kd5rxt-mark
Code:C:\Arduino\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino\arduino-1.8.19\hardware -hardware C:\Users\15712\AppData\Local\Arduino15\packages -tools C:\Arduino\arduino-1.8.19\tools-builder -tools C:\Arduino\arduino-1.8.19\hardware\tools\avr -tools C:\Users\15712\AppData\Local\Arduino15\packages -built-in-libraries C:\Arduino\arduino-1.8.19\libraries -libraries C:\Users\15712\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serialmtp,speed=150,o pt=o2std,keys=en-us -ide-version=10819 -build-path C:\Users\15712\AppData\Local\Temp\arduino_build_88 555 -warnings=none -build-cache C:\Users\15712\AppData\Local\Temp\arduino_cache_59 1103 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.teensy-compile.path=C:\Users\15712\AppData\Local\Arduino1 5\packages\teensy\tools\teensy-compile\11.3.1 -prefs=runtime.tools.teensy-compile-11.3.1.path=C:\Users\15712\AppData\Local\Arduino15 \packages\teensy\tools\teensy-compile\11.3.1 -prefs=runtime.tools.teensy-tools.path=C:\Users\15712\AppData\Local\Arduino15\ packages\teensy\tools\teensy-tools\1.58.0 -prefs=runtime.tools.teensy-tools-1.58.0.path=C:\Users\15712\AppData\Local\Arduino15 \packages\teensy\tools\teensy-tools\1.58.0 -verbose C:\Users\15712\Documents\Arduino\Audio-Guestbooks\audio-guestbook\audio-guestbook.ino Error resolving FQBN: getting Error compiling for board Teensy 4.0.
Sorry. Here is the error message using the hashtag code tags. User is virgin too.
To get rid of all history, etc., you might try the "full IDE cleanup" that KurtE describes in <this> thread post.
Mark J Culross
KD5RXT
P.S. Others have also noted the following which seems to be very important for a full & complete cleanup: before starting the cleanup process, make 100% certain that there are no copies of any Arduino IDE running (maybe a clean reboot before the cleanup would/could ensure that this is the case), otherwise Arduino will not fully complete the uninstall process & will leave bothersome "turds" behind. MJC
