uint32_t startTime, elapsedTime, old_res;
#define SCALE_FACTOR 0.000152587890625
/* D14 and D15 should be grounded if you use this ad7606 board
* https://www.amazon.de/RELAND-SUN-Multi-Channel-Datenerfassungsmodul-Synchronisation/dp/B0B4HKSK8B/ref=sr_1_2?keywords=ad7606&qid=1681803018&sr=8-2
* i do not use oversampling in this example
* i set range to the ground in this example so the range is +/-5V
#define BUSY 32 // you can use any digital pin
#define RESET 30 // you can use any digital pin
#define START_CONVERSION 34 // you can use any digital pin
#define CHIP_SELECT 10 // SPI CS // #define CHIP_SELECT 53 // SPI CS
#define D7_out 12 // SPI MISO there is no need to use MOSI port with the ad7606 #define D7_out 50 // SPI MISO there is no need to use MOSI port with the ad7606
#define RD 13 // SPI SCLK #define RD 52 // SPI SCLK
#define RANGE 36 // you can use any digital pin
#define TOTAL_RAW_BYTES 16
SPISettings _spiSettings;
int bytesToRead = TOTAL_RAW_BYTES;
byte raw[TOTAL_RAW_BYTES];
uint16_t parsed[8];
//--------------SETUP-UP---------------------------
initial();
Serial.begin(2000000);
while (!Serial) {} // wait for usb connection
SPI.begin();
//---------------LOOP--------------------------
startTime = micros();
readData();
elapsedTime = micros() - startTime;
if (elapsedTime != old_res)
Serial.print("Conversion time:\t");
Serial.print(elapsedTime);
Serial.println(" microseconds");
old_res = elapsedTime;
parseRawBytes();
for (int i = 0; i < 8; i++) {
Serial.print((float)parsed[i] * SCALE_FACTOR, 5);
Serial.print(",");
Serial.print("\r\n");
void initial()
pinMode(BUSY, INPUT);
pinMode(RESET, OUTPUT);
pinMode(START_CONVERSION, OUTPUT);
pinMode(CHIP_SELECT, OUTPUT);
pinMode(D7_out, OUTPUT);
pinMode(RD, OUTPUT);
digitalWrite(START_CONVERSION, HIGH);
digitalWrite(CHIP_SELECT, HIGH);
reset(RESET);
void parseRawBytes() {
I figured the problem should be here in the function of parseRawBytes.
The sizeof(int) is 4 in Portanta and also Giga.
This results in the value of (sizeof(parsed) / sizeof(int)) is 4 not 8,
so only the data for the first 4 channels can be obtained.
I modify the maximum value of loop, eight channels data can be obtained.
for (int i = 0; i < (sizeof(parsed) / sizeof(int)); i++)
parsed[i] = (raw[i * 2] << 8) + raw[(i * 2) + 1];
/*reset signal*/
void reset(uint8_t port)
digitalWrite(port, HIGH);
// delayMicroseconds(1);
digitalWrite(port, LOW);
void conversionPulse(uint8_t port)
1- start conversion START_CONVERSION HIGH
2- wait until the busy is LOW again
3- put the CS to LOW
4- Read a byte from the SPI
void readData()
conversionPulse(START_CONVERSION);
while (digitalRead(BUSY) == HIGH) {
SPI.beginTransaction(_spiSettings);
digitalWrite(CHIP_SELECT, LOW);
while (bytesToRead > 0) {
raw[TOTAL_RAW_BYTES - bytesToRead] = SPI.transfer(0x00);
bytesToRead--;
SPI.endTransaction();
0 +/- 5V
1 +/- 10V
void setRange(bool range)
pinMode(RANGE, OUTPUT);
digitalWrite(RANGE, range);
/*OS2 OS1 OS0
oversampling
000 No oversampling Maximum sampling rate is 200KSPS
001 2 times 100 KSPS
010 4 times 50 KSPS
011 8 times 25 KSPS
100 16 times 12.5 KSPS
101 32 times 6.25 KSPS
110 64 times 3.125 KSPS
void setOversampling(uint8_t OS0, uint8_t OS1, uint8_t OS2) {
pinMode(_OS0, OUTPUT);
pinMode(_OS1, OUTPUT);
pinMode(_OS2, OUTPUT);
digitalWrite(_OS0, bitRead(B001, OS0));
digitalWrite(_OS1, bitRead(B010, OS1));
digitalWrite(_OS2, bitRead(B100, OS2));
