Lesept
Thanks to all your explanation, I finally understood how all this works!
Now I have a code that compiles and can create a file to store a large array, and read it afterwards.
The output is correct:
It take 520 ms to read 100 000 float values (53 ms for 10 000 and 2.7 ms for 100).
The array data is stored in PSRAM (using DMAMEM), which is 8 MB. It should be able to store float arrays up to 2000000 values. But when I increase the value of N (size of the array) to 300 000 I get this error message:
Why does it not use the PSRAM?
Another question: isn't it possible to read and write float numbers directly as groups of 4 bytes? The resulting file would be smaller in the Flash memory.
Test LittleFS write, read
#include <LittleFS.h>
LittleFS_QPINAND myfs; // QSPI NAND Flash attached to SPI
#include "onnx__Conv_110.h"
const int N = 100000;
const int total = 921600;
DMAMEM float data[N] = { 0 };
float last = 0;
elapsedMicros chrono;
while (!Serial) {
// wait for serial port to connect.
Serial.print("Initializing SPI FLASH...");
if (!myfs.begin()) {
Serial.printf("Error starting %s\n", "SPI FLASH");
while (1)
// uncomment only the first time
// Serial.println("Formatting SPI FLASH...");
// myfs.lowLevelFormat('.');
Serial.println("Searching file...");
File dir = myfs.open("/");
bool found = false;
while (true) {
File entry = dir.openNextFile();
if (!entry) break;
if (strcmp(entry.name(), "onnx__Conv_110.h") == 0) {
found = true;
Serial.println("File exists!");
Serial.printf("Size: %d\n", entry.size());
entry.close();
if (!found) {
Serial.println("Creating file...");
chrono = 0;
File dataFile = myfs.open("onnx__Conv_110.h", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
for (int j = 0; j < total; j++) {
dataFile.println(onnx__Conv_110_output_0[j], 8);
if (j % 100000 == 0) Serial.printf("i = %d data = %f\n", j, onnx__Conv_110_output_0[j]);
Serial.printf("Execution time: %.3f ms\n", (float)chrono / 1000.0);
} else Serial.println("error opening onnx__Conv_110.h");
Serial.printf("Size: %d\n", dataFile.size());
dataFile.close();
delay(200);
last = onnx__Conv_110_output_0[N - 1];
Serial.println("Now reading data...");
chrono = 0;
File file2 = myfs.open("onnx__Conv_110.h", FILE_READ);
char buffer[15]; // 8 digits after .
int index = 0;
int i = 0;
if (file2) {
while (file2.available()) {
buffer[index++] = file2.read();
if (buffer[index - 1] == '\r') {
buffer[index - 1] = '\0'; // NULL terminate the array
data[i++] = atof(buffer);
index = 0;
file2.read();
if (i % 10000 == 0) Serial.println(i);
if (i > N) break;
} else Serial.println("error opening file");
file2.close();
Serial.printf("Checking data number %d...\nData written: %f\n", N, last);
Serial.printf("Data read : %f\n", data[N - 1]);
// nope
Initializing SPI FLASH...NAND Flash Memory Size = 265289728 bytes / 253 Mbyte / 2 Gbit
Flash initialized.
Searching file...
File exists!
Now reading data...
10000
20000
30000
40000
50000
60000
70000
80000
90000
100000
Execution time: 520.251 ms
Checking data number 100000...
Data written: -0.021341
Data read : -0.021341
- If I set the PSRAM frequency to 133 MHz, the time reduces to 509 ms for 100 000 data.
- Using compilation options 'Fastest with LTO' reduces again to 504 ms
- Overclocking the CPU to 860MHz reduces down to 370 ms.
Flash initialized.
Searching file...
File exists!
Now reading data...
10000
20000
30000
40000
50000
60000
70000
80000
90000
100000
Execution time: 370.558 ms
c:/users/fa125436/appdata/local/arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\fa125436\AppData\Local\arduino\sketches\BE3F2F28DD8D15A2286C6FF9565BEE79/Teensy_test_LittleFS_Flash.ino.elf section `.bss.dma' will not fit in region `RAM'
c:/users/fa125436/appdata/local/arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: region `RAM' overflowed by 688128 bytes
