* (c) 2016 Frank DD4WH 2016_11_02 - MIT license
* Teensy Bat & Ultrasound detector
* Version 0.3
* https://forum.pjrc.com/threads/38988-Bat-detector
* made possible by the samplerate code by Frank Boesing, thanks Frank!
* tested on Teensy 3.5 + Teensy audio board
* + standard tiny electret MIC soldered to the MIC Input of the audio board
* User adjustments - with buttons
* MIC-GAIN 33 + 34 -
* FREQUENCY 35 + 36 -
* SAMPLE RATE 37 + 38 -
* Audio sample rate code - function setI2SFreq
* Copyright (c) 2016, Frank Bösing, f.boesing@gmx.de
* THE SOFTWARE.
#include <Bounce.h>
#include <Metro.h>
#include <ILI9341_t3.h>
#include "font_Arial.h"
#define VERSION " v0.3"
#define BACKLIGHT_PIN 0
#define TFT_DC 20
#define TFT_CS 21
#define TFT_RST 32 // 255 = unused. connect to 3.3V
#define TFT_MOSI 7
#define TFT_SCLK 14
#define TFT_MISO 12
// would be nice to use the fast DMA lib, but it does not work on my Teensy 3.5
//ILI9341_t3DMA tft = ILI9341_t3DMA(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
#define BUTTON_MIC_GAIN_P 33
#define BUTTON_MIC_GAIN_M 34
#define BUTTON_FREQ_P 35
#define BUTTON_FREQ_M 36
#define BUTTON_SAMPLE_RATE_P 37
#define BUTTON_SAMPLE_RATE_M 38
Bounce mic_gain_P = Bounce(BUTTON_MIC_GAIN_P, 50);
Bounce mic_gain_M = Bounce(BUTTON_MIC_GAIN_M, 50);
Bounce freq_P = Bounce(BUTTON_FREQ_P, 50);
Bounce freq_M = Bounce(BUTTON_FREQ_M, 50);
Bounce sample_rate_P = Bounce(BUTTON_SAMPLE_RATE_P, 50);
Bounce sample_rate_M = Bounce(BUTTON_SAMPLE_RATE_M, 50);
#define SAMPLE_RATE_MIN 0
#define SAMPLE_RATE_44K 0
#define SAMPLE_RATE_48K 1
#define SAMPLE_RATE_88K 2
#define SAMPLE_RATE_96K 3
#define SAMPLE_RATE_176K 4
#define SAMPLE_RATE_192K 5
#define SAMPLE_RATE_MAX 5
// this audio comes from the codec by I2S2
AudioInputI2S i2s_in; // MIC input
AudioSynthWaveformSine sine1; // local oscillator
AudioEffectMultiply mult1; // multiply = mix
AudioAnalyzeFFT256 myFFT; // for spectrum display
AudioOutputI2S i2s_out; // headphone output
AudioConnection patchCord5(i2s_in,0,myFFT,0);
AudioConnection patchCord6(i2s_in,0, mult1,0);
AudioConnection patchCord7(sine1,0, mult1,1);
AudioConnection patchCord3(mult1, 0, i2s_out, 1);
AudioConnection patchCord4(mult1, 0, i2s_out, 0);
// Metro 1 second
Metro second = Metro(1000);
elapsedMillis since_bat_detection1;
elapsedMillis since_bat_detection2;
int idx_t = 0;
int idx = 0;
int64_t sum;
float32_t mean;
int16_t FFT_bin [128];
int16_t FFT_max1 = 0;
uint32_t FFT_max_bin1 = 0;
int16_t FFT_mean1 = 0;
int16_t FFT_max2 = 0;
uint32_t FFT_max_bin2 = 0;
int16_t FFT_mean2 = 0;
//int16_t FFT_threshold = 0;
int16_t FFT_bat [3]; // max of 3 frequencies are being displayed
int16_t index_FFT;
int l_limit;
int u_limit;
int index_l_limit;
int index_u_limit;
int peak[512];
int barm[512];
int8_t mic_gain = 40; // start detecting with this MIC_GAIN in dB
int freq_real = 22000; // start detecting at this frequency
int sample_rate = SAMPLE_RATE_96K;
int sample_rate_real = 96000;
String text="96k";
int freq_LO = 7000;
typedef struct SR_Descriptor
const int SR_n;
const char* const f1;
const char* const f2;
const char* const f3;
const char* const f4;
const float32_t x_factor;
} SR_Desc;
// Text and position for the FFT spectrum display scale
const SR_Descriptor SR [SAMPLE_RATE_MAX + 1] =
// SR_n , f1, f2, f3, f4, x_factor = pixels per f1 kHz in spectrum display
{ SAMPLE_RATE_44K, "5", "10", "15", "20", 58.05}, // which means 58.05 pixels per 5 kHz
{ SAMPLE_RATE_48K, "5", "10", "15", "20", 53.33},
{ SAMPLE_RATE_88K, "10", "20", "30", "40", 58.05},
{ SAMPLE_RATE_96K, "10", "20", "30", "40", 53.33},
{ SAMPLE_RATE_176K, "20", "40", "60", "80", 58.05},
{ SAMPLE_RATE_192K, "20", "40", "60", "80", 53.33} // which means 53.33 pixels per 20kHz
//const int myInput = AUDIO_INPUT_LINEIN;
const int myInput = AUDIO_INPUT_MIC;
delay(200);
//setup pins with pullups
pinMode(BUTTON_MIC_GAIN_P,INPUT_PULLUP);
pinMode(BUTTON_MIC_GAIN_M,INPUT_PULLUP);
pinMode(BUTTON_FREQ_P,INPUT_PULLUP);
pinMode(BUTTON_FREQ_M,INPUT_PULLUP);
pinMode(BUTTON_SAMPLE_RATE_P,INPUT_PULLUP);
pinMode(BUTTON_SAMPLE_RATE_M,INPUT_PULLUP);
// Audio connections require memory.
AudioMemory(100);
// Enable the audio shield. select input. and enable output
sgtl5000_1.enable();
sgtl5000_1.volume(0.8);
sgtl5000_1.micGain (mic_gain);
sgtl5000_1.adcHighPassFilterDisable(); // does not help too much!
pinMode( BACKLIGHT_PIN, OUTPUT );
analogWrite( BACKLIGHT_PIN, 1023 );
tft.begin();
tft.setRotation( 3 );
tft.setCursor(14, 7);
tft.setTextColor(ILI9341_ORANGE);
tft.setFont(Arial_12);
tft.print("Teensy Bat Detector "); tft.print(VERSION);
tft.setTextColor(ILI9341_WHITE);
display_settings();
// sorry, couldn´t resist ;-)
logo_head();
for (int v = 0; v < 6; v++) {
logo(true);
delay(200);
logo(false);
delay(200);
set_sample_rate (sample_rate);
set_freq_LO (freq_real);
} // END SETUP
controls();
spectrum();
check_processor();
void controls() {
mic_gain_P.update();
mic_gain_M.update();
freq_P.update();
freq_M.update();
sample_rate_P.update();
sample_rate_M.update();
// change MIC GAIN
if ( mic_gain_P.fallingEdge()) {
mic_gain = mic_gain + 2;
if (mic_gain > 63) {
mic_gain = 63;
set_mic_gain(mic_gain);
if ( mic_gain_M.fallingEdge()) {
mic_gain = mic_gain - 2;
if (mic_gain < 0) {
mic_gain = 0;
// change FREQUENCY of the local oscillator
if ( freq_P.fallingEdge()) {
freq_real = freq_real + 1000;
if (freq_real > 85000) {
freq_real = 85000;
set_freq_LO(freq_real);
if ( freq_M.fallingEdge()) {
freq_real = freq_real - 1000;
if (freq_real < 0) {
freq_real = 0;
// change sample rate
if ( sample_rate_P.fallingEdge()) {
sample_rate = sample_rate + 1;
if (sample_rate > SAMPLE_RATE_MAX) {
sample_rate = SAMPLE_RATE_MAX;
if ( sample_rate_M.fallingEdge()) {
sample_rate = sample_rate - 1;
if (sample_rate < SAMPLE_RATE_MIN) {
sample_rate = SAMPLE_RATE_MIN;
} // END function "controls"
void set_mic_gain(int8_t gain) {
AudioNoInterrupts();
AudioInterrupts();
display_settings();
} // end function set_mic_gain
void set_freq_LO(int freq) {
// audio lib thinks we are still in 44118sps sample rate
// therefore we have to scale the frequency of the local oscillator
// in accordance with the REAL sample rate
freq_LO = freq * (AUDIO_SAMPLE_RATE_EXACT / sample_rate_real);
// if we switch to LOWER samples rates, make sure the running LO
// frequency is allowed ( < 22k) ! If not, adjust consequently, so that
// LO freq never goes up 22k, also adjust the variable freq_real
if(freq_LO > 22000) {
freq_LO = 22000;
freq_real = freq_LO * (sample_rate_real / AUDIO_SAMPLE_RATE_EXACT) + 9;
sine1.frequency(freq_LO);
AudioInterrupts();
display_settings();
} // END of function set_freq_LO
void display_settings() {
tft.fillRect(14,32,200,17,ILI9341_BLACK);
tft.setCursor(14, 32);
tft.print("gain: "); tft.print (mic_gain);
tft.print(" ");
tft.print("freq: "); tft.print (freq_real);
tft.print(" ");
tft.fillRect(232,32,88,17,ILI9341_BLACK);
tft.setCursor(232, 32);
tft.print(" ");
tft.print (text);
/* // only for debugging
tft.fillRect(0,122,200,17,ILI9341_BLACK);
tft.setCursor(0, 122);
tft.print("LO: "); tft.print (freq_LO);
tft.print(" ");
void set_sample_rate (int sr) {
switch (sr) {
case SAMPLE_RATE_44K:
sample_rate_real = 44100;
text = "44.1k";
case SAMPLE_RATE_48K:
sample_rate_real = 48000;
text = "48k";
case SAMPLE_RATE_88K:
sample_rate_real = 88200;
text = "88.2k";
case SAMPLE_RATE_96K:
text = "96k";
case SAMPLE_RATE_176K:
sample_rate_real = 176400;
text = "176k";
case SAMPLE_RATE_192K:
sample_rate_real = 192000;
text = "192k";
setI2SFreq (sample_rate_real);
delay(200); // this delay seems to be very essential !
AudioInterrupts();
delay(20);
display_settings();
prepare_spectrum_display();
} // END function set_sample_rate
void prepare_spectrum_display() {
int base_y = 211;
int b_x = 10;
int x_f = SR[sample_rate].x_factor;
tft.fillRect(0,base_y,320,240 - base_y,ILI9341_BLACK);
// tft.drawFastHLine(b_x, base_y + 2, 256, ILI9341_PURPLE);
// tft.drawFastHLine(b_x, base_y + 3, 256, ILI9341_PURPLE);
tft.drawFastHLine(b_x, base_y + 2, 256, ILI9341_MAROON);
tft.drawFastHLine(b_x, base_y + 3, 256, ILI9341_MAROON);
// vertical lines
tft.drawFastVLine(b_x - 4, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine(b_x - 3, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f + 1 + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 2 + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 2 + 1 + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 3 + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 3 + 1 + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 4 + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 4 + 1 + b_x, base_y + 1, 10, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 0.5 + b_x, base_y + 1, 6, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 1.5 + b_x, base_y + 1, 6, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 2.5 + b_x, base_y + 1, 6, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 3.5 + b_x, base_y + 1, 6, ILI9341_YELLOW);
tft.drawFastVLine( x_f * 4.5 + b_x, base_y + 1, 6, ILI9341_YELLOW);
// text
tft.setFont(Arial_9);
int text_y_offset = 16;
int text_x_offset = - 5;
tft.setCursor (b_x + text_x_offset + 256, base_y + text_y_offset);
tft.print("kHz");
// zero
tft.setCursor (b_x + text_x_offset, base_y + text_y_offset);
tft.print("0");
tft.setCursor (b_x + x_f + text_x_offset, base_y + text_y_offset);
tft.print(SR[sample_rate].f1);
tft.setCursor (b_x + x_f * 2 + text_x_offset, base_y + text_y_offset);
tft.print(SR[sample_rate].f2);
tft.setCursor (b_x + x_f *3 + text_x_offset, base_y + text_y_offset);
tft.print(SR[sample_rate].f3);
tft.setCursor (b_x + x_f *4 + text_x_offset, base_y + text_y_offset);
tft.print(SR[sample_rate].f4);
tft.setFont(Arial_14);
} // END prepare_spectrum_display
void spectrum() { // spectrum analyser code by rheslip - modified
if (myFFT.available()) {
int scale;
scale = 5;
for (int16_t x = 2; x < 128; x++) {
FFT_bin[x] = abs(myFFT.output[x]);
int bar = (FFT_bin[x] * scale);
if (bar >175) bar=175;
// this is a very simple first order IIR filter to smooth the reaction of the bars
bar = 0.05 * bar + 0.95 * barm[x];
// if (bar > peak[x]) peak[x]=bar;
// tft.drawFastVLine(x, 210-bar,bar, ILI9341_PURPLE);
// tft.drawFastVLine(x*2+10, 210-bar,bar, ILI9341_PINK);
tft.drawPixel(x*2+10, 210-barm[x], ILI9341_BLACK);
tft.drawPixel(x*2+10, 210-bar, ILI9341_WHITE);
// tft.drawFastVLine(x*2+10, 20, 210-bar-20, ILI9341_BLACK);
// tft.drawPixel(x*2+10,209-peak[x], ILI9341_YELLOW);
// if(peak[x]>0) peak[x]-=1;
barm[x] = bar;
search_bats();
} //end if
} // end void spectrum
void search_bats() {
// the array FFT_bin contains the results of the 256 point FFT --> 128 magnitude values
// we look for bins that have a high amplitude compared to the mean noise, indicating the presence of ultrasound
// 1. only search in those parts of the array > 14kHz and not around +-10kHz of the LO freq -->
// thus it is best, if I search in two parts --> 14kHz to freq_real-10k AND freq_real+10k to sample_rate/2
// 2. determine mean and max in both parts of the array
// 3. if we find a bin that is much larger than the mean (take care of situations where mean is zero!) --> identify the no. of the bin
// 4. determine frequency of that bin (depends on sample_rate_real)
// a.) by simply multiplying bin# with bin width
// b.) by using an interpolator (not (yet) implemented)
// 5. display frequency in bold and RED for 1-2 sec. (TODO: also display possible bat species ;-)) and then delete
// goto 1.
// search array in two parts:
// 1.) 14k to (freq_real - 10k)
// upper and lower limits for maximum search
l_limit = 14000;
u_limit = freq_real - 10000;
index_l_limit = (l_limit * 256 / sample_rate_real);
index_u_limit = (u_limit * 256 / sample_rate_real);
// Serial.print(index_l_limit); Serial.print (" "); Serial.println(index_u_limit);
if (index_u_limit > index_l_limit) {
arm_max_q15(&FFT_bin[index_l_limit], index_u_limit - index_l_limit, &FFT_max1, &FFT_max_bin1);
// this is the efficient CMSIS function to calculate the mean
arm_mean_q15(&FFT_bin[index_l_limit], index_u_limit - index_l_limit, &FFT_mean1);
// shift bin_max because we have not searched through ALL the 256 FFT bins
FFT_max_bin1 = FFT_max_bin1 + index_l_limit;
// Serial.print(FFT_max1); Serial.print (" "); Serial.println(FFT_mean1);
// 2.) (freq_real + 10k) to 256
l_limit = freq_real + 10000;
if (l_limit < 14000) {
l_limit = 14000;
index_u_limit = 128;
arm_max_q15(&FFT_bin[index_l_limit], index_u_limit - index_l_limit, &FFT_max2, &FFT_max_bin2);
arm_mean_q15(&FFT_bin[index_l_limit], index_u_limit - index_l_limit, &FFT_mean2);
// shift bin_max because we have not searched through ALL the 128 FFT bins
FFT_max_bin2 = FFT_max_bin2 + index_l_limit;
// Serial.print(FFT_max2); Serial.print (" "); Serial.println(FFT_mean2);
display_found_bats();
FFT_max1 = 0;
FFT_mean1 = 0;
FFT_max_bin1 = 0;
FFT_max2 = 0;
FFT_mean2 = 0;
FFT_max_bin2 = 0;
} // END function search_bats()
void display_found_bats() {
int sign_x = 148;
int sign_y = 57;
if (since_bat_detection1 > 6000 && since_bat_detection2 > 6000) {
// DELETE red BAT sign
// Serial.println("RED SIGN DELETED");
tft.fillRect(sign_x, sign_y, 64, 22, ILI9341_BLACK);
tft.fillRect(sign_x + 86, sign_y + 4, 320 - 86 - sign_x, 40, ILI9341_BLACK);
// since_bat_detection = 0;
// DELETE FREQUENCY 1
if (since_bat_detection1 > 6000) {
tft.fillRect(sign_x + 86, sign_y + 4, 320 - 86 - sign_x, 14, ILI9341_BLACK);
// since_bat_detection1 = 0;
// DELETE FREQUENCY 2
if (since_bat_detection2 > 6000) {
tft.fillRect(sign_x + 86, sign_y + 30, 320 - 86 - sign_x, 14, ILI9341_BLACK);
// since_bat_detection2 = 0;
// PRINT RED BAT SIGN
if(FFT_max1 > (FFT_mean1 + 5) || FFT_max2 > (FFT_mean2 + 5)) {
// Serial.println("BAT");
tft.fillRect(sign_x, sign_y, 64, 22, ILI9341_RED);
tft.setCursor(sign_x + 2, sign_y + 4);
tft.print("B A T !");
// PRINT frequency 1
if(FFT_max1 > FFT_mean1 + 5) {
tft.setCursor(sign_x + 86, sign_y + 4);
tft.print(FFT_max_bin1 * sample_rate_real / 256);
tft.print(" Hz");
// Serial.print ("max Freq 1: ");
// Serial.println(FFT_max_bin1 * sample_rate_real / 256);
// PRINT frequency 2
if(FFT_max2 > FFT_mean2 + 5) {
tft.setCursor(sign_x + 86, sign_y + 30);
tft.print(FFT_max_bin2 * sample_rate_real / 256);
tft.print(" Hz");
// Serial.print ("max Freq 2: ");
// Serial.println(FFT_max_bin2 * sample_rate_real / 256);
} // END function display_found_bats
// set samplerate code by Frank Boesing
void setI2SFreq(int freq) {
typedef struct {
uint8_t mult;
uint16_t div;
} tmclk;
const int numfreqs = 14;
const int samplefreqs[numfreqs] = { 8000, 11025, 16000, 22050, 32000, 44100, (int)44117.64706 , 48000, 88200, (int)44117.64706 * 2, 96000, 176400, (int)44117.64706 * 4, 192000};
#if (F_PLL==16000000)
const tmclk clkArr[numfreqs] = {{16, 125}, {148, 839}, {32, 125}, {145, 411}, {64, 125}, {151, 214}, {12, 17}, {96, 125}, {151, 107}, {24, 17}, {192, 125}, {127, 45}, {48, 17}, {255, 83} };
#elif (F_PLL==72000000)
const tmclk clkArr[numfreqs] = {{32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {128, 1125}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375}, {249, 397}, {32, 51}, {185, 271} };
#elif (F_PLL==96000000)
const tmclk clkArr[numfreqs] = {{8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {32, 375}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125}, {151, 321}, {8, 17}, {64, 125} };
#elif (F_PLL==120000000)
const tmclk clkArr[numfreqs] = {{32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {128, 1875}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625}, {178, 473}, {32, 85}, {145, 354} };
#elif (F_PLL==144000000)
const tmclk clkArr[numfreqs] = {{16, 1125}, {49, 2500}, {32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {4, 51}, {32, 375}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375} };
#elif (F_PLL==168000000)
const tmclk clkArr[numfreqs] = {{32, 2625}, {21, 1250}, {64, 2625}, {21, 625}, {128, 2625}, {42, 625}, {8, 119}, {64, 875}, {84, 625}, {16, 119}, {128, 875}, {168, 625}, {32, 119}, {189, 646} };
#elif (F_PLL==180000000)
const tmclk clkArr[numfreqs] = {{46, 4043}, {49, 3125}, {73, 3208}, {98, 3125}, {183, 4021}, {196, 3125}, {16, 255}, {128, 1875}, {107, 853}, {32, 255}, {219, 1604}, {214, 853}, {64, 255}, {219, 802} };
#elif (F_PLL==192000000)
const tmclk clkArr[numfreqs] = {{4, 375}, {37, 2517}, {8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {1, 17}, {8, 125}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125} };
#elif (F_PLL==216000000)
const tmclk clkArr[numfreqs] = {{32, 3375}, {49, 3750}, {64, 3375}, {49, 1875}, {128, 3375}, {98, 1875}, {8, 153}, {64, 1125}, {196, 1875}, {16, 153}, {128, 1125}, {226, 1081}, {32, 153}, {147, 646} };
#elif (F_PLL==240000000)
const tmclk clkArr[numfreqs] = {{16, 1875}, {29, 2466}, {32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {4, 85}, {32, 625}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625} };
for (int f = 0; f < numfreqs; f++) {
if ( freq == samplefreqs[f] ) {
while (I2S0_MCR & I2S_MCR_DUF) ;
I2S0_MDR = I2S_MDR_FRACT((clkArr[f].mult - 1)) | I2S_MDR_DIVIDE((clkArr[f].div - 1));
return;
// bat logo taken from Shezzy:
// http://sisterzpsptreasures.freeforums.org/easy-animated-bat-t77.html
// copyright free graphics
// "The image you create by following this tutorial belongs to you and you may do whatever you want with it."
void logo(bool wing1) {
// Logo ;-)
int x = 265;
int y = 10;
// grey background and white line rectangle around it
tft.fillRect(x + 23, y - 2,16,14,ILI9341_DARKGREY);
tft.fillRect(x - 2, y - 2,16,14,ILI9341_DARKGREY);
// tft.fillRect(x - 2, y - 2, 41, 14,ILI9341_DARKGREY);
if (wing1) {
//Wing1
tft.drawFastHLine(x + 2, y + 0, 5, ILI9341_BLACK);
tft.drawFastHLine(x + 31, y + 0, 5, ILI9341_BLACK);
tft.drawPixel(x + 1, y + 1, ILI9341_BLACK);
tft.drawPixel(x + 35, y + 1, ILI9341_BLACK);
tft.drawPixel(x + 6, y + 1, ILI9341_BLACK);
tft.drawPixel(x + 30, y + 1, ILI9341_BLACK);
// tft.drawPixel(x + 6, y + 2, ILI9341_BLACK);
// tft.drawPixel(x + 30, y + 2, ILI9341_BLACK);
tft.drawFastVLine(x , y + 2, 7, ILI9341_BLACK);
tft.drawFastVLine(x + 36 , y + 2, 7, ILI9341_BLACK);
tft.drawFastHLine(x + 7, y + 2, 2, ILI9341_BLACK);
tft.drawFastHLine(x + 28, y + 2, 2, ILI9341_BLACK);
tft.drawPixel(x + 13, y + 2, ILI9341_BLACK);
tft.drawPixel(x + 23, y + 2, ILI9341_BLACK);
tft.drawFastHLine(x + 9, y + 3, 4, ILI9341_BLACK);
tft.drawFastHLine(x + 24, y + 3, 4, ILI9341_BLACK);
tft.drawFastHLine(x + 3, y + 5, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 31, y + 5, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 7, y + 5, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 27, y + 5, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 11, y + 5, 2, ILI9341_BLACK);
tft.drawFastHLine(x + 24, y + 5, 2, ILI9341_BLACK);
tft.drawPixel(x + 2, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 6, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 10, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 13, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 23, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 26, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 30, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 34, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 1, y + 7, ILI9341_BLACK);
tft.drawPixel(x + 6, y + 7, ILI9341_BLACK);
tft.drawPixel(x + 10, y + 7, ILI9341_BLACK);
tft.drawPixel(x + 26, y + 7, ILI9341_BLACK);
tft.drawPixel(x + 30, y + 7, ILI9341_BLACK);
tft.drawPixel(x + 35, y + 7, ILI9341_BLACK);
else {
//Wing2
tft.drawFastHLine(x + 2, y + 2, 5, ILI9341_BLACK);
tft.drawFastHLine(x + 31, y + 2, 5, ILI9341_BLACK);
tft.drawPixel(x + 1, y + 3, ILI9341_BLACK);
tft.drawPixel(x + 35, y + 3, ILI9341_BLACK);
tft.drawPixel(x + 6, y + 3, ILI9341_BLACK);
tft.drawPixel(x + 30, y + 3, ILI9341_BLACK);
// tft.drawPixel(x + 6, y + 4, ILI9341_BLACK);
// tft.drawPixel(x + 30, y + 4, ILI9341_BLACK);
tft.drawFastVLine(x , y + 4, 7, ILI9341_BLACK);
tft.drawFastVLine(x + 36 , y + 4, 7, ILI9341_BLACK);
tft.drawFastHLine(x + 7, y + 4, 2, ILI9341_BLACK);
tft.drawFastHLine(x + 28, y + 4, 2, ILI9341_BLACK);
// tft.drawPixel(x + 13, y + 4, ILI9341_BLACK);
// tft.drawPixel(x + 23, y + 4, ILI9341_BLACK);
tft.drawFastHLine(x + 9, y + 5, 5, ILI9341_BLACK);
tft.drawFastHLine(x + 24, y + 5, 5, ILI9341_BLACK);
tft.drawFastHLine(x + 3, y + 7, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 31, y + 7, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 7, y + 7, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 27, y + 7, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 11, y + 7, 3, ILI9341_BLACK);
tft.drawFastHLine(x + 24, y + 7, 3, ILI9341_BLACK);
tft.drawPixel(x + 2, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 6, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 10, y + 8, ILI9341_BLACK);
// tft.drawPixel(x + 13, y + 8, ILI9341_BLACK);
// tft.drawPixel(x + 23, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 26, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 30, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 34, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 1, y + 9, ILI9341_BLACK);
tft.drawPixel(x + 6, y + 9, ILI9341_BLACK);
tft.drawPixel(x + 10, y + 9, ILI9341_BLACK);
tft.drawPixel(x + 26, y + 9, ILI9341_BLACK);
tft.drawPixel(x + 30, y + 9, ILI9341_BLACK);
tft.drawPixel(x + 35, y + 9, ILI9341_BLACK);
void logo_head() {
int x = 265;
int y = 10;
tft.fillRect(x + 14, y - 2,9,14,ILI9341_DARKGREY);
// Head
tft.drawPixel(x + 15, y + 2, ILI9341_BLACK);
tft.drawPixel(x + 21, y + 2, ILI9341_BLACK);
tft.drawPixel(x + 14, y + 3, ILI9341_BLACK);
tft.drawPixel(x + 16, y + 3, ILI9341_BLACK);
tft.drawPixel(x + 20, y + 3, ILI9341_BLACK);
tft.drawPixel(x + 22, y + 3, ILI9341_BLACK);
tft.drawPixel(x + 14, y + 4, ILI9341_BLACK);
tft.drawPixel(x + 22, y + 4, ILI9341_BLACK);
tft.drawFastHLine(x + 17, y + 4, 3, ILI9341_BLACK);
tft.drawPixel(x + 14, y + 5, ILI9341_BLACK);
tft.drawPixel(x + 22, y + 5, ILI9341_BLACK);
tft.drawPixel(x + 16, y + 5, ILI9341_RED);
tft.drawPixel(x + 20, y + 5, ILI9341_RED);
tft.drawPixel(x + 17, y + 6, ILI9341_RED);
tft.drawPixel(x + 19, y + 6, ILI9341_RED);
tft.drawPixel(x + 14, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 22, y + 6, ILI9341_BLACK);
tft.drawPixel(x + 15, y + 7, ILI9341_BLACK);
tft.drawPixel(x + 21, y + 7, ILI9341_BLACK);
tft.drawPixel(x + 16, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 20, y + 8, ILI9341_BLACK);
tft.drawPixel(x + 17, y + 8, ILI9341_WHITE);
tft.drawPixel(x + 19, y + 8, ILI9341_WHITE);
tft.drawFastHLine(x + 17, y + 9, 3, ILI9341_BLACK);
void check_processor() {
if (second.check() == 1) {
Serial.print("Proc = ");
Serial.print(AudioProcessorUsage());
Serial.print(" (");
Serial.print(AudioProcessorUsageMax());
Serial.print("), Mem = ");
Serial.print(AudioMemoryUsage());
Serial.print(" (");
Serial.print(AudioMemoryUsageMax());
Serial.println(")");
/* tft.fillRect(100,120,200,80,ILI9341_BLACK);
tft.setCursor(10, 120);
tft.setTextSize(2);
tft.print ("Proc = ");
tft.setCursor(100, 120);
tft.print (AudioProcessorUsage());
tft.setCursor(180, 120);
tft.print (AudioProcessorUsageMax());
tft.setCursor(10, 150);
tft.print ("Mem = ");
tft.setCursor(100, 150);
tft.print (AudioMemoryUsage());
tft.setCursor(180, 150);
tft.print (AudioMemoryUsageMax());
AudioProcessorUsageMaxReset();
AudioMemoryUsageMaxReset();
} // END function check_processor
