Adding MTP to a Teensy 4.1 project (and 3.2) that is already SERIAL + MIDI
Davidelvig
Is this possible?
I've tried the MTP examples after downloading from each of these :
I'm doing this on a Teensy 4.1 board... and not yet seeing a new USB connected drive on my MacBook, so two questions:
  1. How can I best get started to "see" a USB-connected Teensy's SD card in Mac Finder?
  2. Would this be possible to do while also having the Serial port support Serial and MIDI
It would be sooooo good!
Is this possible?
Sorry not sure on why you're not seeing it. The example for MTP_Teensy worked for me without any issues but that was on a PC. Could you test connecting it to with a windows box just in case it's a MAC related issue? You'll probably find it not working there too but worth checking it's consistent.
Beyond that my first check would be that the Teensy can read/write the SD card. If it can't read and write the card then MTP isn't going to work. If it doesn't work check which filesystem the card is formatted to or try a different card.
On question 2, possible but it involves editing the usb library. You would need to edit usb_desc.h and possibly usb_desc.c to add a new USB operating mode with the options you want. By using the existing options as examples it shouldn't be too tricky to work out what's needed but it'll certainly look intimidating at first.
Thanks, @AndyA
On further attempts, I noted that Arduino was not seeing a Serial port for terminal output. A reset of the selected Teensy allowed me to see this output from setup()
MTP_test
SDIO Storage 0 254 sdio 0 0
SD Storage 1 10 sd1 failed or missing
**** dir of sd[0] ****
LOGS/
midi/
test1.txt
Setup done
1001 12 1 0:
1002 16 1 0:  1
So, "sd1 failed or missing"
I have an off-the-shelf Teensy 4.1 in my enclosure, with a uSD card that had files readable using the SD library in my own app with
code like:
if (SD.begin(SD_CARD_Pin)) {
     SD.open("/");
Any ideas?
I'm using the unmodified code in mtp-test.ino
from the MTP_t4 library
(I've not yet tested it on Windows, but I expect I have a lower-level failure based on the error at startup)
MTP_test
LOGS/
midi/
test1.txt
I think that
is indicating that the built in SD card interface is mounting the card correctly, taking a quick look at the example code I think the second error is attempting to mount an SPI connected SD card which you probably don't have.
If the directory listing given matches your card then it's managing to read the card.
Got it. It does indeed match the root directory of the Teensy-mounted SD card.
It does work on Windows, but not the Mac.
Hmmm
David:
You cannot use MTP with the Mac Finder as this is a MicroSoft protocol that has not been implemented on the Mac. However there are several apps you can download that will read this protocol, google is your friend.
Regards,
Ed
Thanks, @AndyA!
I'll ping @KurtE and @WMXZ
(or maybe I've just pinged them by mentioning them)
Sorry, I seldom use a MAC. My 12+ year old one is currently sitting in cabinet.
But if I remember correctly, mostly used something with the name like: Android File Transfer app... I believe done by Android...
I tried a few other things several years ago, There are some that you can purchase that have free trial period...
I only used Windows, and know that it works on Ubuntu. I recall that Mac's were always an issue. Old story: Apple-Microsoft
For MTP on MacOS, use the Android File Transfer program.
You can drag and drop files between it and Finder. But if you double click a file, you'll get a message it has to be dragged over to your Mac. Not quite seamless, but it's the best I've seen for MTP on MacOS.
Android File Transfer worked after a reboot!
This offers some real possibilities!
Thanks, all!
and using the Example_3_simple_SD.ino example from the MTP_Teensy library
So, my mission now is to explore getting Serial+MIDI+MTP(Very Beta) working for a serial port type.
I'd welcome collaborators on this... particularly those smarter than I.
I'm working in VS Code generally.
Where might I find the proper copies of
to peruse?
(or within Arduino IDE for that matter)
On MacOS using Arduino IDE 2.2.x, the Teensyduino files are installed in a hidden "Library" folder in your home directory. On my Macbook Air using the lastest beta, the full pathname is /Users/paul/Library/Arduino15/packages/teensy/hardware/avr/0.59.6/cores/teensy4/usb_desc.h. If you find this file on you Mac and edit it, Arduino IDE should automatically notice the change and recompile as needed. Best to start with a quick sanity check, just add any syntax error and make sure a Verify results in a compile error to confirm you're editing the right file and Arduino IDE really is using it.
I have this working on MacOS using the Example_3_simple_SD file.
I had to quit google drive and dropbox, which intercepted the connection before Android File Transfer could get there.
Question: Does the 'MTP.loop()' function set up an interrupt, or anything else I need to worry about. I am running an ADC at 250 kHz using an interrupt driven by one of the timers.
run MTP.loop() in loop() (lowest priority) and if ADC is running on elevated priority then there is no issue, Anyhow, I, myself, only call MTP.loop() when ADC is stopped, or I'm not interested in captured data. MTP_teensy may run MTP.loop using a 20Hz timer: I would stop this timer during acquisition.
Thanks.
I have a spare switch, so have adopted the strategy of rebooting and running only the MTP code when that pin is low. With MacOS and Android File Transfer, I am having trouble with other apps grabbing the Serial connection.
I would like to find some clearer documentation. Does MTP.loop() actually need to be in the Arduino loop? Does it need to be called periodically? How is the USB port divided between MTP and the Arduino serial interface?
I do not know of a simple way to set interrupt priorities on the Teensy. There is a forum thread from several years ago; it was not trivial then.
MPT.loop() simply communicates with PC and handles USB-MTP-requests. Each call to MTP.loop() handles a single MTP request by PC.
Other USB requests by PC and Teensy (e.g. USB-Serial) are handled in parallel (transparently).
USB per se is handled at an elevated priority level.
Running MTP-loop in Arduino loop only ensures that all other activities, Audio, Timer, etc. that run at elevated priority level are not disturbed.
If you do not call MTP.loop() than MTP requests by PC are simply not answered by Teensy. If you call MTP.loop(), but there is no MTP request by PC, Teensy does nothing and MTP.loop() returns immediately. However if you happen to copy a large file via MTP from PC to Teensy or viseversa, MTP.loop() will not return until request is satisfied. So better run MTP.loop in Arduino loop which runs at lowest priority.
