I put together a library that allows GDB (included in Teensyduino) to perform source-level debugging on the Teensy without debugging hardware (no need for JTAG, SWD, etc). It uses GDB's Remote Serial Protocol to communicate with Teensy over a Serial connection (physical or USB). No extra hardware or software is required.
This is a beta release for comments and testing. It works on Teensy 4. Tested primarily on Mac.
See https://forum.pjrc.com/threads/61262-Sleeping-to-disable-C_DEBUGEN?p=243070&posted=1#post243070 for previous discussion and this for background: https://forum.pjrc.com/threads/26358-Software-Debugger-Stack.
Highlights:
* Set/remove breakpoints at runtime in most places in your code
* Examine and change memory and registers
* View call stack
* Halt code at any time
* Next/step one instruction at a time
Since real breakpoints are permanently disabled on the Teensy, in order to emulate breakpoints the library uses the SVC interrupt (like I did in TeensyThreads). Since Teensy 4 places most code in RAM, activating a breakpoint replaces the original instructions with SVC calls (and puts the original back later). On Teensy 3.2, setting breakpoints uses the Cortex-M4's features to "patch" parts of flash by pointing it to RAM.
The library is enabled by including a header, `TeensyDebug.h`. There is a program that adds a menu option that configures Arduino to open GDB automatically after uploading your program. You can also run GDB manually and use `target remote` to connect to the serial port used by the GDB interface.
To read more and try it out visit: http://github.com/ftrias/TeensyDebug
Any comments or code would be greatly appreciated!
Highlights:
* View call stack
