#include <LiquidCrystal.h>
// Generate audio samples using AudioSynthWaveform, use
// AudioAnalyzeFFT256 to generate a spectrum and output
// it to the LCD or the serial monitor
2a
Typical output (where the frequency of 1723Hz was chosen because it
falls in the centre of a bin):
tone_freq = 1723, sine, amplitude = 0.0500, FFT = 16, Hanning
4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 820, 3, 0, 0, 0, 0, 0, 0, 0, ....
(all the rest to the right are zero)
// 1 = Display the spectrum on the LCD
// 0 = Print the spectrum on the Serial Monitor
const int LCD_DISPLAY = 0;
// Number of Spectra to average for one output of FFT
// and name of window to use (or NULL for the default)
int num_avg = 16;
const int16_t *window = NULL;
AudioAnalyzeFFT256 myFFT(num_avg,window);
// Allows the program to print info about the window being used
struct map_window_name {
const char *name;
const int16_t *array;
} map_win_name[] = {
// The first entry MUST be the default
{ "Hanning", AudioWindowHanning256},
{ "Bartlett", AudioWindowBartlett256},
{ "Blackman", AudioWindowBlackman256},
{ "Flattop", AudioWindowFlattop256},
{ "BlackmanHarris", AudioWindowBlackmanHarris256},
{ "Nuttall", AudioWindowNuttall256},
{ "BlackmanNuttall", AudioWindowBlackmanNuttall256},
{ "Welch", AudioWindowWelch256},
{ "Hamming", AudioWindowHamming256},
{ "Cosine", AudioWindowCosine256},
{ "Tukey", AudioWindowTukey256},
{ "Unknown", NULL},
// Map a window array address into its name
const char *window_name(const int16_t *ar)
int i;
if(ar == NULL)return(map_win_name[0].name);
for(i=0;map_win_name[i].array != NULL;i++) {
if(ar == map_win_name[i].array)return(map_win_name[i].name);
// Create the Audio components. These should be created in the
// order data flows, inputs/sources -> processing -> outputs
// Type of tone. SINE, SAWTOOTH, SQUARE or TRIANGLE
short type = TONE_TYPE_SINE;
#define TONE_FREQ 1723
#define TONE_LENGTH_MS 2000
#define SILENCE_LENGTH_MS 200
// Number of tones to send
int tone_count = 3;
// state of tone generator
int tone_state = 0;
// tone amplitude
float t_amp = 0.05;
char *wave_names[4] = {
"sine",
"sawtooth",
"square",
"triangle"
AudioSynthWaveform myEffect;
AudioOutputI2S audioOutput; // audio shield: headphones & line-out
// Send the synthesized tone to the FFT and to the left and
// right audio output channels
AudioConnection c1(myEffect, 0, audioOutput, 0);
AudioConnection c2(myEffect, 0, myFFT, 0);
AudioConnection c3(myEffect, 0, audioOutput, 1);
// Create an object to control the audio shield.
AudioControlSGTL5000 audioShield;
// Use the LiquidCrystal library to display the spectrum
// Define 8 special characters for the bar graph display
LiquidCrystal lcd( 2, 3, 4, 5, 6, 7, 8);
byte bar1[8] = {
0,0,0,0,0,0,0,255};
byte bar2[8] = {
0,0,0,0,0,0,255,255};
byte bar3[8] = {
0,0,0,0,0,255,255,255};
byte bar4[8] = {
0,0,0,0,255,255,255,255};
byte bar5[8] = {
0,0,0,255,255,255,255,255};
byte bar6[8] = {
0,0,255,255,255,255,255,255};
byte bar7[8] = {
0,255,255,255,255,255,255,255};
byte bar8[8] = {
255,255,255,255,255,255,255,255};
// Index of first bin to be displayed on the LCD
int start_index = 0;
// character blocks which display the spectrum
char blocks[2][17];
while(!Serial);
delay(2000);
// Audio connections require memory to work. For more
AudioMemory(12);
// Enable the audio shield and set the output volume.
audioShield.enable();
// audioShield.inputSelect(myInput);
audioShield.volume(60);
// I want output on the line out too
audioShield.unmuteLineout();
// audioShield.muteHeadphone();
blocks[0][16] = 0;
blocks[1][16] = 0;
lcd.begin(16, 2);
lcd.print("Audio Spectrum");
delay(2000);
lcd.createChar(0, bar1);
lcd.createChar(1, bar2);
lcd.createChar(2, bar3);
lcd.createChar(3, bar4);
lcd.createChar(4, bar5);
lcd.createChar(5, bar6);
lcd.createChar(6, bar7);
lcd.createChar(7, bar8);
myEffect.set_ramp_length(144);
// Start the tone generator with zero amplitude
myEffect.begin(t_amp,TONE_FREQ,type);
Serial.print("tone_freq = ");
Serial.print(TONE_FREQ);
Serial.print(", ");
Serial.print(wave_names[type]);
Serial.print(", amplitude = ");
Serial.print(t_amp,4);
Serial.print(", FFT = ");
Serial.print(num_avg);
Serial.print(", ");
Serial.println(window_name(window));
// Only need one tone when printing the results to
// the serial monitor
if(!LCD_DISPLAY)tone_count = 1;
// Map an amplitde to a special character
char cmap(int i)
if(i == 0)return(' ');
return(i-1);
// buffer and index for input from serial monitor
char tmp[128];
int idx = 0;
unsigned long last_time;
int log_mag;
int op;
char *p;
if(tone_count) {
switch(tone_state) {
case 0: // Start the tone generator and timer
myEffect.amplitude(t_amp);
last_time = millis();
// Wait for timer to expire
tone_state = 1;
case 1: // Wait for timer to expire
if(millis() - last_time < TONE_LENGTH_MS)break;
myEffect.amplitude(0);
// Now "send" silence
tone_state = 2;
case 2:
if(millis() - last_time < SILENCE_LENGTH_MS)break;
// count this tone and then reset for next one
tone_count--;
tone_state = 0;
if(LCD_DISPLAY) {
if(start_index < 0)start_index = 0;
if(start_index > 112)start_index = 112;
if (myFFT.available()) {
for(int i=0;i < 16;i++) {
op = myFFT.output[i+start_index];
if(op < 0)op = 0;
log_mag = 0;
while(op) {
log_mag++;
op >>= 1;
//sprintf(tmp,"%4d (%2d),",op,log_mag);
//Serial.print(tmp);
// log_mag = log(myFFT.output[i])/log(1.4);
if(log_mag > 8) {
blocks[1][i] = 7;
if(log_mag >= 16)blocks[0][i] = 7;
else blocks[0][i] = cmap(log_mag - 8);
else {
blocks[0][i] = ' ';
blocks[1][i] = cmap(log_mag);
//Serial.println("");
lcd.setCursor(0,0);
lcd.write(blocks[0],16);
lcd.setCursor(0,1);
lcd.write(blocks[1],16);
else {
if(tone_count) {
for(int i=0;i < 128;i++) {
Serial.print(myFFT.output[i]);
Serial.print(", ");
Serial.println("");
while(Serial.available() > 0) {
char c = Serial.read();
if((c != '\n') && (c != '\r')) {
tmp[idx++] = c;
if(idx >= 127) {
Serial.println("Error: line too long");
idx = 0;
continue;
tmp[idx] = 0;
if(idx == 0)continue;
idx = 0;
c = tmp[0];
p = &tmp[1];
while(*p && *p == ' ')p++;
if(*p == 0) {
idx = 0;
continue;
switch(tolower(c)) {
// By default the LCD display shows the first 16 bins.
// Typing the command 's N' where N is a number from
// 0 to 119 will display the 16 bins starting at index N
case 's':
start_index = atoi(p);
Serial.println(start_index);
// Volume control
float vol = analogRead(15);
vol = vol / 10.24;
audioShield.volume(vol);
