01:36:19.783 (ports 1): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
01:36:19.784 (ports 1): remove: loc=usb:0/140000/0/6/1/1
01:36:19.784 (ports 1): usb_remove: usb:0/140000/0/6/1/1
01:36:19.784 (ports 1): nothing new, skipping HID & Ports enum
01:36:19.994 (ports 1): WM_DEVICECHANGE DBT_DEVICEARRIVAL
01:36:19.996 (ports 1): nothing new, skipping HID & Ports enum
01:36:20.188 (loader): handle d64
01:36:20.188 (loader): Device came online, code_size = 100
01:36:20.188 (loader): Board is: NXP IMXRT1062 ROM
01:36:20.188 (loader): begin operation
01:36:20.188 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.hex", 21504 bytes
01:36:20.204 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex", 21504 bytes, and 4992 loader utility
01:36:20.204 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
01:36:20.204 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex". 21504 bytes
01:36:20.204 (loader): set background IMG_ONLINE
01:36:20.204 (loader): nxp_write: success
01:36:20.204 (loader): HAB locked secure mode
01:36:20.204 (loader): sending ehex loader utility, 4992 bytes
01:36:20.220 (loader): nxp_write: success
01:36:20.222 (loader): nxp_write: success
01:36:20.222 (loader): run it..
01:36:20.238 (loader): ehex loader utility sucessfully started
01:36:20.238 (loader): end operation, total time = 0.050 seconds
01:36:20.238 (loader): redraw timer set, image 80 to show for 2000 ms
01:36:20.272 (ports 1): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
01:36:20.273 (ports 1): nothing new, skipping HID & Ports enum
01:36:20.427 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:20.428 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:20.428 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/3
01:36:20.443 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/3
01:36:20.443 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:20.613 (ports 1): WM_DEVICECHANGE DBT_DEVICEARRIVAL
01:36:20.615 (ports 1): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000ecf8e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
01:36:20.615 (ports 1): found_usb_device, loc=usb:0/140000/0/6/1/1 Port_#0001.Hub_#0010
01:36:20.615 (ports 1): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
01:36:20.615 (ports 1): found_usb_device, devinst=0000001f
01:36:20.615 (ports 1): add: loc=usb:0/140000/0/6/1/1, class=HID, vid=16C0, pid=0478, ver=0107, serial=000ecf8e, dev=\\?\usb#vid_16c0&pid_0478#000ecf8e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
01:36:20.615 (ports 1): hiddev_from_devinst_list: iface=0
01:36:20.615 (ports 1): found_usb_device complete
01:36:20.616 (ports 1): usb_add: usb:0/140000/0/6/1/1 [no_device] (Teensy 4.1) Bootloader
01:36:20.686 (loader): encryption is required, public key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
01:36:20.686 (loader): Device came online, code_size = 8126464
01:36:20.696 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.07
01:36:20.696 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.hex", 21504 bytes
01:36:20.706 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex", 21504 bytes, and 4992 loader utility
01:36:20.706 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
01:36:20.716 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex". 21504 bytes, 0% used
01:36:20.716 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex" opened, but "USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex" will actually be used
01:36:20.746 (loader): set background IMG_ONLINE
01:36:20.756 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.hex", 21504 bytes
01:36:20.766 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex", 21504 bytes, and 4992 loader utility
01:36:20.766 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
01:36:20.776 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex". 21504 bytes, 0% used
[B]01:36:20.781 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex" opened, but "USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex" will actually be used
01:36:20.809 (loader): can't open file 'C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.elf' (error 2: the system cannot find the file specified.)[/B]
01:36:20.813 (loader): elf file is for Unknown Board
01:36:20.818 (loader): using encrypted ehex (required - secure mode is locked)
01:36:20.850 (loader): begin operation
01:36:20.890 (loader): flash, block=0, bs=1024, auto=1
01:36:21.046 (loader): flash, block=1, bs=1024, auto=1
01:36:21.053 (loader): flash, block=2, bs=1024, auto=1
01:36:21.058 (loader): flash, block=3, bs=1024, auto=1
01:36:21.062 (loader): flash, block=4, bs=1024, auto=1
01:36:21.069 (loader): flash, block=5, bs=1024, auto=1
01:36:21.077 (loader): flash, block=6, bs=1024, auto=1
01:36:21.082 (loader): flash, block=7, bs=1024, auto=1
01:36:21.088 (loader): flash, block=8, bs=1024, auto=1
01:36:21.125 (loader): flash, block=9, bs=1024, auto=1
01:36:21.131 (loader): flash, block=10, bs=1024, auto=1
01:36:21.136 (loader): flash, block=11, bs=1024, auto=1
01:36:21.142 (loader): flash, block=12, bs=1024, auto=1
01:36:21.149 (loader): flash, block=13, bs=1024, auto=1
01:36:21.155 (loader): flash, block=14, bs=1024, auto=1
01:36:21.187 (loader): flash, block=15, bs=1024, auto=1
01:36:21.193 (loader): flash, block=16, bs=1024, auto=1
01:36:21.202 (loader): flash, block=17, bs=1024, auto=1
01:36:21.209 (loader): flash, block=18, bs=1024, auto=1
01:36:21.216 (loader): flash, block=19, bs=1024, auto=1
01:36:21.223 (loader): flash, block=20, bs=1024, auto=1
01:36:21.255 (loader): sending reboot
01:36:21.262 (loader): begin wait_until_offline
01:36:21.267 (loader): offline, waited 0
01:36:21.273 (loader): end operation, total time = 0.417 seconds
01:36:21.280 (loader): set background IMG_REBOOT_OK
01:36:21.285 (ports 1): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
01:36:21.288 (ports 1): remove: loc=usb:0/140000/0/6/1/1
01:36:21.288 (ports 1): usb_remove: usb:0/140000/0/6/1/1
01:36:21.288 (ports 1): nothing new, skipping HID & Ports enum
01:36:21.302 (loader): redraw timer set, image 14 to show for 1200 ms
01:36:21.460 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:21.476 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/3
01:36:21.476 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:21.491 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/3
01:36:21.491 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:21.524 (ports 1): WM_DEVICECHANGE DBT_DEVICEARRIVAL
01:36:21.526 (ports 1): nothing new, skipping HID & Ports enum
01:36:21.714 (loader): handle b30
01:36:21.714 (loader): Device came online, code_size = 100
01:36:21.729 (loader): Board is: NXP IMXRT1062 ROM
01:36:21.729 (loader): begin operation
01:36:21.745 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.hex", 21504 bytes
01:36:21.745 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex", 21504 bytes, and 4992 loader utility
01:36:21.761 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
01:36:21.761 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex". 21504 bytes
01:36:21.776 (loader): reboot too soon timer still running, oh no!
01:36:21.808 (loader): set background IMG_ONLINE
01:36:21.820 (loader): nxp_write: success
01:36:21.825 (loader): HAB locked secure mode
01:36:21.825 (loader): sending ehex loader utility, 4992 bytes
01:36:21.841 (loader): nxp_write: success
01:36:21.856 (loader): nxp_write: success
01:36:21.872 (loader): nxp_write: success
01:36:21.872 (loader): run it..
01:36:21.888 (loader): ehex loader utility sucessfully started
01:36:21.903 (loader): end operation, total time = 0.174 seconds
01:36:21.903 (loader): redraw timer set, image 80 to show for 2000 ms
01:36:21.931 (ports 1): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
01:36:21.934 (ports 1): nothing new, skipping HID & Ports enum
01:36:21.966 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:21.981 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:21.981 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/3
01:36:21.997 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/3
01:36:21.997 (loader): HID/win32: vid:046D pid:C52B ver:1211 usb:0/140000/0/9/4/2/4
01:36:22.275 (ports 1): WM_DEVICECHANGE DBT_DEVICEARRIVAL
01:36:22.277 (ports 1): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000ecf8e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
01:36:22.277 (ports 1): found_usb_device, loc=usb:0/140000/0/6/1/1 Port_#0001.Hub_#0010
01:36:22.277 (ports 1): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
01:36:22.277 (ports 1): found_usb_device, devinst=0000001f
01:36:22.277 (ports 1): add: loc=usb:0/140000/0/6/1/1, class=HID, vid=16C0, pid=0478, ver=0107, serial=000ecf8e, dev=\\?\usb#vid_16c0&pid_0478#000ecf8e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
01:36:22.277 (ports 1): hiddev_from_devinst_list: iface=0
01:36:22.278 (ports 1): found_usb_device complete
01:36:22.279 (ports 1): usb_add: usb:0/140000/0/6/1/1 [no_device] (Teensy 4.1) Bootloader
01:36:22.486 (loader): encryption is required, public key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
01:36:22.486 (loader): Device came online, code_size = 8126464
01:36:22.496 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.07
01:36:22.506 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.hex", 21504 bytes
01:36:22.516 (loader): File "C:\T_Drive\tCode\PJRC\USB-Serial-Print-Speed-Test\USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex", 21504 bytes, and 4992 loader utility
01:36:22.526 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
01:36:22.526 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex". 21504 bytes, 0% used
01:36:22.536 (loader): File "USB-Serial-Print-Speed-Test.ino.TEENSY41.hex" opened, but "USB-Serial-Print-Speed-Test.ino.TEENSY41.ehex" will actually be used
01:36:22.577 (loader): set background IMG_ONLINE
01:36:22.736 (loader): HID/win32: HidD_GetPreparsedData ok, device still online :-)
01:37:08.327 (ports 1): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
01:37:08.328 (ports 1): update_usb_device, devinst list change, old had 1, new has 2
01:37:08.328 (ports 1): hiddev_from_devinst_list: iface=0
01:37:08.329 (ports 1): hid, found devinst=00000020
01:37:08.329 (ports 1): hid, path=\\?\hid#vid_16c0&pid_0478#8&3742ec8f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
01:37:08.329 (ports 1): hid, opened handle
01:37:08.329 (ports 1): devinst=00000020, location=usb:0/140000/0/6/1/1
01:37:08.329 (ports 1): vid=16C0, pid=0478, ver=0107, usepage=FF9C, use=0025
01:37:08.329 (ports 1): devpath=\\?\hid#vid_16c0&pid_0478#8&3742ec8f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
01:37:08.329 (ports 1): usb_add: usb:0/140000/0/6/1/1 hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
01:37:08.429 (ports 1): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
01:37:08.430 (ports 1): nothing new, skipping HID & Ports enum
