"/>
	</component>
	<component name="HF2BQComposite">
		<property name="ComponentList" value="HF2BQLow,HF2BQMid,HF2BQHigh"/>
		<property name="MixerName" value="HF2DRCMixer"/>
	</component>
	<component name="HF3DBE">
		<property name="I2CAddress1" value="69"/>
	</component>
	<component name="HF2SG">
		<property name="I2CAddress1" value="161"/>
		<property name="I2CAddress2" value="151"/>
		<property name="I2CLength1" value="4"/>
		<property name="Level" value="0"/>
		<property name="SubSourceSelect" value="drc"/>
	</component>
	<component name="HF3BQROM1">
		<property name="I2CAddress1" value="72"/>
		<property name="I2CAddress2" value="77"/>
		<property name="I2CAddress3" value="82"/>
		<property name="I2CAddress4" value="87"/>
		<property name="I2CAddress5" value="92"/>
		<property name="Inst1_A1" value="0.4384882314963785"/>
		<property name="Inst1_B0" value="0.938488231496378"/>
		<property name="Inst1_B1" value="-0.469244115748189"/>
		<property name="Inst2_A1" value="0.911873929345145"/>
		<property name="Inst2_A2" value="-0.848436815395613"/>
		<property name="Inst2_B1" value="-0.911873929345145"/>
		<property name="Inst2_B2" value="0.848436815395613"/>
		<property name="Inst2_Bandwidth" value="1250.0"/>
		<property name="Inst2_CornerFrequency" value="1250.0"/>
		<property name="Inst3_A1" value="0.885117954958025"/>
		<property name="Inst3_A2" value="-0.809784033195007"/>
		<property name="Inst3_B1" value="-0.885117954958025"/>
		<property name="Inst3_B2" value="0.809784033195007"/>
		<property name="Inst3_Bandwidth" value="1600.0"/>
		<property name="Inst3_CornerFrequency" value="1600.0"/>
		<property name="Inst4_A1" value="0.853553390593275"/>
		<property name="Inst4_A2" value="-0.76732698797896"/>
		<property name="Inst4_B1" value="-0.853553390593275"/>
		<property name="Inst4_B2" value="0.76732698797896"/>
		<property name="Inst4_Bandwidth" value="2000.0"/>
		<property name="Inst4_CornerFrequency" value="2000.0"/>
		<property name="Inst5_A1" value="0.81274533209597"/>
		<property name="Inst5_A2" value="-0.716589866095654"/>
		<property name="Inst5_B1" value="-0.81274533209597"/>
		<property name="Inst5_B2" value="0.716589866095654"/>
		<property name="Inst5_Bandwidth" value="2500.0"/>
		<property name="Inst5_CornerFrequency" value="2500.0"/>
	</component>
	<component name="HF7FineVolume">
		<property name="FineVolume" value="0.0"/>
		<property name="I2CAddress1" value="255"/>
	</component>
	<component name="HF1BQROM1">
		<property name="I2CAddress1" value="83"/>
		<property name="I2CAddress10" value="128"/>
		<property name="I2CAddress2" value="88"/>
		<property name="I2CAddress3" value="93"/>
		<property name="I2CAddress4" value="98"/>
		<property name="I2CAddress5" value="103"/>
		<property name="I2CAddress6" value="108"/>
		<property name="I2CAddress7" value="113"/>
		<property name="I2CAddress8" value="118"/>
		<property name="I2CAddress9" value="123"/>
		<property name="I2CLength10" value="20"/>
		<property name="I2CLength6" value="20"/>
		<property name="I2CLength7" value="20"/>
		<property name="I2CLength8" value="20"/>
		<property name="I2CLength9" value="20"/>
		<property name="Inst1_A1" value="0.4960882663726806640625"/>
		<property name="Inst1_B0" value="0.99608814716339111328125"/>
		<property name="Inst1_B1" value="-0.49804401397705078125"/>
		<property name="Inst1_CornerFrequency" value="10.0"/>
		<property name="Inst10_A1" value="0.49967277050018310546875"/>
		<property name="Inst10_A2" value="0"/>
		<property name="Inst10_B0" value="0.9996726512908935546875"/>
		<property name="Inst10_B1" value="-0.49983632564544677734375"/>
		<property name="Inst10_B2" value="0"/>
		<property name="Inst10_Bandwidth" value="5.0"/>
		<property name="Inst10_CornerFrequency" value="5.0"/>
		<property name="Inst10_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst10_FilterType" value="High Pass"/>
		<property name="Inst10_Gain" value="0.0"/>
		<property name="Inst10_On" value="1"/>
		<property name="Inst10_PB" value="0.5"/>
		<property name="Inst10_Q" value="0.707"/>
		<property name="Inst10_Scale" value="1.0"/>
		<property name="Inst2_A1" value="0.99895155429840087890625"/>
		<property name="Inst2_A2" value="-0.9979076385498046875"/>
		<property name="Inst2_B1" value="-0.99895155429840087890625"/>
		<property name="Inst2_B2" value="0.9979076385498046875"/>
		<property name="Inst2_Bandwidth" value="16.0"/>
		<property name="Inst2_CornerFrequency" value="16.0"/>
		<property name="Inst3_A1" value="0.99790108203887939453125"/>
		<property name="Inst3_A2" value="-0.9958198070526123046875"/>
		<property name="Inst3_B1" value="-0.99790108203887939453125"/>
		<property name="Inst3_B2" value="0.9958198070526123046875"/>
		<property name="Inst3_Bandwidth" value="32.0"/>
		<property name="Inst3_CornerFrequency" value="32.0"/>
		<property name="Inst3_FilterSubType" value="Linkwitz Riley 2"/>
		<property name="Inst4_A1" value="0.9957935810089111328125"/>
		<property name="Inst4_A2" value="-0.99165713787078857421875"/>
		<property name="Inst4_B1" value="-0.9957935810089111328125"/>
		<property name="Inst4_B2" value="0.99165713787078857421875"/>
		<property name="Inst4_Bandwidth" value="64.0"/>
		<property name="Inst4_CornerFrequency" value="64.0"/>
		<property name="Inst5_A1" value="0.99175202846527099609375"/>
		<property name="Inst5_A2" value="-0.98376977443695068359375"/>
		<property name="Inst5_B1" value="-0.99175202846527099609375"/>
		<property name="Inst5_B2" value="0.98376977443695068359375"/>
		<property name="Inst5_Bandwidth" value="125.0"/>
		<property name="Inst5_CornerFrequency" value="125.0"/>
		<property name="Inst6_A1" value="0.98337256908416748046875"/>
		<property name="Inst6_A2" value="-0.9677989482879638671875"/>
		<property name="Inst6_B0" value="0.99999988079071044921875"/>
		<property name="Inst6_B1" value="-0.98337256908416748046875"/>
		<property name="Inst6_B2" value="0.9677989482879638671875"/>
		<property name="Inst6_Bandwidth" value="250.0"/>
		<property name="Inst6_CornerFrequency" value="250.0"/>
		<property name="Inst6_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst6_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst6_Gain" value="0.0"/>
		<property name="Inst6_On" value="1"/>
		<property name="Inst6_PB" value="0.5"/>
		<property name="Inst6_Q" value="0.707"/>
		<property name="Inst6_Scale" value="1.0"/>
		<property name="Inst7_A1" value="0.9662277698516845703125"/>
		<property name="Inst7_A2" value="-0.93660199642181396484375"/>
		<property name="Inst7_B0" value="0.99999988079071044921875"/>
		<property name="Inst7_B1" value="-0.9662277698516845703125"/>
		<property name="Inst7_B2" value="0.93660199642181396484375"/>
		<property name="Inst7_Bandwidth" value="500.0"/>
		<property name="Inst7_CornerFrequency" value="500.0"/>
		<property name="Inst7_FilterSubType" value="Linkwitz Riley 2"/>
		<property name="Inst7_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst7_Gain" value="0.0"/>
		<property name="Inst7_On" value="1"/>
		<property name="Inst7_PB" value="0.5"/>
		<property name="Inst7_Q" value="0.707"/>
		<property name="Inst7_Scale" value="1.0"/>
		<property name="Inst8_A1" value="0.93045914173126220703125"/>
		<property name="Inst8_A2" value="-0.8769762516021728515625"/>
		<property name="Inst8_B0" value="0.99999988079071044921875"/>
		<property name="Inst8_B1" value="-0.93045914173126220703125"/>
		<property name="Inst8_B2" value="0.8769762516021728515625"/>
		<property name="Inst8_Bandwidth" value="1000.0"/>
		<property name="Inst8_CornerFrequency" value="1000.0"/>
		<property name="Inst8_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst8_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst8_Gain" value="0.0"/>
		<property name="Inst8_On" value="1"/>
		<property name="Inst8_PB" value="0.5"/>
		<property name="Inst8_Q" value="0.707"/>
		<property name="Inst8_Scale" value="1.0"/>
		<property name="Inst9_A1" value="0.85355317592620849609375"/>
		<property name="Inst9_A2" value="-0.767326831817626953125"/>
		<property name="Inst9_B0" value="0.99999988079071044921875"/>
		<property name="Inst9_B1" value="-0.85355317592620849609375"/>
		<property name="Inst9_B2" value="0.767326831817626953125"/>
		<property name="Inst9_Bandwidth" value="2000.0"/>
		<property name="Inst9_CornerFrequency" value="2000.0"/>
		<property name="Inst9_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst9_FilterType" value="Equalizer (Bandwidth)"/>
		<property name="Inst9_Gain" value="0.0"/>
		<property name="Inst9_On" value="1"/>
		<property name="Inst9_PB" value="0.5"/>
		<property name="Inst9_Q" value="0.707"/>
		<property name="Inst9_Scale" value="1.0"/>
		<property name="Instances" value="10"/>
	</component>
	<component name="HF1BQLow">
		<property name="I2CAddress1" value="189"/>
		<property name="Inst1_A1" value="0.93660199642181396484375"/>
		<property name="Inst1_A2" value="-0.877223491668701171875"/>
		<property name="Inst1_B0" value="0.00100481510162353515625"/>
		<property name="Inst1_B1" value="0.00100481510162353515625"/>
		<property name="Inst1_B2" value="0.00100481510162353515625"/>
		<property name="Inst1_CornerFrequency" value="500.0"/>
		<property name="Instances" value="1"/>
	</component>
	<component name="HF4DBEBQHIGH">
		<property name="Inst1_CornerFrequency" value="8600.0"/>
		<property name="Inst3_Bandwidth" value="0.0"/>
		<property name="Inst3_CornerFrequency" value="20000.0"/>
		<property name="Inst4_CornerFrequency" value="16000.0"/>
		<property name="Inst4_Gain" value="-3.0"/>
		<property name="Instances" value="4"/>
	</component>
	<component name="HF6BQLow">
		<property name="I2CAddress1" value="2"/>
		<property name="Inst1_Bandwidth" value="0.0"/>
	</component>
	<component name="HF2DBE">
		<property name="I2CAddress1" value="143"/>
	</component>
	<component name="HF2SGBQ">
		<property name="I2CAddress1" value="156"/>
		<property name="Inst1_A1" value="0.49220693111419677734375"/>
		<property name="Inst1_B0" value="0.00779283046722412109375"/>
		<property name="Inst1_B1" value="0.00389635562896728515625"/>
		<property name="Inst1_CornerFrequency" value="120.0"/>
		<property name="LPF" value="300.0"/>
	</component>
	<component name="HF4PBE">
		<property name="Bypass" value="False"/>
		<property name="Effect" value="1"/>
		<property name="HarmonicGain" value="0"/>
		<property name="HPF" value="50"/>
		<property name="I2CAddress1" value="35"/>
		<property name="I2CAddress2" value="36"/>
		<property name="I2CAddress3" value="235"/>
		<property name="I2CLength2" value="100"/>
		<property name="I2CLength3" value="8"/>
	</component>
	<component name="HF4BQMid">
		<property name="I2CAddress2" value="10"/>
		<property name="Inst1_A1" value="0.66817843914031982421875"/>
		<property name="Inst1_A2" value="-0.4464626312255859375"/>
		<property name="Inst1_B0" value="0.02752625942230224609375"/>
		<property name="Inst1_B1" value="0.02752625942230224609375"/>
		<property name="Inst1_B2" value="0.02752625942230224609375"/>
		<property name="Inst1_CornerFrequency" value="3000.0"/>
		<property name="Inst1_On" value="0"/>
		<property name="Inst2_A1" value="0.93660199642181396484375"/>
		<property name="Inst2_A2" value="-0.877223491668701171875"/>
		<property name="Inst2_B0" value="0.02752625942230224609375"/>
		<property name="Inst2_B1" value="0.02752625942230224609375"/>
		<property name="Inst2_B2" value="0.02752625942230224609375"/>
		<property name="Inst2_Bandwidth" value="0.0"/>
		<property name="Inst2_FilterSubType" value="Linkwitz Riley 2"/>
		<property name="Inst2_FilterType" value="High Pass"/>
		<property name="Inst2_On" value="0"/>
		<property name="ShowComposite" value="True"/>
	</component>
	<component name="HF4DRC1">
		<property name="Energy0" value="150.0"/>
		<property name="I2CAddress1" value="111"/>
	</component>
	<component name="HF7BQLow">
		<property name="I2CAddress1" value="30"/>
	</component>
	<component name="HF4BQLow">
		<property name="Inst1_B0" value="0.69570481777191162109375"/>
		<property name="Inst1_B1" value="-0.69570481777191162109375"/>
		<property name="Inst1_B2" value="0.69570481777191162109375"/>
	</component>
	<component name="HF2DDEBQLOW">
		<property name="I2CAddress1" value="227"/>
		<property name="I2CAddress2" value="232"/>
		<property name="Inst2_Bandwidth" value="1000.0"/>
		<property name="Inst2_CornerFrequency" value="320.0"/>
		<property name="Inst2_Gain" value="5.0"/>
		<property name="Inst2_Q" value="8.6"/>
	</component>
	<component name="ErrorHandlingMono">
		<property name="AVDD" value="True"/>
		<property name="DetectPeriod" value="0"/>
		<property name="FS" value="True"/>
		<property name="MCLKError" value="True"/>
		<property name="MissingLRCK" value="True"/>
		<property name="MissingMCLK" value="True"/>
		<property name="PLLLockError" value="True"/>
		<property name="SCLKError" value="True"/>
	</component>
	<component name="HF3BQMid">
		<property name="I2CAddress1" value="33"/>
		<property name="Inst1_A1" value="0.767326831817626953125"/>
		<property name="Inst1_A2" value="-0.58879053592681884765625"/>
		<property name="Inst1_B0" value="0.78086102008819580078125"/>
		<property name="Inst1_B1" value="-0.78086102008819580078125"/>
		<property name="Inst1_B2" value="0.78086102008819580078125"/>
		<property name="Inst1_CornerFrequency" value="2000.0"/>
	</component>
	<component name="HF6FineVolume">
	</component>
	<component name="HF7MonoBQComposite">
	</component>
	<component name="HF7MonoFineVolume">
	</component>
	<component name="HF2BQROM1">
	</component>
	<component name="EVMIO">
		<property name="DSPCoefBlockStart1" value="1"/>
		<property name="HPMute" value="False"/>
		<property name="Input" value="USB"/>
		<property name="Output" value="USB"/>
		<property name="TargetProcessor" value="miniDSP_D"/>
		<property name="USBMute" value="False"/>
		<property name="Volume" value="0"/>
	</component>
	<component name="HF7DRCMixer">
	</component>
	<component name="HF2SmoothClip">
		<property name="Coefficient" value="0"/>
		<property name="CoefficientHex" value="0x400000"/>
		<property name="I2CAddress1" value="251"/>
	</component>
	<component name="HF5MonoBQROM1">
		<property name="Inst1_A1" value="0.49983632564544677734375"/>
		<property name="Inst1_A2" value="0.0"/>
		<property name="Inst1_B0" value="0.9998362064361572265625"/>
		<property name="Inst1_B1" value="-0.49991810321807861328125"/>
		<property name="Inst1_B2" value="0.0"/>
	</component>
	<component name="HF3DBEBQLOW">
		<property name="I2CAddress1" value="212"/>
		<property name="I2CAddress2" value="217"/>
		<property name="I2CAddress3" value="222"/>
	</component>
	<component name="HF6SFSBQ">
		<property name="HPF" value="200.0"/>
		<property name="I2CAddress1" value="51"/>
		<property name="I2CAddress2" value="56"/>
		<property name="Inst1_A1" value="0.98148715496063232421875"/>
		<property name="Inst1_A2" value="-0.963647365570068359375"/>
		<property name="Inst1_B0" value="0.9816553592681884765625"/>
		<property name="Inst1_B1" value="-0.9816553592681884765625"/>
		<property name="Inst1_B2" value="0.9816553592681884765625"/>
		<property name="Inst1_CornerFrequency" value="200.0"/>
		<property name="Inst2_A1" value="0.7270982265472412109375"/>
		<property name="Inst2_A2" value="-0.57401120662689208984375"/>
		<property name="Inst2_B0" value="0.02995359897613525390625"/>
		<property name="Inst2_B1" value="0.02995359897613525390625"/>
		<property name="Inst2_B2" value="0.02995359897613525390625"/>
		<property name="Inst2_CornerFrequency" value="3000.0"/>
		<property name="LPF" value="3000.0"/>
	</component>
	<component name="HF3BQHigh">
		<property name="I2CAddress1" value="28"/>
		<property name="Inst1_B0" value="0.013534069061279296875"/>
		<property name="Inst1_B1" value="0.013534069061279296875"/>
		<property name="Inst1_B2" value="0.013534069061279296875"/>
	</component>
	<component name="HF4BQComposite">
		<property name="ComponentList" value="HF4BQLow,HF4BQMid,HF4BQHigh"/>
		<property name="MixerName" value="HF4DRCMixer"/>
	</component>
	<component name="HF1DRCMixer">
	</component>
	<component name="HF2DDE">
		<property name="I2CAddress1" value="219"/>
	</component>
	<component name="HF5SG">
		<property name="I2CAddress1" value="7"/>
		<property name="I2CAddress2" value="25"/>
	</component>
	<component name="HF6SFS">
		<property name="I2CAddress1" value="61"/>
	</component>
	<component name="HF3CM">
		<property name="I2CAddress1" value="201"/>
		<property name="I2CAddress2" value="206"/>
		<property name="LowInput" value="LR2"/>
		<property name="LowPhase" value="0"/>
		<property name="MidInput" value="LR2"/>
		<property name="MidPhase" value="0"/>
	</component>
	<component name="HF4BQHigh">
		<property name="I2CAddress1" value="15"/>
		<property name="Inst1_A1" value="0.33408915996551513671875"/>
		<property name="Inst1_B0" value="0.83408915996551513671875"/>
		<property name="Inst1_B1" value="-0.41704452037811279296875"/>
	</component>
	<component name="HF3BQComposite">
		<property name="ComponentList" value="HF3BQMid,HF3BQHigh"/>
		<property name="MixerName" value="HF3DRCMixer"/>
	</component>
	<component name="HF7DRC1">
		<property name="RatioType0" value="0.0"/>
	</component>
	<component name="HF3DS">
		<property name="I2CAddress1" value="196"/>
		<property name="MidDelaySamples" value="0"/>
	</component>
	<component name="HF1FineVolume">
	</component>
	<component name="HF6DBEBQHIGH">
		<property name="I2CAddress1" value="36"/>
		<property name="I2CAddress2" value="41"/>
		<property name="I2CAddress3" value="46"/>
	</component>
	<component name="HF7MonoBQROM1">
		<property name="I2CAddress1" value="47"/>
		<property name="I2CAddress2" value="52"/>
		<property name="I2CAddress3" value="57"/>
		<property name="I2CAddress4" value="62"/>
		<property name="I2CAddress5" value="40"/>
		<property name="Inst1_A1" value="0.49967277050018310546875"/>
		<property name="Inst1_B0" value="0.9996726512908935546875"/>
		<property name="Inst1_B1" value="-0.49983632564544677734375"/>
		<property name="Inst2_A1" value="0.99175202846527099609375"/>
		<property name="Inst2_A2" value="-0.98376977443695068359375"/>
		<property name="Inst2_B1" value="-0.99175202846527099609375"/>
		<property name="Inst2_B2" value="0.98376977443695068359375"/>
		<property name="Inst2_Bandwidth" value="250.0"/>
		<property name="Inst2_CornerFrequency" value="250.0"/>
		<property name="Inst3_Bandwidth" value="500.0"/>
		<property name="Inst3_CornerFrequency" value="500.0"/>
		<property name="Inst4_A1" value="0.9662277698516845703125"/>
		<property name="Inst4_A2" value="-0.93660199642181396484375"/>
		<property name="Inst4_B1" value="-0.9662277698516845703125"/>
		<property name="Inst4_B2" value="0.93660199642181396484375"/>
		<property name="Inst4_Bandwidth" value="1000.0"/>
		<property name="Inst4_CornerFrequency" value="1000.0"/>
		<property name="Inst5_A1" value="0.93045914173126220703125"/>
		<property name="Inst5_A2" value="-0.8769762516021728515625"/>
		<property name="Inst5_B1" value="-0.93045914173126220703125"/>
		<property name="Inst5_B2" value="0.8769762516021728515625"/>
		<property name="Inst5_Bandwidth" value="2000.0"/>
		<property name="Inst5_CornerFrequency" value="2000.0"/>
	</component>
	<component name="HF7MonoSmoothClip">
		<property name="Coefficient" value="0.0"/>
	</component>
	<component name="HF5MonoDRC1">
		<property name="CurrentTarget" value="PCM5142"/>
		<property name="Decay0" value="200.0"/>
		<property name="I2CAddress1" value="17"/>
		<property name="I2CLength1" value="32"/>
		<property name="MaxX" value="0.0"/>
		<property name="MaxY" value="0.0"/>
		<property name="MinX" value="-60.0"/>
		<property name="MinY" value="-60.0"/>
		<property name="Ratio1" value="2.0"/>
		<property name="Regions" value="2"/>
		<property name="Threshold1" value="0.0"/>
	</component>
	<component name="HF6BQComposite">
		<property name="ComponentList" value="HF6BQLow,HF6BQMid,HF6BQHigh"/>
		<property name="MixerName" value="HF6DRCMixer"/>
	</component>
	<component name="HF6DRCMixer">
		<property name="I2CAddress" value="12"/>
	</component>
	<component name="HF4DBEBQLOW">
		<property name="I2CAddress1" value="191"/>
		<property name="I2CAddress2" value="196"/>
		<property name="I2CAddress3" value="201"/>
		<property name="I2CAddress4" value="206"/>
	</component>
	<component name="AudioAmpConfigMono">
		<property name="AnaDigiMute" value="True"/>
		<property name="AnalogBoostA" value="False"/>
		<property name="AnalogBoostB" value="False"/>
		<property name="AutoMuteTimeA" value="0"/>
		<property name="AutoMuteTimeB" value="0"/>
		<property name="DACGainA" value="0"/>
		<property name="DACGainB" value="0"/>
		<property name="DataOffset" value="0"/>
		<property name="Demphasis" value="False"/>
		<property name="SerialAudioDataFormat" value="0"/>
		<property name="SerialAudioWordLength" value="2"/>
		<property name="SwapABData" value="False"/>
		<property name="VCOMRefRamp" value="False"/>
	</component>
	<component name="RightPanelControlStereo">
		<property name="AmpStatus" value="0"/>
		<property name="ClockStatus" value="0"/>
		<property name="DataStatus" value="0"/>
		<property name="DetectedFs" value="32-48"/>
		<property name="DetectedMCLK" value="256"/>
		<property name="DetectedSCLK" value="64"/>
		<property name="GangAB" value="True"/>
		<property name="Mute" value="False"/>
		<property name="Reset" value="0.0"/>
		<property name="SDOUT" value="0.0"/>
		<property name="Shutdown" value="0.0"/>
		<property name="Standby" value="False"/>
		<property name="VolA" value="8.5"/>
		<property name="VolAdvDownSpeed" value="1"/>
		<property name="VolAdvDownStep" value="1"/>
		<property name="VolAdvErrorDownSpeed" value="1"/>
		<property name="VolAdvErrorDownStep" value="4"/>
		<property name="VolAdvGangAutoMute" value="True"/>
		<property name="VolAdvLeftAutoMute" value="True"/>
		<property name="VolAdvRightAutoMute" value="True"/>
		<property name="VolAdvUpSpeed" value="1"/>
		<property name="VolAdvUpStep" value="1"/>
		<property name="VolB" value="8.5"/>
	</component>
	<component name="HF1SmoothClip">
	</component>
	<component name="HF3DBEBQHIGH">
		<property name="I2CAddress1" value="108"/>
		<property name="I2CAddress2" value="113"/>
	</component>
	<component name="HF2DDEBQSENSE">
		<property name="I2CAddress1" value="209"/>
		<property name="I2CAddress2" value="214"/>
		<property name="Inst1_A1" value="0.49446737766265869140625"/>
		<property name="Inst1_B0" value="0.99446737766265869140625"/>
		<property name="Inst1_B1" value="-0.49723362922668457031250"/>
		<property name="Inst1_Bandwidth" value="160.0"/>
		<property name="Inst1_CornerFrequency" value="85.0"/>
		<property name="Inst2_A1" value="0.13400959968566894531250"/>
		<property name="Inst2_B0" value="0.36599028110504150390625"/>
		<property name="Inst2_B1" value="0.18299520015716552734375"/>
		<property name="Inst2_CornerFrequency" value="7999.0"/>
		<property name="LowerSensing" value="85.0"/>
		<property name="UpperSensing" value="7999.0"/>
	</component>
	<component name="ErrorHandlingStereo">
	</component>
	<component name="DeviceIOConfigMono">
		<property name="Input" value="SerialAudio"/>
		<property name="Sdout" value="0"/>
	</component>
	<component name="HF1BQComposite">
		<property name="ComponentList" value="HF1BQLow,HF1BQMid,HF1BQHigh"/>
		<property name="MixerName" value="HF1DRCMixer"/>
	</component>
	<component name="HF5MonoSmoothClip">
	</component>
	<component name="HF4DRCMixer">
		<property name="I2CAddress" value="20"/>
	</component>
	<component name="DeviceClockingStereo">
		<property name="AutoDetect" value="True"/>
	</component>
	<component name="HF1DBEBQHIGH">
	</component>
	<component name="HF2FineVolume">
	</component>
	<component name="HF1BQMid">
		<property name="I2CAddress1" value="199"/>
		<property name="I2CAddress2" value="204"/>
		<property name="Inst2_B0" value="0.9376068115234375"/>
		<property name="Inst2_B1" value="-0.9376068115234375"/>
		<property name="Inst2_B2" value="0.9376068115234375"/>
	</component>
	<component name="HF7BQROM1">
	</component>
	<component name="HF1DBE">
	</component>
	<component name="HF2DRC1">
	</component>
	<component name="HF7BQMid">
		<property name="I2CAddress1" value="100"/>
		<property name="I2CAddress2" value="105"/>
		<property name="Inst1_B0" value="0.9376068115234375"/>
		<property name="Inst1_B1" value="-0.9376068115234375"/>
		<property name="Inst1_B2" value="0.9376068115234375"/>
		<property name="Inst2_A1" value="0.66817843914031982421875"/>
		<property name="Inst2_A2" value="-0.4464626312255859375"/>
	</component>
	<component name="HF4SmoothClip">
	</component>
	<component name="DeviceIOConfigStereo">
	</component>
	<component name="HF2BQHigh">
		<property name="I2CAddress1" value="194"/>
	</component>
	<component name="HF6BQROM1">
		<property name="I2CAddress1" value="96"/>
		<property name="I2CAddress10" value="141"/>
		<property name="I2CAddress2" value="101"/>
		<property name="I2CAddress3" value="106"/>
		<property name="I2CAddress4" value="111"/>
		<property name="I2CAddress5" value="116"/>
		<property name="I2CAddress6" value="121"/>
		<property name="I2CAddress7" value="126"/>
		<property name="I2CAddress8" value="131"/>
		<property name="I2CAddress9" value="136"/>
		<property name="Inst1_A1" value="0.4993457794189453125"/>
		<property name="Inst1_B0" value="0.9993457794189453125"/>
		<property name="Inst1_B1" value="-0.49967288970947265625"/>
		<property name="Inst10_A1" value="0.499672857810604"/>
		<property name="Inst10_B0" value="0.999672857810604"/>
		<property name="Inst10_B1" value="-0.499836428905302"/>
		<property name="Inst10_Bandwidth" value="0.0"/>
		<property name="Inst2_A1" value="0.99895170659208"/>
		<property name="Inst2_A2" value="-0.997907795084684"/>
		<property name="Inst2_B0" value="1"/>
		<property name="Inst2_B1" value="-0.99895170659208"/>
		<property name="Inst2_B2" value="0.997907795084684"/>
		<property name="Inst3_A1" value="0.997901224537865"/>
		<property name="Inst3_A2" value="-0.995819958342083"/>
		<property name="Inst3_B0" value="1"/>
		<property name="Inst3_B1" value="-0.997901224537865"/>
		<property name="Inst3_B2" value="0.995819958342083"/>
		<property name="Inst4_A1" value="0.995793712931855"/>
		<property name="Inst4_A2" value="-0.991657316547624"/>
		<property name="Inst4_B0" value="1"/>
		<property name="Inst4_B1" value="-0.995793712931855"/>
		<property name="Inst4_B2" value="0.991657316547624"/>
		<property name="Inst5_A1" value="0.991752203141535"/>
		<property name="Inst5_A2" value="-0.983769957876585"/>
		<property name="Inst5_B0" value="1"/>
		<property name="Inst5_B1" value="-0.991752203141535"/>
		<property name="Inst5_B2" value="0.983769957876585"/>
		<property name="Inst6_A1" value="0.983372752327295"/>
		<property name="Inst6_A2" value="-0.967799088930799"/>
		<property name="Inst6_B0" value="1"/>
		<property name="Inst6_B1" value="-0.983372752327295"/>
		<property name="Inst6_B2" value="0.967799088930799"/>
		<property name="Inst7_A1" value="0.96622789700423"/>
		<property name="Inst7_A2" value="-0.936602207992062"/>
		<property name="Inst7_B0" value="1"/>
		<property name="Inst7_B1" value="-0.96622789700423"/>
		<property name="Inst7_B2" value="0.936602207992062"/>
		<property name="Inst7_FilterSubType" value="ButterWorth 1"/>
		<property name="Inst8_A1" value="0.93045933457688"/>
		<property name="Inst8_A2" value="-0.876976462992757"/>
		<property name="Inst8_B0" value="1"/>
		<property name="Inst8_B1" value="-0.93045933457688"/>
		<property name="Inst8_B2" value="0.876976462992757"/>
		<property name="Inst9_A1" value="0.853553390593275"/>
		<property name="Inst9_A2" value="-0.76732698797896"/>
		<property name="Inst9_B0" value="1"/>
		<property name="Inst9_B1" value="-0.853553390593275"/>
		<property name="Inst9_B2" value="0.76732698797896"/>
	</component>
	<component name="HF5DRC1">
	</component>
	<component name="HF5SmoothClip">
	</component>
	<component name="HF4DBE">
		<property name="I2CAddress1" value="82"/>
	</component>
	<component name="HF5DRCMixer">
		<property name="I2CAddress" value="25"/>
	</component>
	<component name="HF3PBE">
		<property name="HPF" value="180"/>
		<property name="I2CAddress2" value="3"/>
		<property name="I2CAddress3" value="227"/>
	</component>
	<component name="HF6DBEBQSENSE">
		<property name="I2CAddress1" value="25"/>
		<property name="Inst1_A1" value="0.98956811428070068359375"/>
		<property name="Inst1_A2" value="-0.9792721271514892578125"/>
		<property name="Inst1_B0" value="0.0103638172149658203125"/>
		<property name="Inst1_B2" value="-0.0103638172149658203125"/>
		<property name="Inst1_FilterType" value="Band Pass"/>
		<property name="UpperSensing" value="200.0"/>
	</component>
	<component name="HF6BQMid">
	</component>
	<component name="HF5BQROM1">
	</component>
	<component name="HF7MonoDRC1">
	</component>
	<component name="HF4FineVolume">
	</component>
	<component name="HF3DRCMixer">
		<property name="Gain2" value="0.999999880791"/>
		<property name="Gain3" value="-0.999999880791"/>
		<property name="I2CAddress" value="38"/>
	</component>
	<component name="HF3DRC1">
		<property name="I2CAddress1" value="118"/>
	</component>
	<component name="HF2DBEBQLOW">
		<property name="I2CAddress1" value="133"/>
		<property name="I2CAddress2" value="138"/>
		<property name="Inst1_FilterSubType" value="ButterWorth 2"/>
	</component>
	<component name="HF2DBEBQSENSE">
		<property name="I2CAddress1" value="146"/>
		<property name="Inst1_A1" value="0.98956823348999023437500"/>
		<property name="Inst1_A2" value="-0.97927224636077880859375"/>
		<property name="Inst1_B0" value="0.01036381721496582031250"/>
		<property name="Inst1_B2" value="-0.01036381721496582031250"/>
		<property name="Inst1_Bandwidth" value="160"/>
		<property name="Inst1_CornerFrequency" value="120"/>
	</component>
	<component name="HF1DBEBQLOW">
		<property name="Inst1_Bandwidth" value="60.0"/>
		<property name="Inst1_CornerFrequency" value="100.0"/>
		<property name="Inst1_Gain" value="18.0"/>
		<property name="Inst2_CornerFrequency" value="70.0"/>
		<property name="Inst2_Gain" value="9.0"/>
	</component>
	<component name="HF5SGBQ">
		<property name="I2CAddress1" value="12"/>
		<property name="Inst1_A1" value="0.4951150417327880859375"/>
		<property name="Inst1_B0" value="0.0048847198486328125"/>
		<property name="Inst1_B1" value="0.00244235992431640625"/>
		<property name="Inst1_CornerFrequency" value="300.0"/>
	</component>
	<component name="HF6BQHigh">
	</component>
	<component name="HF6SmoothClip">
	</component>
	<component name="HF2BQMid">
	</component>
	<component name="HF2BQLow">
	</component>
	<component name="HF1PBE">
		<property name="I2CAddress1" value="151"/>
		<property name="I2CAddress2" value="152"/>
		<property name="I2CAddress3" value="209"/>
	</component>
	<component name="DeviceClockingMono">
	</component>
	<component name="HF7MonoBQLow">
	</component>
	<component name="RightPanelControlMono">
		<property name="DetectedMCLK" value="0"/>
		<property name="DetectedSCLK" value="0"/>
		<property name="GangCAB" value="False"/>
		<property name="GangCABOffset" value="0.0"/>
		<property name="Standby" value="True"/>
		<property name="VolC" value="0.0"/>
	</component>
	<component name="HF6DRC1">
	</component>
	<component name="AudioAmpConfigStereo">
		<property name="GangControls" value="False"/>
		<property name="SerialAudioWordLength" value="3"/>
	</component>
	<component name="HF4BQROM1">
		<property name="I2CAddress1" value="85"/>
		<property name="I2CAddress2" value="90"/>
		<property name="I2CAddress3" value="95"/>
		<property name="I2CAddress4" value="100"/>
		<property name="I2CAddress5" value="105"/>
		<property name="Inst5_Bandwidth" value="1000.0"/>
		<property name="Inst5_CornerFrequency" value="1000.0"/>
		<property name="Inst5_Gain" value="4.0"/>
	</component>
	<component name="HF1DBEBQSENSE">
	</component>
	<component name="HF5MonoDRCMixer">
	</component>
	<component name="HF3SmoothClip">
	</component>
	<component name="HF7MonoBQMid">
	</component>
	<component name="HF7SmoothClip">
	</component>
	<component name="HF1BQHigh">
	</component>
	<component name="HF7MonoBQHigh">
	</component>
	<component name="HF7MonoDRCMixer">
	</component>
	<component name="HF7BQHigh">
	</component>
	<component name="HF4DBEBQSENSE">
		<property name="I2CAddress2" value="30"/>
		<property name="Inst1_A1" value="0.49738872051239013671875"/>
		<property name="Inst1_B0" value="0.9973886013031005859375"/>
		<property name="Inst1_B1" value="-0.49869430065155029296875"/>
		<property name="Inst1_CornerFrequency" value="40.0"/>
	</component>
</properties>
Jay
I must admit that I have zero experience with TI’s purepath software, but I guess that you’ll have to take that XML information and recode everything manually as I2C command sequence. The Data and Register structure should be documented in the PCM1542 datasheet starting with page 68.
According to a TI forum post there is a PCM512x driver that is register map compatible with the PCM5242. Maybe this will help me.
https://github.com/raspberrypi/linux/tree/linux_stable/sound/soc/codecs
- pcm512x-i2c.c
- pcm512x-spi.c
- pcm512x.c
- pcm512x.h
Doesn't look like there are any PCM5242 specific drivers in the Linux kernel. I believe most implementations are using this PCM512x driver to operate it. Some users on forums complain about the lack of a specific PCM5242 driver. I don't see anything else on the web that would help.
Because curious minds wanted to know...
My code was very simple.
// Code taken from
// Advanced Microcontroller-based Audio Workshop
// http://www.pjrc.com/store/audio_tutorial_kit.html
// https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
// Part 2-4: Using The Microphone
// Modified by JayShoe for "My First Audio Mixer"
// Works with the examples in the forum with the PCM5102a and PCM1808
// Drivers need to be developed for PCM5242 and PCM1865.
// copy the Design Tool code here
AudioInputI2S            i2s1;           //xy=116,243.99999237060547
AudioInputUSB            usb1;           //xy=125,154.99999237060547
AudioAmplifier           amp1;           //xy=184,364.99999237060547
AudioMixer4              mixer1;         //xy=268.00001525878906,262.0000114440918
AudioMixer4              mixer3;         //xy=500,273.99999237060547
AudioMixer4              mixer2;         //xy=506.00001525878906,395.00001525878906
AudioOutputI2S           i2s2;           //xy=684,361.99999237060547
AudioConnection          patchCord1(i2s1, 0, mixer1, 0);
AudioConnection          patchCord2(i2s1, 1, mixer1, 1);
AudioConnection          patchCord3(usb1, 0, mixer3, 2);
AudioConnection          patchCord4(usb1, 1, mixer2, 2);
AudioConnection          patchCord5(amp1, 0, mixer3, 0);
AudioConnection          patchCord6(amp1, 0, mixer2, 0);
AudioConnection          patchCord7(mixer1, amp1);
AudioConnection          patchCord8(mixer3, 0, i2s2, 0);
AudioConnection          patchCord9(mixer2, 0, i2s2, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=217,124.99999237060547
  AudioMemory(256);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.9);
  sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
  sgtl5000_1.micGain(0);
  amp1.gain(1.0);
  mixer1.gain(0, 0.5);
  mixer1.gain(1, 0.5);
  mixer1.gain(2, 0.0);
  mixer1.gain(3, 0.0);
  mixer2.gain(0, 0.3);
  mixer2.gain(1, 0.0);
  mixer2.gain(2, 0.1);
  mixer2.gain(3, 0.0);
  mixer3.gain(0, 0.3);
  mixer3.gain(1, 0.0);
  mixer3.gain(2, 0.1);
  mixer3.gain(3, 0.0);
  // do nothing
  /* print a summary of the current & maximum usage
  Serial.print("CPU: ");
  Serial.print("all=");
  Serial.print(AudioProcessorUsage());
  Serial.print(",");
  Serial.print(AudioProcessorUsageMax());
  Serial.print("    ");
  Serial.print("Memory: ");
  Serial.print(AudioMemoryUsage());
  Serial.print(",");
  Serial.print(AudioMemoryUsageMax());
  // Serial.print("    ");
  // Serial.print("Send: (R)eset, (S)lower, (F)aster");
  // very simple timing   :-)
And here is the design tool image:
Simply mix the two "mics" (two channels coming in through I2S). Then mix the stereo output of the USB Audio with the two inputs, then output to the DAC. I also tested this with reverb (on the mixed mic signal), and it also sounded great.
Ultimately I'm going to want to control each mixer for my project via USB. One concept is to do it using Open Sound Control protocol, MIDI, HID, or otherwise. So once this all works there will still be a lot of work to get it actually doing what I want it to do. :)
I'm just sharing this because someone asked me about it.
I'm in need of some help.
I have a single I2S input and a I2S output (as coded in my previous post). Now I'm trying to add a PCM1865. This ADC utilizes TDM to accept the 4 channel inputs. I keep the output as a single I2S line, but I change the input to a TDM to handle this. As soon as I add the TDM input the output starts sounding horrible.
So, will I need to run both the ADC and DAC in TDM mode in order to make this work? Is mixed mode (I2S output but TDM input) not supported?
Code below has commented lines on the TDM input and wires. It works... As soon as you uncomment those 5 lines the code no longer works. Thanks for the help!
// Code taken from
//AudioInputTDM            tdm1;           //xy=96,676
AudioInputUSB            usb1;           //xy=253,228
AudioAmplifier           amp1;           //xy=312,438
AudioMixer4              mixer1;         //xy=345,606
AudioMixer4              mixer3;         //xy=628,347
AudioMixer4              mixer2;         //xy=634,469
AudioOutputI2S           i2s2;           //xy=812,435
//AudioConnection          patchCord1(tdm1, 0, mixer1, 0);
//AudioConnection          patchCord2(tdm1, 1, mixer1, 1);
//AudioConnection          patchCord3(tdm1, 2, mixer1, 2);
//AudioConnection          patchCord4(tdm1, 3, mixer1, 3);
AudioConnection          patchCord5(usb1, 0, mixer3, 2);
AudioConnection          patchCord6(usb1, 1, mixer2, 2);
AudioConnection          patchCord7(amp1, 0, mixer3, 0);
AudioConnection          patchCord8(amp1, 0, mixer2, 0);
AudioConnection          patchCord9(mixer1, amp1);
AudioConnection          patchCord10(mixer3, 0, i2s2, 0);
AudioConnection          patchCord11(mixer2, 0, i2s2, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=345,198
  AudioMemory(256);
  //amp1.gain(1.0);
  mixer1.gain(0, 0.3);
  mixer1.gain(1, 0.3);
  mixer1.gain(2, 0.3);
  mixer1.gain(3, 0.3);
  // do nothing
  Serial.print(",");
  Serial.print("    ");
  Serial.print(",");
A graphic from the audio tool:
Mixing I2S & TDM is not supported.
Someday I want to make the design tool aware of which objects use which physical hardware resources, and which of those are sharable and which are mutually exclusive. But that's a complex project and it's been a relatively low priority.
To be a bit more specific, TDM actually uses the I2S hardware, but it configures the hardware quite differently using higher clock speeds.
@JayShoe could you please help me out a bit?
I'm expecting the same DAC boards and almost the same ADC boards (I've ordered PCM1802 boards which seem to be similar to PCM1808 in the provided connectivity options, but seem a little bit better from the specs perspective).
Thanks for pointing the connection scheme out and giving me hope that my idea might have a chance to work. It's just looking at the Teensy 3.6 pinout I am a bit confused with matching it to your scheme. For example BCK = BCK (9), DIN = TX (22), LCK = LCRLK (23). For the pin 9 I see CS0/RX2/PWM (not BCK), for the pin 22 I see A8/PWM/Touch (not TX).
Also I am going to have two ADC and two DAC boards connected at the same time (the plan is to use quad channel), it would have been fantastic if you can provide some guidance to connecting all four, if possible.
Yep, it took me a long time to figure out the jargon. There are many ways engineers call the pins. TX is "Transmit Line" because it sends a signal to wherever it's connected. RX is "Receive Line" because it receives whatever it is you are sending. DIN is "Digital Input" and DOUT is "Digital Output". Both descriptions are referring to similar functions. They are either sending or receiving serial data. You need to make sure you connect things in the right direction. Most of the time engineers speak directions in the perspective of the "DSP". Audio coming out of the DSP is transmitted, audio coming into the DSP is received. The ADC is transmitting. The DAC is receiving.
There are some other confusing references throughout datasheets and schematics referencing "Bitclock", "Worldclock", Etc. But usually it can be figured out be elimination. You'll see BCK, BK, WS, MK, MCL, etc... Don't get too caught up with exact names, study the I2S protocol and then determine what the engineer is talking about that way.
Using all of the same equipment in this thread I did in fact connect more than one DAC to the same line to play the exact same thing on both... You won't be able to use two ADCs on the same line. That will need to be connected to the 2nd TX/RX lines. This won't be an issue either, I think my table shows the two separate lines. You should be OK to do what you are doing.
Update: I figured it out.
PCM5102A / Teensy 3.6
VCC = Vin
3.3v = NC
GND = GND
FLT = GND
SCL = GND (also works connected to 11 /MCL)
BCK = BCK (9)
DIN = TX (22)
LCK = LCRLK (23)
FMT = GND
XMT = 3.3V (HIGH)
There is a noticeable difference in sound quality over my PC port or audio shield.
And now I'm going to work on getting the ADC working. I'll post my results when I know.
Hey Jay,
Just checking, but it looks from your pic and the schematic in it as if DMP is also tied to ground? I have one of these in the mail, so can't experiment yet to confirm.
According to the PCM5102(A) data sheet, DMP must be tied low to switch the deemphasis off. Only very few CDs, mostly produced in Japan in the early 1980s need activated deemphasis and they communicated about that in the data stream header.
For today's digital audio use, the deemphasis has no practical use and remains always off. Enabling it without need will make the sound less brilliant or even muffled.
@JayShoe, just wanted to thank you again! I've received the devices and it seems to work (except for the quad channel input but I'll create another topic about it as it seems to be a bug).
Hello hoho,
I'm happy this is helpful. I don't know that I have ever completed testing the quad channel inputs. I decided to go straight to the TDM format and work on the PCM5242 and PCM1865 chips. They both have TDM.
Here is a picture of my Teensy Audio Bridge I've ordered so i can test my new ADC/DAC card with the teensy more easily. This is just a prototype/test. It's the easiest way to group up the I2C/I2S lines into a simple IDE ribbon. I'm going to keep the ribbon short for testing my new PCM5242/PCM1865 board (no sneak peeks on the ADC/DAC PCB). For future releases of the Teensy Bridge I plan on adding some "clock distribution" circuits, but I need to test them to make sure they work first (conversation here: https://www.diyaudio.com/forums/dig...c-jitter-correction-ic-clock-distibution.html). Any comments on clock distribution and I2C distribution are appreciated!
Currently I can confirm that the PCM5242 works with the Teensy. I used a development board and it worked great. Sounds great. But then when i started toying with the PCM1865 module I realized that my connections were sloppy and loose connections were making it very difficult to confirm whether it works or not.... So I went straight to PCB. Very excited to plug it all in and start testing it.
This looks great. Would you mind sharing Gerber files?
My context is: building a 8 channel, simmultanious 24bit, 96kHz, ADC to Ethernet bridge.
Ultimat3ly I want to use the ADS1278 ADC, but if a couple of PCM1808 work, that will be fine too.
I got the ADC working now too on my project. It's a PCM1808 module, another cheap board from ebay.
Just to confirm, I'm using this board and it REALLY IS necessary to hook the 3.3 up to the teensy 3.3, which is really not intuitive. Basically, JayShoe's instructions should be followed exactly. I tried using the datasheet to hook up one of these boards and I never thought I needed to supply both 5.0 and 3.3 - until I looked at the board and saw no voltage regulator. Paul has said elsewhere that the 1802's 3.3V is an output - but the 1808 is different, and really needs both voltages supplied.
<headsmack/>
