Not sure if this is the best thread to ask this, but I have been having fun seeing what I can screw up
Or more specifically trying out stuff using some new stuff like FS.h, LittleFS, SD, MTP... And playing around with how one might use some of this stuff, to see where maybe it makes sense to expand some of the stuff for example in FS.h.
Example suppose I wish have an MTP aware sketch, which for example suppose that the sketch maybe generates log files and the like and the program may be controlled by some form of configuration file.
What other things might I want?
a) I might want to know if MTP is connected and that there is an MTP session. Not sure exactly when the best trigger point is? On Start Session? Don't know at what granularity you may wish to know things.
Example if You have two storages installed, maybe you wish to know that the 2nd storage you added, if at least the top level of this storage has been enumerated or not...
b) You might want to know if the host PC updated anything as maybe you wish to reflect this on the Teensy. Example suppose your Teensy is running a sketch and maybe has a larger display like RA8875 running sort of a tablet sketch. Maybe one of the modes that sketch may run is showing your local file system and allow you to locally create new files, delete files... This is where that code needs to notify the host about the changes (some of the stuff I have been playing with). But likewise if the host deletes some files, you would like to know that to update your list on the screen...
Maybe you simply have some notification per storage, of has something changed?
c) Sort of part of b) but suppose you have a configuration file you store in your storage, that somehow controls your sketch, maybe a set of sound files or color for LEDS, or maybe a new python script to run...
How would I detect this? Suppose I have a file at the root of my storage called teensy.ini And I want to know when this file changes? How? On many systems there might be a file change notify you might setup?
But other times, you might at start up time read the file and remember the Modify Date of the file. And then later if you see that date has changed? Then you know you may need to do something...
So then I wondered, does our high level FS.h file know anything about dates? I don't think so. Should it? Obviously Fat File systems support dates, but not sure of our Interface? I do see in some of the SDFat system there are apis to print the date, but not sure if there are any to retrieve it? LittleFS, does it support dates? I did not notice any. Is it worth doing anything? My guess (default answer) Punt.
Thoughts? Maybe main brain is just wondering too much
Edit: Note: I mention this in this thread, as to see if we should extend any of the new features before the official 1.54 is released with FS.h, LittleFS, Hopefully MTP...
