defragster
Senior Member+
On one of the NAND SPI chips LFSIntegrity had run leaving lots of dirs and files - died on delete of folder 24? Teensy still responds to USB CMD 'f' to toggle that.
Running the new LFSIntegrity a recursive delete/WIPE all was created and it is visible in the delete process there are some longer pauses.
Wondering if one of those pauses is what threw off the delete? I said skip the rest and the drive was gone after that.
Here is the end where it failed:
Looked a bit more about adding formatunused as third type - some progress - but unclear ...
CMD: 1008(GET_OBJECT_INFO)l: 16 T:1e2 : a
RESP:2001(RSP:OK)l: 16 T:1e2 : a
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1e3 : a dc01 (STORAGE_ID)
RESP:2001(RSP:OK)l: 20 T:1e3 : a dc01
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1e4 : a dc07 (OBJECT NAME)
RESP:2001(RSP:OK)l: 20 T:1e4 : a dc07
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1e5 : a dc41 (PERSISTENT_UID)
RESP:2001(RSP:OK)l: 20 T:1e5 : a dc41
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1e6 : a dc44 (NAME)
RESP:2001(RSP:OK)l: 20 T:1e6 : a dc44
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1e7 : 9 dc02 (FORMAT)
RESP:2001(RSP:OK)l: 20 T:1e7 : 9 dc02
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1e8 : 9 dc03 (PROTECTION)
RESP:2001(RSP:OK)l: 20 T:1e8 : 9 dc03
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1e9 : 9 dc04 (SIZE)
RESP:2001(RSP:OK)l: 20 T:1e9 : 9 dc04
CMD: 1008(GET_OBJECT_INFO)l: 16 T:1ea : 9
RESP:2001(RSP:OK)l: 16 T:1ea : 9
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1eb : 9 dc01 (STORAGE_ID)
RESP:2001(RSP:OK)l: 20 T:1eb : 9 dc01
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1ec : 9 dc07 (OBJECT NAME)
RESP:2001(RSP:OK)l: 20 T:1ec : 9 dc07
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1ed : 9 dc41 (PERSISTENT_UID)
RESP:2001(RSP:OK)l: 20 T:1ed : 9 dc41
CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:1ee : 9 dc44 (NAME)
RESP:2001(RSP:OK)l: 20 T:1ee : 9 dc44
CMD: 100b(DELETE_OBJECT)l: 20 T:1ef : 24 0
RESP:2001(RSP:OK)l: 20 T:1ef : 24 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f0 : 25 0
RESP:2001(RSP:OK)l: 20 T:1f0 : 25 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f1 : 26 0
RESP:2001(RSP:OK)l: 20 T:1f1 : 26 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f2 : 27 0
RESP:2001(RSP:OK)l: 20 T:1f2 : 27 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f3 : 28 0
RESP:2001(RSP:OK)l: 20 T:1f3 : 28 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f4 : 9 0
RESP:2001(RSP:OK)l: 20 T:1f4 : 9 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f5 : a 0
RESP:2001(RSP:OK)l: 20 T:1f5 : a 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f6 : b 0
RESP:2001(RSP:OK)l: 20 T:1f6 : b 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f7 : c 0
RESP:2001(RSP:OK)l: 20 T:1f7 : c 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f8 : d 0
RESP:2001(RSP:OK)l: 20 T:1f8 : d 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1f9 : e 0
RESP:2001(RSP:OK)l: 20 T:1f9 : e 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1fa : f 0
RESP:2001(RSP:OK)l: 20 T:1fa : f 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1fb : 10 0
RESP:2001(RSP:OK)l: 20 T:1fb : 10 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1fc : 11 0
RESP:2001(RSP:OK)l: 20 T:1fc : 11 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1fd : 12 0
RESP:2001(RSP:OK)l: 20 T:1fd : 12 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1fe : 14 0
RESP:2001(RSP:OK)l: 20 T:1fe : 14 0
CMD: 100b(DELETE_OBJECT)l: 20 T:1ff : 15 0
RESP:2001(RSP:OK)l: 20 T:1ff : 15 0
CMD: 100b(DELETE_OBJECT)l: 20 T:200 : 16 0
RESP:2001(RSP:OK)l: 20 T:200 : 16 0
CMD: 100b(DELETE_OBJECT)l: 20 T:201 : 17 0
RESP:2001(RSP:OK)l: 20 T:201 : 17 0
CMD: 100b(DELETE_OBJECT)l: 20 T:202 : 18 0
RESP:2001(RSP:OK)l: 20 T:202 : 18 0
*** Command line: f
low level format of LittleFS disks selected
