unsigned int ns_to_clocks(float ns, float freq)
float clocks = ceilf(ns * 1.0e-9f * freq);
if (clocks < 1.0f) return 1;
return (unsigned int)clocks;
bool sdram_init()
// use PLL3 PFD1 664.62 divided by 4 or 5, for 166 or 133 MHz
const unsigned int clockdiv = 5;
CCM_CBCDR = (CCM_CBCDR & ~(CCM_CBCDR_SEMC_PODF(7))) |
CCM_CBCDR_SEMC_CLK_SEL | CCM_CBCDR_SEMC_ALT_CLK_SEL |
CCM_CBCDR_SEMC_PODF(clockdiv-1);
delayMicroseconds(1);
const float freq = 664.62e6 / (float)clockdiv;
CCM_CCGR3 |= CCM_CCGR3_SEMC(CCM_CCGR_ON);
// software reset
SEMC_BR0 = 0;
SEMC_BR1 = 0;
SEMC_BR2 = 0;
SEMC_BR3 = 0;
SEMC_BR4 = 0;
SEMC_BR5 = 0;
SEMC_BR6 = 0;
SEMC_BR7 = 0;
SEMC_BR8 = 0;
SEMC_MCR = SEMC_MCR_SWRST;
elapsedMicros timeout = 0;
while (SEMC_MCR & SEMC_MCR_SWRST) {
if (timeout > 1500) return false;
// configure pins
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_00 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_01 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_02 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_03 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_04 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_05 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_06 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_07 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_08 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_09 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_10 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_11 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_12 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_13 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_14 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_15 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_16 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_17 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_18 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_19 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_20 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_21 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_22 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_23 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_24 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_25 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_26 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_27 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_28 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_29 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_30 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_31 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_32 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_33 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_34 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_35 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_36 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_37 = 0x10;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_38 = 0;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_39 = 0x10;
// TODO: configure pad registers for 200 MHz, fast drive, hyst?
// TODO: IOMUXC_SEMC_I_IPP_IND_DQS4_SELECT_INPUT not needed?
// turn on SEMC hardware, same settings as NXP's SDK
SEMC_MCR |= SEMC_MCR_MDIS | SEMC_MCR_CTO(0xFF) | SEMC_MCR_BTO(0x1F);
// TODO: reference manual page 1364 says "Recommend to set BMCR0 with 0x0 for
// applications that require restrict sequence of transactions", same on BMCR1
SEMC_BMCR0 = SEMC_BMCR0_WQOS(5) | SEMC_BMCR0_WAGE(8) |
SEMC_BMCR0_WSH(0x40) | SEMC_BMCR0_WRWS(0x10);
SEMC_BMCR1 = SEMC_BMCR1_WQOS(5) | SEMC_BMCR1_WAGE(8) |
SEMC_BMCR1_WPH(0x60) | SEMC_BMCR1_WRWS(0x24) | SEMC_BMCR1_WBR(0x40);
SEMC_MCR &= ~SEMC_MCR_MDIS;
// configure SDRAM parameters
SEMC_BR0 = 0x80000000 | SEMC_BR_MS(13 /*13 = 32 Mbyte*/) | SEMC_BR_VLD;
SEMC_SDRAMCR0 = SEMC_SDRAMCR0_CL(3) |
SEMC_SDRAMCR0_COL(3) | // 3 = 9 bit column
SEMC_SDRAMCR0_BL(3) | // 3 = 8 word burst length
SEMC_SDRAMCR0_PS; // use 16 bit data
SEMC_SDRAMCR1 =
SEMC_SDRAMCR1_ACT2PRE(ns_to_clocks(42, freq)) | // tRAS: ACTIVE to PRECHARGE
SEMC_SDRAMCR1_CKEOFF(ns_to_clocks(42, freq)) | // self refresh
SEMC_SDRAMCR1_WRC(ns_to_clocks(12, freq)) | // tWR: WRITE recovery
SEMC_SDRAMCR1_RFRC(ns_to_clocks(67, freq)) | // tRFC or tXSR: REFRESH recovery
SEMC_SDRAMCR1_ACT2RW(ns_to_clocks(18, freq)) | // tRCD: ACTIVE to READ/WRITE
SEMC_SDRAMCR1_PRE2ACT(ns_to_clocks(18, freq)); // tRP: PRECHARGE to ACTIVE/REFRESH
SEMC_SDRAMCR2 = 0; // TODO... page 1425
//#define SEMC_SDRAMCR2_ITO(n) ((uint32_t)(n & 0xFF)<<24)
//#define SEMC_SDRAMCR2_ACT2ACT(n) ((uint32_t)(n & 0xFF)<<16)
//#define SEMC_SDRAMCR2_REF2REF(n) ((uint32_t)(n & 0xFF)<<8)
//#define SEMC_SDRAMCR2_SRRC(n) ((uint32_t)(n & 0xFF)<<0)
SEMC_SDRAMCR3 = 0; // TODO...page 1426
//#define SEMC_SDRAMCR3_UT(n) ((uint32_t)(n & 0xFF)<<24)
//#define SEMC_SDRAMCR3_RT(n) ((uint32_t)(n & 0xFF)<<16)
//#define SEMC_SDRAMCR3_PRESCALE(n) ((uint32_t)(n & 0xFF)<<8)
//#define SEMC_SDRAMCR3_REBL(n) ((uint32_t)(n & 0x07)<<1)
//#define SEMC_SDRAMCR3_REN ((uint32_t)(1<<0))
SEMC_IPCR1 = 2; // IP commadns, data is 16 bits wide
SEMC_IPCR2 = 0;
// TODO: send IP commands to initialize SDRAM chip
// precharge all
// auto refresh (NXP SDK sends this twice, why?)
// mode set
// enable refresh
SEMC_SDRAMCR3 |= SEMC_SDRAMCR3_REN;
// TODO: configure MPU to allow read/write, disallow exec, use cache
return true; // hopefully SDRAM now working at 80000000 to 81FFFFFF
Serial.println("SDRAM Init Experiment");
if (sdram_init()) {
Serial.println(":-)");
Serial.println("nope :(");
Thanks PaulHere's my initial and incomplete (see SEMC_SDRAMCR2, SEMC_SDRAMCR3, IP commands) attempt to convert it all to Teensy. Hopefully this at least helps get things started...
FLASHMEM void configure_sdram_pins()
// initialize pins
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_00 = 0x0110F9; //SEMC_D0
/* Slew Rate Field: Fast Slew Rate
Drive Strength Field: R0/7
Speed Field: max(200MHz)
Open Drain Enable Field: Open Drain Disabled
Pull / Keep Enable Field: Pull/Keeper Enabled
Pull / Keep Select Field: Keeper
Pull Up / Down Config. Field: 100K Ohm Pull Down
Hyst. Enable Field: Hysteresis Enabled */
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_01 = 0x0110F9; //SEMC_D0
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_02 = 0x0110F9; //SEMC_D1
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_03 = 0x0110F9; //SEMC_D2
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_04 = 0x0110F9; //SEMC_D3
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_05 = 0x0110F9; //SEMC_D4
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_06 = 0x0110F9; //SEMC_D5
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_07 = 0x0110F9; //SEMC_D6
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_08 = 0x0110F9; //SEMC_DMO
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_08 = 0x0110F9; //SEMC_A0
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_10 = 0x0110F9; //SEMC_A1
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_11 = 0x0110F9; //SEMC_A2
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_12 = 0x0110F9; //SEMC_A3
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_13 = 0x0110F9; //SEMC_A4
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_14 = 0x0110F9; //SEMC_A5
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_15 = 0x0110F9; //SEMC_A6
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_16 = 0x0110F9; //SEMC_A7
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_17 = 0x0110F9; //SEMC_A8
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_18 = 0x0110F9; //SEMC_A9
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_19 = 0x0110F9; //SEMC_A11
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_20 = 0x0110F9; //SEMC_A12
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_21 = 0x0110F9; //SEMC_BA0
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_22 = 0x0110F9; //SEMC_BA1
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_23 = 0x0110F9; //SEMC_A10
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_24 = 0x0110F9; //SEMC_CAS
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_25 = 0x0110F9; //SEMC_RAS
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_26 = 0x0110F9; //SEMC_CLK
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_27 = 0x0110F9; //SEMC_CKE
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_28 = 0x0110F9; //SEMC_WE
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_29 = 0x0110F9; //SEMC_CS0
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_30 = 0x0110F9; //SEMC_D8
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_31 = 0x0110F9; //SEMC_D9
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_32 = 0x0110F9; //SEMC_D10
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_33 = 0x0110F9; //SEMC_D11
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_34 = 0x0110F9; //SEMC_D12
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_35 = 0x0110F9; //SEMC_D13
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_36 = 0x0110F9; //SEMC_D14
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_37 = 0x0110F9; //SEMC_D15
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_38 = 0x0110F9; //SEMC_DM1
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_39 = 0x0110F9; //SEMC_DQS
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_40 = 0x0110F9; //SEMC_MD0
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_41 = 0x0110F9; //SEMC_MD1
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_00 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_01 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_02 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_03 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_04 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_05 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_06 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_07 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_08 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_10 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_11 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_12 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_13 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_14 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_15 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_16 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_17 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_18 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_19 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_20 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_21 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_22 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_23 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_24 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_25 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_26 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_27 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_28 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_29 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_30 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_31 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_32 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_33 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_34 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_35 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_36 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_37 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_38 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_39 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_40 = 0x00;
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_41 = 0x00;
- {pin_num: E3, peripheral: SEMC, signal: 'DATA, 00', pin_signal: GPIO_EMC_00, hysteresis_enable: Enable, pull_up_down_config: Pull_Down_100K_Ohm, pull_keeper_enable: Enable,
open_drain: Disable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: F3, peripheral: SEMC, signal: 'DATA, 01', pin_signal: GPIO_EMC_01, hysteresis_enable: Enable, pull_keeper_enable: Enable, speed: MHZ_200, drive_strength: R0_7,
slew_rate: Fast}
- {pin_num: F4, peripheral: SEMC, signal: 'DATA, 02', pin_signal: GPIO_EMC_02, hysteresis_enable: Enable, pull_keeper_enable: Enable, speed: MHZ_200, drive_strength: R0_7,
slew_rate: Fast}
- {pin_num: G4, peripheral: SEMC, signal: 'DATA, 03', pin_signal: GPIO_EMC_03, hysteresis_enable: Enable, pull_keeper_enable: Enable, speed: MHZ_200, drive_strength: R0_7,
slew_rate: Fast}
- {pin_num: F2, peripheral: SEMC, signal: 'DATA, 04', pin_signal: GPIO_EMC_04, hysteresis_enable: Enable, pull_keeper_enable: Enable, speed: MHZ_200, drive_strength: R0_7,
slew_rate: Fast}
- {pin_num: G5, peripheral: SEMC, signal: 'DATA, 05', pin_signal: GPIO_EMC_05, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: H5, peripheral: SEMC, signal: 'DATA, 06', pin_signal: GPIO_EMC_06, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: H4, peripheral: SEMC, signal: 'DATA, 07', pin_signal: GPIO_EMC_07, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: H3, peripheral: SEMC, signal: 'DM, 0', pin_signal: GPIO_EMC_08, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: C2, peripheral: SEMC, signal: 'ADDR, 00', pin_signal: GPIO_EMC_09, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: G1, peripheral: SEMC, signal: 'ADDR, 01', pin_signal: GPIO_EMC_10, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: G3, peripheral: SEMC, signal: 'ADDR, 02', pin_signal: GPIO_EMC_11, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: H1, peripheral: SEMC, signal: 'ADDR, 03', pin_signal: GPIO_EMC_12, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: A6, peripheral: SEMC, signal: 'ADDR, 04', pin_signal: GPIO_EMC_13, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: B6, peripheral: SEMC, signal: 'ADDR, 05', pin_signal: GPIO_EMC_14, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: B1, peripheral: SEMC, signal: 'ADDR, 06', pin_signal: GPIO_EMC_15, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: A5, peripheral: SEMC, signal: 'ADDR, 07', pin_signal: GPIO_EMC_16, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: A4, peripheral: SEMC, signal: 'ADDR, 08', pin_signal: GPIO_EMC_17, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: B2, peripheral: SEMC, signal: 'ADDR, 09', pin_signal: GPIO_EMC_18, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: B4, peripheral: SEMC, signal: 'ADDR, 11', pin_signal: GPIO_EMC_19, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: A3, peripheral: SEMC, signal: 'ADDR, 12', pin_signal: GPIO_EMC_20, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: C1, peripheral: SEMC, signal: 'BA, 0', pin_signal: GPIO_EMC_21, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: F1, peripheral: SEMC, signal: 'BA, 1', pin_signal: GPIO_EMC_22, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: G2, peripheral: SEMC, signal: 'ADDR, 10', pin_signal: GPIO_EMC_23, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: D3, peripheral: SEMC, signal: semc_cas, pin_signal: GPIO_EMC_24, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: D2, peripheral: SEMC, signal: semc_ras, pin_signal: GPIO_EMC_25, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: B3, peripheral: SEMC, signal: semc_clk, pin_signal: GPIO_EMC_26, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: A2, peripheral: SEMC, signal: semc_cke, pin_signal: GPIO_EMC_27, hysteresis_enable: Enable, pull_keeper_select: Keeper, speed: MHZ_200, drive_strength: R0_7,
slew_rate: Fast}
- {pin_num: D1, peripheral: SEMC, signal: semc_we, pin_signal: GPIO_EMC_28, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: E1, peripheral: SEMC, signal: 'CS, 0', pin_signal: GPIO_EMC_29, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: C6, peripheral: SEMC, signal: 'DATA, 08', pin_signal: GPIO_EMC_30, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: C5, peripheral: SEMC, signal: 'DATA, 09', pin_signal: GPIO_EMC_31, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: D5, peripheral: SEMC, signal: 'DATA, 10', pin_signal: GPIO_EMC_32, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: C4, peripheral: SEMC, signal: 'DATA, 11', pin_signal: GPIO_EMC_33, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: D4, peripheral: SEMC, signal: 'DATA, 12', pin_signal: GPIO_EMC_34, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: E5, peripheral: SEMC, signal: 'DATA, 13', pin_signal: GPIO_EMC_35, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: C3, peripheral: SEMC, signal: 'DATA, 14', pin_signal: GPIO_EMC_36, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: E4, peripheral: SEMC, signal: 'DATA, 15', pin_signal: GPIO_EMC_37, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: D6, peripheral: SEMC, signal: 'DM, 1', pin_signal: GPIO_EMC_38, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: B7, peripheral: SEMC, signal: semc_dqs, pin_signal: GPIO_EMC_39, software_input_on: Enable, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7,
slew_rate: Fast}
- {pin_num: A7, peripheral: SEMC, signal: semc_rdy, pin_signal: GPIO_EMC_40, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
- {pin_num: C7, peripheral: SEMC, signal: 'CSX, 0', pin_signal: GPIO_EMC_41, hysteresis_enable: Enable, speed: MHZ_200, drive_strength: R0_7, slew_rate: Fast}
WOW - runaway train! Good to have @PaulStoffregen input/update/assistance and great to have @mjs513 onboard.I give up - I will play along with the dev. But curiosity got to me and you know what they say "curiosity kills the cat but satisfaction brought him back."But @defragster may have it all done by the time I get the board
I'll IM you with my info.
#define SDRAM_Read 0x08 /* SDRAM memory read. */
#define SDRAM_Write 0x09 /* SDRAM memory write. */
#define SDRAM_Modeset 0x0a /* SDRAM MODE SET. */
#define SDRAM_Active 0x0b /* SDRAM active. */
#define SDRAM_AutoRefresh 0x0c /* SDRAM auto-refresh. */
#define SDRAM_SelfRefresh 0x0d /* SDRAM self-refresh. */
#define SDRAM_Precharge 0x0e /* SDRAM precharge. */
#define SDRAM_Prechargeall 0x0f /* SDRAM precharge all. */
#define SEMC_IPCMD_KEY(n) (((uint32_t)(((uint32_t)(n)) << 16)) & 0xFFFF0000U)
bool SendIPCommand(uint32_t address, uint16_t command, uint32_t write, uint32_t *read)
uint32_t cmdMode;
bool readCmd = 0;
bool writeCmd = 0;
/* Clear status bit */
SEMC_INTR |= 0x1U;
/* Set address. */
SEMC_IPCR0= address;
/* Check command mode. */
cmdMode = command & 0xFU;
readCmd = (cmdMode == SDRAM_Read);
writeCmd = (cmdMode == SDRAM_Write) || (cmdMode == SDRAM_Modeset);
if (writeCmd)
/* Set data. */
SEMC_IPTXDAT = write;
/* Set command code. */
SEMC_IPCMD = command | SEMC_IPCMD_KEY(0xA55A);
/* Wait for command done. */
bool result = IPCommandComplete();
if (result != true)
return result;
if (readCmd)
/* Get the read data */
*read = SEMC_IPRXDAT;
return true;
bool IPCommandComplete()
/* Poll status bit till command is done*/
while (!(SEMC_INTR & 0x1))
SEMC_INTR |= 0x1;
/* Check error status */
if (SEMC_INTR & 0x2)
SEMC_INTR |= 0x2;
return false;
return true;
bool sdram_init()
// software reset
SEMC_BR0 = 0;
SEMC_BR1 = 0;
SEMC_BR2 = 0;
SEMC_BR3 = 0;
SEMC_BR4 = 0;
SEMC_BR5 = 0;
SEMC_BR6 = 0;
SEMC_BR7 = 0;
SEMC_BR8 = 0;
configure_sdram_pins();
SEMC_SDRAMCR1 =
SEMC_SDRAMCR2 =
SEMC_SDRAMCR2_SRRC((ns_to_clocks(67, freq) - 1)) |
SEMC_SDRAMCR2_REF2REF(ns_to_clocks(60, freq)) | /* No Minus one to keep with RM */
SEMC_SDRAMCR2_ACT2ACT(ns_to_clocks(60, freq)) | /* No Minus one to keep with RM */
SEMC_SDRAMCR2_ITO(0);
//sdk has: idle = config->tIdleTimeout_Ns / config->tPrescalePeriod_Ns
//RM states
/* SEMC closes all opened pages if the SDRAM idle time lasts more than idle timeout period. SDRAM is
considered idle when there is no AXI Bus transfer and no SDRAM command pending.
00000000b - IDLE timeout period is 256*Prescale period.
00000001-11111111b - IDLE timeout period is ITO*Prescale period.
uint32_t prescaleperiod = 160 * (1000000000 / freq);
uint16_t prescale = prescaleperiod / 16 / (1000000000 / freq);
if (prescale > 256)
Serial.println("Invalid Timer Setting");
while(1){}
uint16_t refresh = (64 * 1000000 / 8192)/ prescaleperiod;
uint16_t urgentRef = refresh;
//uint16_t idle = 0 / prescaleperiod;
SEMC_SDRAMCR3 = SEMC_SDRAMCR3_REBL((1 - 1)) |
/* N * 16 * 1s / clkSrc_Hz = config->tPrescalePeriod_Ns */
SEMC_SDRAMCR3_PRESCALE(prescale) | SEMC_SDRAMCR3_RT(refresh) | SEMC_SDRAMCR3_UT(urgentRef);
SEMC_IPCR2 = 0;
// precharge all
// mode set
bool result_cmd = SendIPCommand(0x80000000, SDRAM_Prechargeall, 0, NULL);
if (result_cmd != true)
return result_cmd;
result_cmd = SendIPCommand(0x80000000, SDRAM_AutoRefresh, 0, NULL);
return result_cmd;
return result_cmd;
/* Mode setting value. */
uint16_t mode = (uint16_t)3| (uint16_t)(3 << 4);
result_cmd = SendIPCommand(0x80000000, SDRAM_Modeset, mode, NULL);
return result_cmd;
// enable refresh
if(result_cmd == false) return false;
if (sdram_init()) {
// initialize pins
/* Default to Pauls version
// configure pins
I see that little cap - I have an iron ... if I get it off it'll never go back on ... will wait a day or so for confirmation.@Paul So it's confirmed that C29 should be removed?
If that's the case, then @defragster, remove this capacitor on the top side. I hope you got a hot air station or an iron.
EVKB SDRAM 16MB - with two summary samples:test Pattern 00000000 Write 650314 us Read/Test 589825 us
test RndSeed 2976674124 Write 654314 us Read/Test 617310 us
test ran for 72.08 seconds
All memory tests passed![]()
Calc of the Psudo Rand values is WAY slower on EVKB - it is full debug build and not sure I got 'Optimize 0' removed.test Pattern 00000000 Write 51837 us Read/Test 150381 us
test RndSeed 2976674124 Write 146802 us Read/Test 254228 us
test ran for 20.27 seconds
SEMC SDRAM Example End.
And EVKB SDRAM:test Pattern 5A698421 Write 651565 us Read/Test 589824 us
test Pattern 55555555 Write 650310 us Read/Test 589825 us
test Pattern 33333333 Write 650326 us Read/Test 589825 us
test Pattern 0F0F0F0F Write 650323 us Read/Test 589825 us
test Pattern 00FF00FF Write 650327 us Read/Test 589825 us
test Pattern 0000FFFF Write 650330 us Read/Test 589825 us
test Pattern AAAAAAAA Write 650331 us Read/Test 589825 us
test Pattern CCCCCCCC Write 650324 us Read/Test 589825 us
test Pattern F0F0F0F0 Write 650323 us Read/Test 589825 us
test Pattern FF00FF00 Write 650327 us Read/Test 589825 us
test Pattern FFFF0000 Write 650310 us Read/Test 589825 us
test Pattern FFFFFFFF Write 650328 us Read/Test 589825 us
test RndSeed 1438200953 Write 654320 us Read/Test 617309 us
test RndSeed 3413783263 Write 656345 us Read/Test 617310 us
test RndSeed 1900517911 Write 654325 us Read/Test 617310 us
test RndSeed 1227909400 Write 654335 us Read/Test 617309 us
test RndSeed 276562754 Write 654321 us Read/Test 617309 us
test RndSeed 146878114 Write 654316 us Read/Test 617310 us
test RndSeed 615545407 Write 654314 us Read/Test 617309 us
test RndSeed 110497896 Write 654309 us Read/Test 617309 us
test RndSeed 74539250 Write 654315 us Read/Test 617309 us
test RndSeed 4197336575 Write 654321 us Read/Test 617310 us
test RndSeed 2280382233 Write 654304 us Read/Test 617309 us
test RndSeed 542894183 Write 654320 us Read/Test 617310 us
test RndSeed 3978544245 Write 654323 us Read/Test 617310 us
test RndSeed 2315909796 Write 654325 us Read/Test 617310 us
test RndSeed 3736286001 Write 654308 us Read/Test 617310 us
test RndSeed 2876690683 Write 654329 us Read/Test 617309 us
test RndSeed 215559886 Write 654319 us Read/Test 617310 us
test RndSeed 539179291 Write 654305 us Read/Test 617309 us
test RndSeed 537678650 Write 654313 us Read/Test 617310 us
test RndSeed 4001405270 Write 654308 us Read/Test 617310 us
test RndSeed 2169216599 Write 655318 us Read/Test 617310 us
test RndSeed 4036891097 Write 654318 us Read/Test 617310 us
test RndSeed 1535452389 Write 654310 us Read/Test 617309 us
test RndSeed 2959727213 Write 654306 us Read/Test 617309 us
test RndSeed 4219363395 Write 654332 us Read/Test 617309 us
test RndSeed 1036929753 Write 654314 us Read/Test 617309 us
test RndSeed 2125248865 Write 654306 us Read/Test 617310 us
test RndSeed 3177905864 Write 654319 us Read/Test 617309 us
test RndSeed 2399307098 Write 654315 us Read/Test 617309 us
test RndSeed 3847634607 Write 654315 us Read/Test 617310 us
test RndSeed 27467969 Write 654324 us Read/Test 617310 us
test RndSeed 520563506 Write 654324 us Read/Test 617310 us
test RndSeed 381313790 Write 654315 us Read/Test 617310 us
test RndSeed 4174769276 Write 656346 us Read/Test 617309 us
test RndSeed 3932189449 Write 654319 us Read/Test 617310 us
test RndSeed 4079717394 Write 654313 us Read/Test 617310 us
test RndSeed 868357076 Write 654309 us Read/Test 617310 us
test RndSeed 2474062993 Write 654312 us Read/Test 617309 us
test RndSeed 1502682190 Write 654316 us Read/Test 617310 us
test RndSeed 2471230478 Write 656343 us Read/Test 617310 us
test RndSeed 85016565 Write 654330 us Read/Test 617310 us
test RndSeed 1427530695 Write 654318 us Read/Test 617309 us
test RndSeed 1100533073 Write 654325 us Read/Test 617309 us
test Pattern 5A698421 Write 51842 us Read/Test 150170 us
test Pattern 55555555 Write 51840 us Read/Test 150381 us
test Pattern 33333333 Write 51831 us Read/Test 150382 us
test Pattern 0F0F0F0F Write 51837 us Read/Test 150383 us
test Pattern 00FF00FF Write 51834 us Read/Test 150382 us
test Pattern 0000FFFF Write 51839 us Read/Test 150381 us
test Pattern AAAAAAAA Write 51838 us Read/Test 150383 us
test Pattern CCCCCCCC Write 51835 us Read/Test 150382 us
test Pattern F0F0F0F0 Write 51837 us Read/Test 150383 us
test Pattern FF00FF00 Write 51836 us Read/Test 150381 us
test Pattern FFFF0000 Write 51837 us Read/Test 150383 us
test Pattern FFFFFFFF Write 51834 us Read/Test 150381 us
test RndSeed 1438200953 Write 146801 us Read/Test 254208 us
test RndSeed 3413783263 Write 146801 us Read/Test 254228 us
test RndSeed 1900517911 Write 146800 us Read/Test 254226 us
test RndSeed 1227909400 Write 146801 us Read/Test 254216 us
test RndSeed 276562754 Write 146800 us Read/Test 254206 us
test RndSeed 146878114 Write 146801 us Read/Test 254199 us
test RndSeed 615545407 Write 146801 us Read/Test 254194 us
test RndSeed 110497896 Write 146801 us Read/Test 254191 us
test RndSeed 74539250 Write 146801 us Read/Test 254200 us
test RndSeed 4197336575 Write 146801 us Read/Test 254196 us
test RndSeed 2280382233 Write 146801 us Read/Test 254232 us
test RndSeed 542894183 Write 146800 us Read/Test 254196 us
test RndSeed 3978544245 Write 146800 us Read/Test 254187 us
test RndSeed 2315909796 Write 146801 us Read/Test 254200 us
test RndSeed 3736286001 Write 146801 us Read/Test 254204 us
test RndSeed 2876690683 Write 146801 us Read/Test 254231 us
test RndSeed 215559886 Write 146800 us Read/Test 254215 us
test RndSeed 539179291 Write 146801 us Read/Test 254209 us
test RndSeed 537678650 Write 146801 us Read/Test 254222 us
test RndSeed 4001405270 Write 146801 us Read/Test 254232 us
test RndSeed 2169216599 Write 146801 us Read/Test 254213 us
test RndSeed 4036891097 Write 146801 us Read/Test 254169 us
test RndSeed 1535452389 Write 146801 us Read/Test 254212 us
test RndSeed 2959727213 Write 146800 us Read/Test 254198 us
test RndSeed 4219363395 Write 146800 us Read/Test 254197 us
test RndSeed 1036929753 Write 146800 us Read/Test 254193 us
test RndSeed 2125248865 Write 146801 us Read/Test 254226 us
test RndSeed 3177905864 Write 146801 us Read/Test 254231 us
test RndSeed 2399307098 Write 146801 us Read/Test 254227 us
test RndSeed 3847634607 Write 146801 us Read/Test 254208 us
test RndSeed 27467969 Write 146801 us Read/Test 254197 us
test RndSeed 520563506 Write 146801 us Read/Test 254203 us
test RndSeed 381313790 Write 146801 us Read/Test 254215 us
test RndSeed 4174769276 Write 146801 us Read/Test 254214 us
test RndSeed 3932189449 Write 146800 us Read/Test 254187 us
test RndSeed 4079717394 Write 146801 us Read/Test 254204 us
test RndSeed 868357076 Write 146801 us Read/Test 254218 us
test RndSeed 2474062993 Write 146801 us Read/Test 254185 us
test RndSeed 1502682190 Write 146800 us Read/Test 254191 us
test RndSeed 2471230478 Write 146801 us Read/Test 254232 us
test RndSeed 85016565 Write 146800 us Read/Test 254232 us
test RndSeed 1427530695 Write 146801 us Read/Test 254208 us
test RndSeed 1100533073 Write 146800 us Read/Test 254202 us
SEMC_MCR |= SEMC_MCR_MDIS | SEMC_MCR_CTO(0xFF) | SEMC_MCR_BTO(0x1F) | SEMC_MCR_DQSMD;
teensyDIY.name=Teensy DIY SDRAM
#teensyDIY.upload.maximum_size=16515072
teensyDIY.build.board=TEENSY_SDRAM
SEMC SDRAM Example Start!
SEMC_INIT................
(INIT) busTimeoutCycles: 31, 0x1
(INIT) SEMC_MCR_BTO: 0x1f000000, 0x0
(INIT) dqsMode: 1, SEMC_MCR_DQSMD: 0x4
(INIT) MCR: 0x1f000006
(INIT) BMCR0: 0x104085, BMCR1: 0x40602485
(INIT) Enable SEMC: MCR 0x1f000004
ConfigureSDRAM................
(ConfigureSDRAM) refreshPeriod_nsPerRow: 7812
(ConfigureSDRAM) tPrescalePeriod_Ns: 960
(ConfigureSDRAM) refreshUrgThreshold: 7812
(ConfigureSDRAM) tIdleTimeout_Ns: 0
(ConfigureSDRAM) refresh: 8
(ConfigureSDRAM) urgentRef: 8
(ConfigureSDRAM) idle: 0
(ConfigureSDRAM) csxPinMux: 3
(ConfigureSDRAM) iocReg: 0x0
(ConfigureSDRAM) memsize_kbytes: 32768
(ConfigureSDRAM) memsize: 13
(ConfigureSDRAM) base->BR[cs]: 0x8000001b
(ConfigureSDRAM)
burstLen: 3
(ConfigureSDRAM) casLatency: 3
(ConfigureSDRAM) columnAddrBitNum: 3
(ConfigureSDRAM) portSize: 1
(ConfigureSDRAM) SEMC_SDRAMCR0_BL: 48
(ConfigureSDRAM) SEMC_SDRAMCR0_COL: 768
(ConfigureSDRAM) SEMC_SDRAMCR0_CL: 3072
(ConfigureSDRAM) SDRAMCR0: 0xf31
(ConfigureSDRAM) IOCR: 0x0
(ConfigureSDRAM) Precharge2Act_Ns: 18
(ConfigureSDRAM) Act2ReadWrite_Ns: 18
(ConfigureSDRAM) RefreshRecovery_Ns: 67
(ConfigureSDRAM) WriteRecovery_Ns: 12
(ConfigureSDRAM) CkeOff_Ns: 42
(ConfigureSDRAM) Act2Prechage_Ns: 42
(ConfigureSDRAM) SEMC_SDRAMCR1_PRE2ACT: 2
(ConfigureSDRAM) SEMC_SDRAMCR1_ACT2RW: 32
(ConfigureSDRAM) SEMC_SDRAMCR1_RFRC: 2560
(ConfigureSDRAM) SEMC_SDRAMCR1_WRC: 8192
(ConfigureSDRAM) SEMC_SDRAMCR1_CKEOFF: 393216
(ConfigureSDRAM) SEMC_SDRAMCR1_ACT2PRE: 6291456
(ConfigureSDRAM) SDRAMCR1: 0x662a22
(ConfigureSDRAM) SelfRefRecovery_Ns: 67
(ConfigureSDRAM) Refresh2Refresh_Ns: 60
(ConfigureSDRAM) Act2Act_Ns: 60
(ConfigureSDRAM) SDRAMCR2: 0xa0a0a
(ConfigureSDRAM) refreshBurstLen: 1
(ConfigureSDRAM) SEMC_SDRAMCR3_REBL: 0x0
(ConfigureSDRAM) SEMC_SDRAMCR3_PRESCALE: 0xa00
(ConfigureSDRAM) SEMC_SDRAMCR3_RT(refresh): 0x80000
(ConfigureSDRAM) SEMC_SDRAMCR3_UT(refresh): 0x8000000
(ConfigureSDRAM) SDRAMCR3: 0x8080a00
(ConfigureSDRAM) IPCR1: 0x2
(ConfigureSDRAM) IPCR2: 0x0
(ConfigureSDRAM) mode: 51
(ConfigureSDRAM) Enables refresh SDRAMCR3: 0x8080a01
SEMC SDRAM Memory 32 bit Write Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Memory 32 bit Write Time (uS) 130
SEMC SDRAM Read 32 bit Data Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Memory 32 bit Read Time (uS) 231
SEMC SDRAM 32 bit Data Write and Read Compare Start!
SEMC SDRAM Memory 32 bit R/W Time (uS) 106
SEMC SDRAM 32 bit Data Write and Read Compare Succeed!
SEMC SDRAM Memory 16 bit Write Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Memory 16 bit Write Time (uS) 204
SEMC SDRAM Read 16 bit Data Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Memory 16 bit Read Time (uS) 128
SEMC SDRAM 16 bit Data Write and Read Compare Start!
SEMC SDRAM Memory 16 bit Read/Write Time (uS) 104
SEMC SDRAM 16 bit Data Write and Read Compare Succeed!
SEMC SDRAM Memory 8 bit Write Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Memory 8 bit Write Time (uS) 147
SEMC SDRAM Read 8 bit Data Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Memory 8 bit Read Time (uS) 121
SEMC SDRAM 8 bit Data Write and Read Compare Start!
SEMC SDRAM 8 bit Data Write and Read Compare Succeed!
SEMC SDRAM Memory 8 bit Read/Write Time (uS) 5039
+=1Good Morning all and Merry Christmas
Can code for that be posted ?? : https://github.com/Defragster/EVKB_1060/tree/main/srcOk did a dump of the registers and setup from the EVKB for future reference:
Sounds very interesting!
needs fixed ... Paren was not MISSING ... it is EXTRA at end of lineSCB_MPU_RBAR = 0x80000000 | REGION(i++); // SDRAM
SCB_MPU_RASR = MEM_CACHE_WBWA | READWRITE | NOEXEC | SIZE_32M;
SDRAM_p57: In function 'bool sdram_init()':
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\cores\teensy4/imxrt.h:8540:66: error: expected ';' before ')' token
8540 | #define SEMC_SDRAMCR0_BL((uint32_t)(n & 0x07)<<4))
C:\Users\TimLabs\Documents\GitHub\EVKB_1060\examples\SDRAM_p57\SDRAM_p57.ino:109:9: note: in expansion of macro 'SEMC_SDRAMCR0_BL'
109 | SEMC_SDRAMCR0_BL(3) | // 3 = 8 word burst length
Error compiling for board Teensy 4.1.
if (sdram_init()) {
Uploaded the version of fsl_semc.c that I have all the printf in for debugging. No not for TEENSY_SDRAM - may do laterCan code for that be posted ?? : https://github.com/Defragster/EVKB_1060/tree/main/src
And is there an equivalent for Board: TEENSY_SDRAM
As far as I know,is this essential for cache?
Yep forgot to mention that with everything else going on.Paren was not MISSING ... it is EXTRA at end of line
Success!!!!!!!! Great sign.GOOD RESULT:
// uncomment to enable SEMC_MCR_DQSMD (EMC_39) but make sure you comment out the above line first
//SEMC_MCR |= SEMC_MCR_MDIS | SEMC_MCR_CTO(0xFF) | SEMC_MCR_BTO(0x1F) | SEMC_MCR_DQSMD;
Defragster is really the only one that can try. I could try as I have a board but I’m not really up to speed on what files to swap out in the core and such. So I’ll just hang back and let Defragster test until you also get your board.@defragster - @Dogbone06
Created a version 1 of the Teensy_sdram sketch that cleans code up a little and added the test cases that are in the EVKB example.
Be interesting to see if it worksI did check to see if it compiles without errors.
Merry Christmas![]()
Compile Time:: T:\T_Drive\tCode\RAM\teensyEVKB_xRAM_memtest\teensyEVKB_xRAM_memtest.ino Dec 25 2023 13:02:47
EXTMEM Memory Test, 16 Mbyte
EXTMEM Memory begin, 80000000
EXTMEM Memory end, 81000000
test Pattern 00000000 Write 64278 us Read/Test 176638 us
test RndSeed 2976674124 Write 119371 us Read/Test 278054 us
test ran for 20.60 seconds
testing with fixed pattern 5A698421
testing with pseudo-random sequence, seed=2976674124
testing with pseudo-random sequence, seed=1438200953
testing with pseudo-random sequence, seed=3413783263
testing with pseudo-random sequence, seed=1900517911
testing with pseudo-random sequence, seed=1227909400
testing with pseudo-random sequence, seed=276562754
testing with pseudo-random sequence, seed=146878114
testing with pseudo-random sequence, seed=615545407
testing with pseudo-random sequence, seed=110497896
testing with pseudo-random sequence, seed=74539250
testing with pseudo-random sequence, seed=4197336575
testing with pseudo-random sequence, seed=2280382233
testing with pseudo-random sequence, seed=542894183
testing with pseudo-random sequence, seed=3978544245
testing with pseudo-random sequence, seed=2315909796
testing with pseudo-random sequence, seed=3736286001
testing with pseudo-random sequence, seed=2876690683
testing with pseudo-random sequence, seed=215559886
testing with pseudo-random sequence, seed=539179291
testing with pseudo-random sequence, seed=537678650
testing with pseudo-random sequence, seed=4001405270
testing with pseudo-random sequence, seed=2169216599
testing with pseudo-random sequence, seed=4036891097
testing with pseudo-random sequence, seed=1535452389
testing with pseudo-random sequence, seed=2959727213
testing with pseudo-random sequence, seed=4219363395
testing with pseudo-random sequence, seed=1036929753
testing with pseudo-random sequence, seed=2125248865
testing with pseudo-random sequence, seed=3177905864
testing with pseudo-random sequence, seed=2399307098
testing with pseudo-random sequence, seed=3847634607
testing with pseudo-random sequence, seed=27467969
testing with pseudo-random sequence, seed=520563506
testing with pseudo-random sequence, seed=381313790
testing with pseudo-random sequence, seed=4174769276
testing with pseudo-random sequence, seed=3932189449
testing with pseudo-random sequence, seed=4079717394
testing with pseudo-random sequence, seed=868357076
testing with pseudo-random sequence, seed=2474062993
testing with pseudo-random sequence, seed=1502682190
testing with pseudo-random sequence, seed=2471230478
testing with pseudo-random sequence, seed=85016565
testing with pseudo-random sequence, seed=1427530695
testing with pseudo-random sequence, seed=1100533073
testing with fixed pattern 55555555
testing with fixed pattern 33333333
testing with fixed pattern 0F0F0F0F
testing with fixed pattern 00FF00FF
testing with fixed pattern 0000FFFF
testing with fixed pattern AAAAAAAA
testing with fixed pattern CCCCCCCC
testing with fixed pattern F0F0F0F0
testing with fixed pattern FF00FF00
testing with fixed pattern FFFF0000
testing with fixed pattern FFFFFFFF
testing with fixed pattern 00000000
test Pattern 5A698421 Write 64380 us Read/Test 176636 us
test Pattern 55555555 Write 64278 us Read/Test 176636 us
test Pattern 33333333 Write 64278 us Read/Test 176633 us
test Pattern 0F0F0F0F Write 64278 us Read/Test 176634 us
test Pattern 00FF00FF Write 64278 us Read/Test 176636 us
test Pattern 0000FFFF Write 64279 us Read/Test 176634 us
test Pattern AAAAAAAA Write 64279 us Read/Test 176636 us
test Pattern CCCCCCCC Write 64278 us Read/Test 176636 us
test Pattern F0F0F0F0 Write 64278 us Read/Test 176633 us
test Pattern FF00FF00 Write 64278 us Read/Test 176634 us
test Pattern FFFF0000 Write 64279 us Read/Test 176635 us
test Pattern FFFFFFFF Write 64279 us Read/Test 176636 us
test RndSeed 1438200953 Write 118847 us Read/Test 278058 us
test RndSeed 3413783263 Write 118846 us Read/Test 278058 us
test RndSeed 1900517911 Write 119376 us Read/Test 278061 us
test RndSeed 1227909400 Write 119375 us Read/Test 278059 us
test RndSeed 276562754 Write 118846 us Read/Test 278055 us
test RndSeed 146878114 Write 118846 us Read/Test 278060 us
test RndSeed 615545407 Write 118847 us Read/Test 278055 us
test RndSeed 110497896 Write 119378 us Read/Test 278058 us
test RndSeed 74539250 Write 119367 us Read/Test 278057 us
test RndSeed 4197336575 Write 119374 us Read/Test 278058 us
test RndSeed 2280382233 Write 118847 us Read/Test 278060 us
test RndSeed 542894183 Write 118847 us Read/Test 278056 us
test RndSeed 3978544245 Write 118846 us Read/Test 278056 us
test RndSeed 2315909796 Write 118846 us Read/Test 278058 us
test RndSeed 3736286001 Write 118847 us Read/Test 278056 us
test RndSeed 2876690683 Write 119356 us Read/Test 278056 us
test RndSeed 215559886 Write 119372 us Read/Test 278058 us
test RndSeed 539179291 Write 119357 us Read/Test 278061 us
test RndSeed 537678650 Write 118846 us Read/Test 278058 us
test RndSeed 4001405270 Write 118847 us Read/Test 278060 us
test RndSeed 2169216599 Write 119366 us Read/Test 278057 us
test RndSeed 4036891097 Write 118846 us Read/Test 278055 us
test RndSeed 1535452389 Write 119380 us Read/Test 278057 us
test RndSeed 2959727213 Write 119375 us Read/Test 278057 us
test RndSeed 4219363395 Write 118846 us Read/Test 278056 us
test RndSeed 1036929753 Write 118846 us Read/Test 278060 us
test RndSeed 2125248865 Write 119352 us Read/Test 278055 us
test RndSeed 3177905864 Write 118846 us Read/Test 278058 us
test RndSeed 2399307098 Write 118846 us Read/Test 278057 us
test RndSeed 3847634607 Write 119358 us Read/Test 278057 us
test RndSeed 27467969 Write 119369 us Read/Test 278057 us
test RndSeed 520563506 Write 119372 us Read/Test 278059 us
test RndSeed 381313790 Write 118846 us Read/Test 278060 us
test RndSeed 4174769276 Write 118846 us Read/Test 278056 us
test RndSeed 3932189449 Write 118846 us Read/Test 278058 us
test RndSeed 4079717394 Write 118846 us Read/Test 278058 us
test RndSeed 868357076 Write 118847 us Read/Test 278056 us
test RndSeed 2474062993 Write 118847 us Read/Test 278057 us
test RndSeed 1502682190 Write 118847 us Read/Test 278057 us
test RndSeed 2471230478 Write 118846 us Read/Test 278054 us
test RndSeed 85016565 Write 118846 us Read/Test 278059 us
test RndSeed 1427530695 Write 118846 us Read/Test 278055 us
test RndSeed 1100533073 Write 118846 us Read/Test 278059 us
All memory tests passed :-)
that works too! Added code was seen when doing posted sketch for prior post.@defragster - @Dogbone06
SDRAM Memory 32 bit Write Time (uS) 62
SDRAM Memory 32 bit Read Time (uS) 171
SDRAM Memory 32 bit R/W Time (uS) 27
SDRAM Memory 16 bit Write Time (uS) 21
SDRAM Memory 16 bit Read Time (uS) 14
SDRAM Memory 16 bit Read/Write Time (uS) 28
SDRAM Memory 8 bit Write Time (uS) 28
SDRAM Memory 8 bit Read Time (uS) 14
SDRAM Memory 8 bit Read/Write Time (uS) 31
SDRAM Example End.
Compile Time:: T:\T_Drive\tCode\RAM\teensyEVKB_xRAM_memtest\teensyEVKB_xRAM_memtest.ino Dec 25 2023 13:29:59
EXTMEM Memory Test, 32 Mbyte
EXTMEM Memory end, 82000000
test Pattern 5A698421 Write 128759 us Read/Test 353272 us
test Pattern 55555555 Write 128658 us Read/Test 353267 us
test Pattern 33333333 Write 128658 us Read/Test 353267 us
test Pattern 0F0F0F0F Write 128658 us Read/Test 353271 us
test Pattern 00FF00FF Write 128657 us Read/Test 353268 us
test Pattern 0000FFFF Write 128657 us Read/Test 353278 us
test Pattern AAAAAAAA Write 128658 us Read/Test 353267 us
test Pattern CCCCCCCC Write 128657 us Read/Test 353270 us
test Pattern F0F0F0F0 Write 128658 us Read/Test 353271 us
test Pattern FF00FF00 Write 128658 us Read/Test 353271 us
test Pattern FFFF0000 Write 128657 us Read/Test 353265 us
test Pattern FFFFFFFF Write 128657 us Read/Test 353265 us
test Pattern 00000000 Write 128657 us Read/Test 353272 us
test RndSeed 2976674124 Write 237690 us Read/Test 556117 us
test RndSeed 1438200953 Write 238736 us Read/Test 556114 us
test RndSeed 3413783263 Write 237690 us Read/Test 556115 us
test RndSeed 1900517911 Write 237691 us Read/Test 556119 us
test RndSeed 1227909400 Write 238759 us Read/Test 556114 us
test RndSeed 276562754 Write 237689 us Read/Test 556114 us
test RndSeed 146878114 Write 237691 us Read/Test 556118 us
test RndSeed 615545407 Write 237690 us Read/Test 556115 us
test RndSeed 110497896 Write 237691 us Read/Test 556121 us
test RndSeed 74539250 Write 237690 us Read/Test 556115 us
test RndSeed 4197336575 Write 238770 us Read/Test 556115 us
test RndSeed 2280382233 Write 237690 us Read/Test 556114 us
test RndSeed 542894183 Write 237691 us Read/Test 556115 us
test RndSeed 3978544245 Write 237690 us Read/Test 556115 us
test RndSeed 2315909796 Write 237691 us Read/Test 556117 us
test RndSeed 3736286001 Write 237690 us Read/Test 556118 us
test RndSeed 2876690683 Write 238749 us Read/Test 556119 us
test RndSeed 215559886 Write 237691 us Read/Test 556116 us
test RndSeed 539179291 Write 237690 us Read/Test 556119 us
test RndSeed 537678650 Write 238746 us Read/Test 556115 us
test RndSeed 4001405270 Write 237691 us Read/Test 556114 us
test RndSeed 2169216599 Write 238751 us Read/Test 556113 us
test RndSeed 4036891097 Write 237691 us Read/Test 556115 us
test RndSeed 1535452389 Write 237691 us Read/Test 556118 us
test RndSeed 2959727213 Write 237690 us Read/Test 556119 us
test RndSeed 4219363395 Write 237690 us Read/Test 556116 us
test RndSeed 1036929753 Write 237690 us Read/Test 556116 us
test RndSeed 2125248865 Write 238748 us Read/Test 556112 us
test RndSeed 3177905864 Write 237691 us Read/Test 556116 us
test RndSeed 2399307098 Write 237691 us Read/Test 556115 us
test RndSeed 3847634607 Write 237690 us Read/Test 556115 us
test RndSeed 27467969 Write 237690 us Read/Test 556116 us
test RndSeed 520563506 Write 238733 us Read/Test 556120 us
test RndSeed 381313790 Write 238746 us Read/Test 556115 us
test RndSeed 4174769276 Write 237690 us Read/Test 556115 us
test RndSeed 3932189449 Write 237690 us Read/Test 556114 us
test RndSeed 4079717394 Write 237690 us Read/Test 556116 us
test RndSeed 868357076 Write 237691 us Read/Test 556115 us
test RndSeed 2474062993 Write 237690 us Read/Test 556116 us
test RndSeed 1502682190 Write 237690 us Read/Test 556120 us
test RndSeed 2471230478 Write 237690 us Read/Test 556118 us
test RndSeed 85016565 Write 237690 us Read/Test 556119 us
test RndSeed 1427530695 Write 237690 us Read/Test 556117 us
test RndSeed 1100533073 Write 237691 us Read/Test 556115 us
test ran for 41.20 seconds
many hours of work to be a REAL board:
