# Generated by VisualTeensy (https://github.com/luni64/VisualTeensy)
# Board Teensy 4.1
# USB Type Dual Serial
# CPU Speed 600 MHz
# Optimize Debug
# Keyboard Layout US English
# 2021/08/01 12:18
SHELL := cmd.exe
export SHELL
TARGET_NAME := MyApp
BOARD_ID := TEENSY41
MCU := imxrt1062
LIBS_SHARED_BASE := C:\Users\tviljoen\Documents\Arduino\libraries
LIBS_SHARED :=
LIBS_LOCAL_BASE := lib
LIBS_LOCAL := Audio SD SerialFlash SPI Wire TeensyDebug
CORE_BASE := C:\Technical\Teensy\arduino-1.8.13_1.53\hardware\teensy\avr\cores\teensy4
GCC_BASE := C:\Technical\Teensy\arduino-1.8.13_1.53\hardware\tools\arm\bin
UPL_PJRC_B := C:\Technical\Teensy\arduino-1.8.13_1.53\hardware\tools
UPL_TYCMD_B := C:\Technical\Teensy\arduino-1.8.13_1.53\hardware\tools
# Flags and Defines
FLAGS_CPU := -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16
FLAGS_OPT := -Og
FLAGS_COM := -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD
FLAGS_LSP :=
FLAGS_CPP := -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing
FLAGS_C :=
FLAGS_S := -x assembler-with-cpp
FLAGS_LD := -Wl,--print-memory-usage,--gc-sections,--relax,--defsym=__rtc_localtime=$(shell powershell [int](Get-Date -UFormat +%s)[0]) -T$(CORE_BASE)/imxrt1062_t41.ld
LIBS := -larm_cortexM7lfsp_math -lm -lstdc++
DEFINES := -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO_TEENSY41 -DARDUINO=10813
DEFINES += -DF_CPU=600000000 -DUSB_DUAL_SERIAL -DLAYOUT_US_ENGLISH
CPP_FLAGS := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_CPP)
C_FLAGS := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_C)
S_FLAGS := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_COM) $(DEFINES) $(FLAGS_S)
LD_FLAGS := $(FLAGS_CPU) $(FLAGS_OPT) $(FLAGS_LSP) $(FLAGS_LD)
AR_FLAGS := rcs
NM_FLAGS := --numeric-sort --defined-only --demangle --print-size
# Colors
COL_CORE := [38;2;187;206;251m
COL_LIB := [38;2;206;244;253m
COL_SRC := [38;2;100;149;237m
COL_LINK := [38;2;255;255;202m
COL_ERR := [38;2;255;159;159m
COL_OK := [38;2;179;255;179m
COL_RESET := [0m
# Folders and Files
USR_SRC := src
LIB_SRC := lib
CORE_SRC := $(CORE_BASE)
BIN := .vsteensy/build
USR_BIN := $(BIN)/src
CORE_BIN := $(BIN)/core
LIB_BIN := $(BIN)/lib
CORE_LIB := $(BIN)/core.a
TARGET_HEX := $(BIN)/$(TARGET_NAME).hex
TARGET_ELF := $(BIN)/$(TARGET_NAME).elf
TARGET_LST := $(BIN)/$(TARGET_NAME).lst
TARGET_SYM := $(BIN)/$(TARGET_NAME).sym
# BINARIES
CC := $(GCC_BASE)/arm-none-eabi-gcc
CXX := $(GCC_BASE)/arm-none-eabi-g++
AR := $(GCC_BASE)/arm-none-eabi-gcc-ar
NM := $(GCC_BASE)/arm-none-eabi-gcc-nm
SIZE := $(GCC_BASE)/arm-none-eabi-size
OBJDUMP := $(GCC_BASE)/arm-none-eabi-objdump
OBJCOPY := $(GCC_BASE)/arm-none-eabi-objcopy
UPL_PJRC := "$(UPL_PJRC_B)/teensy_post_compile" -test -file=$(TARGET_NAME) -path=$(BIN) -tools="$(UPL_PJRC_B)" -board=$(BOARD_ID) -reboot
UPL_TYCMD := $(UPL_TYCMD_B)/tyCommanderC upload $(TARGET_HEX) --autostart --wait --multi
UPL_CLICMD := $(UPL_CLICMD_B)/teensy_loader_cli -mmcu=$(MCU) -v $(TARGET_HEX)
UPL_JLINK := $(UPL_JLINK_B)/jlink -commanderscript .vsteensy/flash.jlink
# Source and Include Files
# Recursively create list of source and object files in USR_SRC and CORE_SRC
# and corresponding subdirectories.
# The function rwildcard is taken from http://stackoverflow.com/a/12959694)
rwildcard =$(wildcard $1$2) $(foreach d,$(wildcard $1*),$(call rwildcard,$d/,$2))
#User Sources -----------------------------------------------------------------
USR_C_FILES := $(call rwildcard,$(USR_SRC)/,*.c)
USR_CPP_FILES := $(call rwildcard,$(USR_SRC)/,*.cpp)
USR_S_FILES := $(call rwildcard,$(USR_SRC)/,*.S)
USR_OBJ := $(USR_S_FILES:$(USR_SRC)/%.S=$(USR_BIN)/%.o) $(USR_C_FILES:$(USR_SRC)/%.c=$(USR_BIN)/%.o) $(USR_CPP_FILES:$(USR_SRC)/%.cpp=$(USR_BIN)/%.o)
# Core library sources --------------------------------------------------------
CORE_CPP_FILES := $(call rwildcard,$(CORE_SRC)/,*.cpp)
CORE_C_FILES := $(call rwildcard,$(CORE_SRC)/,*.c)
CORE_S_FILES := $(call rwildcard,$(CORE_SRC)/,*.S)
CORE_OBJ := $(CORE_S_FILES:$(CORE_SRC)/%.S=$(CORE_BIN)/%.o) $(CORE_C_FILES:$(CORE_SRC)/%.c=$(CORE_BIN)/%.o) $(CORE_CPP_FILES:$(CORE_SRC)/%.cpp=$(CORE_BIN)/%.o)
# User library sources (see https://github.com/arduino/arduino/wiki/arduino-ide-1.5:-library-specification)
LIB_DIRS_SHARED := $(foreach d, $(LIBS_SHARED), $(LIBS_SHARED_BASE)/$d/ $(LIBS_SHARED_BASE)/$d/utility/) # base and /utility
LIB_DIRS_SHARED += $(foreach d, $(LIBS_SHARED), $(LIBS_SHARED_BASE)/$d/src/ $(dir $(call rwildcard,$(LIBS_SHARED_BASE)/$d/src/,*/.))) # src and all subdirs of base
LIB_DIRS_LOCAL := $(foreach d, $(LIBS_LOCAL), $(LIBS_LOCAL_BASE)/$d/ $(LIBS_LOCAL_BASE)/$d/utility/ ) # base and /utility
LIB_DIRS_LOCAL += $(foreach d, $(LIBS_LOCAL), $(LIBS_LOCAL_BASE)/$d/src/ $(dir $(call rwildcard,$(LIBS_LOCAL_BASE)/$d/src/,*/.))) # src and all subdirs of base
LIB_CPP_SHARED := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.cpp))
LIB_C_SHARED := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.c))
LIB_S_SHARED := $(foreach d, $(LIB_DIRS_SHARED),$(call wildcard,$d*.S))
LIB_CPP_LOCAL := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.cpp))
LIB_C_LOCAL := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.c))
LIB_S_LOCAL := $(foreach d, $(LIB_DIRS_LOCAL),$(call wildcard,$d/*.S))
LIB_OBJ := $(LIB_CPP_SHARED:$(LIBS_SHARED_BASE)/%.cpp=$(LIB_BIN)/%.o) $(LIB_CPP_LOCAL:$(LIBS_LOCAL_BASE)/%.cpp=$(LIB_BIN)/%.o)
LIB_OBJ += $(LIB_C_SHARED:$(LIBS_SHARED_BASE)/%.c=$(LIB_BIN)/%.o) $(LIB_C_LOCAL:$(LIBS_LOCAL_BASE)/%.c=$(LIB_BIN)/%.o)
LIB_OBJ += $(LIB_S_SHARED:$(LIBS_SHARED_BASE)/%.S=$(LIB_BIN)/%.o) $(LIB_S_LOCAL:$(LIBS_LOCAL_BASE)/%.S=$(LIB_BIN)/%.o)
# Includes -------------------------------------------------------------
INCLUDE := -I./$(USR_SRC) -I$(CORE_SRC)
INCLUDE += $(foreach d, $(LIB_DIRS_SHARED), -I$d)
INCLUDE += $(foreach d, $(LIB_DIRS_LOCAL), -I$d)
# Generate directories --------------------------------------------------------
DIRECTORIES := $(sort $(dir $(CORE_OBJ) $(USR_OBJ) $(LIB_OBJ)))
generateDirs := $(foreach d, $(DIRECTORIES), $(shell if not exist "$d" mkdir "$d"))
#$(info dirs: $(DIRECTORIES))
# Rules:
.PHONY: directories all rebuild upload uploadTy uploadCLI clean cleanUser cleanCore
all: $(TARGET_LST) $(TARGET_SYM) $(TARGET_HEX)
rebuild: cleanUser all
clean: cleanUser cleanCore cleanLib
@echo $(COL_OK)cleaning done$(COL_RESET)
upload: all
@$(UPL_PJRC)
uploadTy: all
@$(UPL_TYCMD)
uploadCLI: all
@$(UPL_CLICMD)
uploadJLink: all
@$(UPL_JLINK)
# Core library ----------------------------------------------------------------
$(CORE_BIN)/%.o: $(CORE_SRC)/%.S
@echo $(COL_CORE)CORE [ASM] $(notdir $<) $(COL_ERR)
@"$(CC)" $(S_FLAGS) $(INCLUDE) -o $@ -c $<
$(CORE_BIN)/%.o: $(CORE_SRC)/%.c
@echo $(COL_CORE)CORE [CC] $(notdir $<) $(COL_ERR)
@"$(CC)" $(C_FLAGS) $(INCLUDE) -o $@ -c $<
$(CORE_BIN)/%.o: $(CORE_SRC)/%.cpp
@echo $(COL_CORE)CORE [CPP] $(notdir $<) $(COL_ERR)
@"$(CXX)" $(CPP_FLAGS) $(INCLUDE) -o $@ -c $<
$(CORE_LIB) : $(CORE_OBJ)
@echo $(COL_LINK)CORE [AR] $@ $(COL_ERR)
@$(AR) $(AR_FLAGS) $@ $^
@echo $(COL_OK)Teensy core built successfully &&echo.
# Shared Libraries ------------------------------------------------------------
$(LIB_BIN)/%.o: $(LIBS_SHARED_BASE)/%.S
@echo $(COL_LIB)LIB [ASM] $(notdir $<) $(COL_ERR)
$(LIB_BIN)/%.o: $(LIBS_SHARED_BASE)/%.cpp
@echo $(COL_LIB)LIB [CPP] $(notdir $<) $(COL_ERR)
@echo $(COL_LIB)LIB [CC] $(notdir $<) $(COL_ERR)
# Local Libraries -------------------------------------------------------------
$(LIB_BIN)/%.o: $(LIBS_LOCAL_BASE)/%.S
$(LIB_BIN)/%.o: $(LIBS_LOCAL_BASE)/%.cpp
# Handle user sources ---------------------------------------------------------
$(USR_BIN)/%.o: $(USR_SRC)/%.S
@echo $(COL_SRC)USER [ASM] $< $(COL_ERR)
@"$(CC)" $(S_FLAGS) $(INCLUDE) -o "$@" -c $<
$(USR_BIN)/%.o: $(USR_SRC)/%.c
@echo $(COL_SRC)USER [CC] $(notdir $<) $(COL_ERR)
@"$(CC)" $(C_FLAGS) $(INCLUDE) -o "$@" -c $<
$(USR_BIN)/%.o: $(USR_SRC)/%.cpp
@echo $(COL_SRC)USER [CPP] $(notdir $<) $(COL_ERR)
@"$(CXX)" $(CPP_FLAGS) $(INCLUDE) -o "$@" -c $<
# Linking ---------------------------------------------------------------------
$(TARGET_ELF): $(CORE_LIB) $(LIB_OBJ) $(USR_OBJ)
@echo $(COL_LINK)
@echo [LD] $@ $(COL_ERR)
@$(CC) $(LD_FLAGS) -o "$@" $(USR_OBJ) $(LIB_OBJ) $(CORE_LIB) $(LIBS)
@echo $(COL_OK)User code built and linked to libraries &&echo.
%.lst: %.elf
@echo [LST] $@
@$(OBJDUMP) -d -S --demangle --no-show-raw-insn "$<" > "$@"
@echo $(COL_OK)Sucessfully built project$(COL_RESET) &&echo.
%.sym: %.elf
@echo [SYM] $@
@$(NM) $(NM_FLAGS) "$<" > "$@"
%.hex: %.elf
@echo $(COL_LINK)[HEX] $@
@$(OBJCOPY) -O ihex -R.eeprom "$<" "$@"
# Cleaning --------------------------------------------------------------------
cleanUser:
@echo $(COL_LINK)Cleaning user binaries...$(COL_RESET)
@if exist $(USR_BIN) rd /s/q "$(USR_BIN)"
@if exist "$(TARGET_LST)" del $(subst /,\,$(TARGET_LST))
cleanCore:
@echo $(COL_LINK)Cleaning core binaries...$(COL_RESET)
@if exist $(CORE_BIN) rd /s/q "$(CORE_BIN)"
@if exist $(CORE_LIB) del $(subst /,\,$(CORE_LIB))
cleanLib:
@echo $(COL_LINK)Cleaning user library binaries...$(COL_RESET)
@if exist $(LIB_BIN) rd /s/q "$(LIB_BIN)"
# compiler generated dependency info ------------------------------------------
-include $(CORE_OBJ:.o=.d)
-include $(USR_OBJ:.o=.d)
-include $(LIB_OBJ:.o=.d)
