#include <ILI9341_t3ns_font_Arial.h>
#include <ILI9341_t3ns_font_ArialBold.h>
#include <ILI9341_t3ns.h>
#include "SPI.h"
//#define KURTS_FLEXI
#ifdef KURTS_FLEXI
#define TFT_DC 22
#define TFT_CS 15
#define TFT_RST -1
#define TFT_SCK 14
#define TFT_MISO 12
#define TFT_MOSI 7
#define DEBUG_PIN 13
#else
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 7
#define TFT_SCK 13
#define TFT_MISO 12
#define TFT_MOSI 11
ILI9341_t3ns tft = ILI9341_t3ns(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
Adafruit_GFX_Button button;
uint8_t use_dma = 0;
uint8_t use_clip_rect = 0;
uint8_t use_set_origin = 0;
uint8_t use_fb = 0;
#define ORIGIN_TEST_X 50
#define ORIGIN_TEST_Y 50
while (!Serial && (millis() < 4000)) ;
tft.begin();
tft.setRotation(3);
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(ILI9341_RDMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDPIXFMT);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDIMGFMT);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDSELFDIAG);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
#ifdef DEBUG_PIN
pinMode(DEBUG_PIN, OUTPUT);
button.initButton(&tft, 200, 125, 100, 40, ILI9341_GREEN, ILI9341_YELLOW, ILI9341_RED, "UP", 1);
drawTestScreen();
void SetupOrClearClipRectAndOffsets() {
if (use_clip_rect) {
tft.setClipRect(); // make sure we clear the whole screen
tft.setOrigin(); // make sure none are set yet
tft.fillScreen(ILI9341_LIGHTGREY);
// Now lets set origin.
if (use_set_origin)
tft.setOrigin(ORIGIN_TEST_X, ORIGIN_TEST_Y);
int x = tft.width() / 4;
int y = tft.height() / 4;
int w = tft.width() / 2;
int h = tft.height() / 2;
tft.drawRect(x, y, w, h, ILI9341_ORANGE);
tft.updateScreen();
tft.setClipRect(x + 1, y + 1, w - 2, h - 2);
delay(250);
tft.setClipRect();
if (use_set_origin)
tft.setOrigin();
uint16_t palette[256]; // Should probably be 256, but I don't use many colors...
uint16_t pixel_data[2500];
const uint8_t pict1bpp[] = {0xff, 0xff, 0xc0, 0x03, 0xa0, 0x05, 0x90, 0x9, 0x88, 0x11, 0x84, 0x21, 0x82, 0x41, 0x81, 0x81,
0x81, 0x81, 0x82, 0x41, 0x84, 0x21, 0x88, 0x11, 0x90, 0x09, 0xa0, 0x05, 0xc0, 0x03, 0xff, 0xff
const uint8_t pict2bpp[] = {
0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff,
0x55, 0x55, 0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00,
0xaa, 0xaa, 0xff, 0xff, 0x00, 0x00, 0x55, 0x55,
0xff, 0xff, 0x00, 0x00, 0x55, 0x55, 0xaa, 0xaa,
const uint8_t pict4bpp[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x00,
0x00, 0x11, 0x22, 0x22, 0x22, 0x22, 0x11, 0x00,
0x00, 0x11, 0x22, 0x33, 0x33, 0x22, 0x11, 0x00,
void drawTestScreen() {
Serial.printf("Use FB: %d ", use_fb); Serial.flush();
tft.useFrameBuffer(use_fb);
SetupOrClearClipRectAndOffsets();
uint32_t start_time = millis();
tft.fillScreen(use_fb ? ILI9341_RED : ILI9341_BLACK);
//tft.setFont(Inconsolata_60);
tft.setFont(Arial_24_Bold);
tft.setTextColor(ILI9341_WHITE);
tft.setCursor(0, 0);
tft.println("Test");
tft.setTextColor(ILI9341_WHITE, ILI9341_RED);
tft.println("text");
tft.setCursor(85, 65);
tft.print("XYZ");
tft.setFontAdafruit();
tft.setTextSize(2);
tft.println("01234");
tft.setTextColor(ILI9341_WHITE, ILI9341_GREEN);
tft.println("56789!@#$%");
tft.drawRect(0, 150, 100, 50, ILI9341_WHITE);
tft.drawLine(0, 150, 100, 50, ILI9341_GREEN);
tft.fillRectVGradient(125, 150, 50, 50, ILI9341_GREEN, ILI9341_YELLOW);
tft.fillRectHGradient(200, 150, 50, 50, ILI9341_YELLOW, ILI9341_GREEN);
// Try a read rect and write rect
#ifdef DEBUG_PIN
digitalWrite(DEBUG_PIN, HIGH);
delay(5);
tft.readRect(0, 0, 50, 50, pixel_data);
#ifdef DEBUG_PIN
digitalWrite(DEBUG_PIN, LOW);
tft.writeRect(250, 0, 50, 50, pixel_data);
// Lets try to pack this rectangle of data into 8 byte
tft.readRect(85, 65, 50, 50, pixel_data);
uint16_t *ppd16 = pixel_data;
uint8_t *ppd8 = (uint8_t*)pixel_data;
uint8_t palette_cnt = 0;
int palette_index;
for (int i = 0; i < 2500; i++) {
for (palette_index = 0; palette_index < palette_cnt; palette_index++) {
if (*ppd16 == palette[palette_index])
if (palette_index >= palette_cnt) {
palette[palette_cnt++] = *ppd16; // save away the color
*ppd8++ = palette_index;
ppd16++;
tft.writeRect8BPP(200, 50, 50, 50, (uint8_t*)pixel_data, palette);
palette[0] = ILI9341_CYAN;
palette[1] = ILI9341_OLIVE;
tft.writeRect1BPP(75, 100, 16, 16, pict1bpp, palette);
tft.writeRect1BPP(320-90, 75, 16, 16, pict1bpp, palette);
palette[2] = ILI9341_MAROON;
palette[3] = ILI9341_PINK;
tft.writeRect2BPP(75, 125, 32, 16, pict2bpp, palette);
tft.writeRectNBPP(15, 125, 32, 16, 2, pict2bpp, palette);
tft.writeRectNBPP(75, 150, 16, 16, 4, pict4bpp, palette);
// Try drawing button
button.drawButton();
if (use_dma) {
tft.startUpdateScreenAsync();
tft.updateScreen();
Serial.println(millis() - start_time, DEC);
if (use_dma && use_fb) {
Serial.printf("DMA error status: %x\n", DMA_ES);
use_fb = use_fb ? 0 : 1 ;
Serial.println(use_fb, DEC);
void drawTextScreen(bool fOpaque) {
tft.setFont(Arial_40_Bold);
if (fOpaque)
tft.setTextColor(ILI9341_WHITE, use_fb ? ILI9341_BLACK : ILI9341_RED);
tft.setCursor(0, 5);
tft.println("AbCdEfGhIj");
tft.setFont(Arial_28_Bold);
tft.println("0123456789!@#$");
#if 1
tft.setFont(Arial_20_Bold);
tft.println("abcdefghijklmnopq");
tft.setFont(Arial_14_Bold);
tft.println("ABCDEFGHIJKLMNOPQRST");
tft.setFont(Arial_10_Bold);
tft.println("0123456789zyxwvutu");
tft.updateScreen();
Serial.printf("Use FB: %d OP: %d, DT: %d OR: %d\n", use_fb, fOpaque, use_set_origin, millis() - start_time);
// Try continuous update
void testDMAContUpdate() {
// Force frame buffer on
Serial.printf("continuous DMA udpate test - Frame mode on\n"); Serial.flush();
use_fb = 1; //
tft.fillScreen(ILI9341_GREEN);
tft.startUpdateScreenAsync(true);
uint32_t frame_count;
while ((frame_count = tft.frameCount()) < 10) yield();
tft.fillScreen(ILI9341_YELLOW);
while ((frame_count = tft.frameCount()) < 20) yield();
tft.fillScreen(ILI9341_RED);
while ((frame_count = tft.frameCount()) < 30) yield();
while ((frame_count = tft.frameCount()) < 40) yield();
tft.setCursor(0, 100);
tft.println("DONE");
tft.endUpdateScreenAsync();
Serial.println("Finished test");
void loop(void) {
// See if any text entered
int ich;
if ((ich = Serial.read()) != -1) {
while (Serial.read() != -1) delay(1);
if (ich == 'c') {
use_clip_rect = !use_clip_rect;
if (use_clip_rect) Serial.println("Clip Rectangle Turned on");
else Serial.println("Clip Rectangle turned off");
return;
if (ich == 'd') {
use_dma = !use_dma;
if (use_dma) Serial.println("DMA Turned on");
else Serial.println("DMA turned off");
return;
if (ich == 's') {
use_set_origin = !use_set_origin;
if (use_set_origin) Serial.printf("Set origin to %d, %d\n", ORIGIN_TEST_X, ORIGIN_TEST_Y);
else Serial.println("Clear origin");
return;
if (ich == 'o')
drawTextScreen(1);
else if (ich == 't')
drawTextScreen(0);
else if (ich == 'r') {
testDMAContUpdate();
drawTestScreen();
