Here is a third beta test for Teensyduino 1.56.
Linux 32 bit:
https://www.pjrc.com/teensy/td_156-beta3/TeensyduinoInstall.linux32
Linux 64 bit:
https://www.pjrc.com/teensy/td_156-beta3/TeensyduinoInstall.linux64
Linux ARM:
https://www.pjrc.com/teensy/td_156-beta3/TeensyduinoInstall.linuxarm
Linux ARM64:
https://www.pjrc.com/teensy/td_156-beta3/TeensyduinoInstall.linuxaarch64
MacOS 10.10 to 10.15:
https://www.pjrc.com/teensy/td_156-beta3/Teensyduino_MacOS_Catalina.zip
MacOS 10.8 to 10.14:
https://www.pjrc.com/teensy/td_156-beta3/TeensyduinoInstall.dmg
Windows:
https://www.pjrc.com/teensy/td_156-beta3/TeensyduinoInstall.exe
Changes since Teensyduino 1.56-beta2:
Teensy Loader updates Teensy 4.0, 4.1, MicroMod to bootloader 1.07
Improve SD.mediaPresent()
Fix SD compile error on Teensy LC
Show helpful error if original SdFat used
Fix SdFat example compile errors, FsFile & SD_FAT_TYPE
Delete SdFat examples not needed for Teensy
Improve SdFat format speed with SHARED_SPI
Improve SdFat free cluster count speed with SHARED_SPI
Add SdFat restart(), to reinitialize hardware & card
SdFat FAT16/32 format use existing buffer (Kurt E)
SdFat support for GPT partitions (Kurt E)
SdFat fix use of USE_SIMPLE_LITTLE_ENDIAN
SdFat fix exfat corruption when using timestamps (Kurt E)
Wire use inline functions for AVR
Wire increase buffer size on Teensy 3 & 4
Wire fix ambiguous requestFrom with bool
FS use block write (Kurt E)
Fix IMXRT_DMA_TCD define
Add comments in imxrt.h for clock gate requirements
Fix MTP count of bytes transferred (Kurt E)
Improve usbMIDI.send_now() on Teensy 3.x (Robert Jonkman)
Improve Stream comptibility with newer Arduino (Kurt E)
Audio add play queue setMaxBuffers() (Mark T)
Audio add play queue play() for raw data (Mark T)
Update FastLED to 3.4
FastLED fix OctoWS2811 driver on Teensy 4 (Shawn Silverman)
FastLED fix WS2812B timing on Teensy 4
OctoWS2811 add BasicTest_FastLED example
FreqCount fix for reading less slower than gate interval (mjs513)
FreqCount add missing end() function (mjs513)
LittleFS update internal littlefs to version 2.4.1 (mjs513)
Tlc5940 minor update for compiler flag setting (Adam Phelps)
OneWire minor updates for non-Teensy boards
USBHost_t36 fix HIDDumper example for Linux (Kurt E)
USBHost_t36 increase enum buffer for complex MIDI devices (Robert Jonkman)
Improve Teensy 4 Secure fusewrite and locksecuremode
Allow some old Teensy 4.x boards to run EHEX files
Add usage info with -h to teensy_post_compile and teensy_ports
Fix teensy_ports -L on Windows
Linux 32 bit:
Linux 64 bit:
Linux ARM:
Linux ARM64:
Windows:
