Here is a fourth beta test for Teensyduino 1.42.
The main new feature is a "Teensy" section in the Tools > Ports menu
which tries to show Teensy in all modes, not just Serial. New native
(no Java serial library) serial monitor code is also with these ports.
Changes since Teensyduino 1.42-beta3
Teensy 3.5 now supports use of 256K RAM
EthernetClient fix for forced connection close
Small speedup to analogWrite for DAC pins
Fix DMAChannel transferSize() on Teensy LC
Fix FTM_CONF register bitfield defs
Update ADC library (Pedro Villanueva)
Audio: Add freeverb mono & stereo
Audio: Granular pitch shift & freeze effects (Bleep Labs)
Audio: envelope status functions
Audio: Fixes to waveform object
Audio: Add variable triangle waveform
Audio: Add modulated waveform, support for freq & phase modulation
Audio: Add simple amp/switch object
Audio: Add PDM input
Update OneWire, very minor changes
PS2Keyboard: add UK & Spanish layouts
TimeAlarms: minor fixes
USBHost_t36: Joystick fixes (KurtE)
Macintosh build now uses 64 bits
