Looks good. Wondering about any suggestions for partially assembling a board. I have done a couple with PCBWay which has worked out OK:
But last time was about 2 years ago. With my current main MMOD test board: Where I had them do most of the SMD parts...
If my notes are correct I think it came out to about $125 for 5 of them...
Thinking about having them do a follow on one, with the DXL servo stuff, speaker, ... removed, but then add back the OV7670/75... 2x10 connector to play with some of the different cameras..
If I decide to pull the trigger. Current latest one I increased the size of the board to be length of 3.5" ILI9488 board. Similar for height except added a bit to allow camera to be plugged into the front. I actually put on two connectors, so can put on front or back... Still cleaning up;
Shown with 2.8" ILI9341...
I was thinking about the insert from bottom for the camera, but unless you had different versions, of camera, a 2 row pinout
would not work well. However did put on for ILI99341, as can then do stuff with it on either side. Where when on top it would stick out
the other end...
But wondering if there are other manufactures I should look at for just a couple of boards.
