Custom Teensy and Lockable code
jensa
Hi all,
I'm making a custom board and want to protect the firmware. The process is explained well for boards made by PJRC, but in my case I'm buying the core parts from PJRC and putting them on my own boards. I asked PJRC the following:
So just so I'm sure that I understand this correctly - any MKL02 (from PJRC) can enable this on any iMXRT1060 (from anywhere)? It's the Teensy 4 Security Tool that enables this using firmware in the MKL02 chip?
Paul then replied:
1: Only specific iMXRT1060 chips are supported, as documented on the web page. For example, "1064" parts definitely do not work. Parts with an extra "X" in the part number also will not work. Only specific flash memory chips are supported. Pay attention to "M" vs "Q" in the part number!
2: Yes, a MKL02 chip from PJRC pairs with a brand new IMXRT1062 chip as sold by NXP through distributors. Once paired, that MKL02 only works with that specific IMXRT1062.
3: Custom boards begin the same as Lockable Teensy. Details are thoroughly documented on the code security page. If you haven't already, I would highly recommend you buy at least one Lockable Teensy so you can experience the process of locking before you design a custom PCB. Try using it with Arduino IDE on another PC that doesn't have your key.pem file. Also try copying only the .hex or .ehex file and open it with Teensy Loader on another PC. This stuff is all documented, but there's really no substitute for experiencing it first hand.
Posting his reply here as Paul suggested, so others can find the answer via search. My core takeaway is that for any Teensy from PJRC, these fuses are pre-programmed. On a custom board and a blank MIMXRT1062DVJ6B, you are free to set the fuses as you like. When you set them to be locked (Tools > Teensy 4 Security), they're permanent.
Yes, the IMXRT fuse memory absolutely is permanent. Setting a fuse bit physically alters the chip in an irreversible way. NXP doesn't give details of how it's implemented, but the on-chip technology is likely amorphous silicon anti-fuse.
The MKL02 chip will pair with your IMXRT1062 on first use. Part of that process involves setting some of the fuses as needed by all Teensy boards.
When Teensy 4.0 was released in late 2019 and Teensy 4.1 in early 2020, those fuses were set only by PJRC's bed-of-nails test fixture. We couldn't sell the bootloader chips at that time, because they depended upon the test fixture to configure the fuses and do other stuff. The MKL02 bootloader chips became available in 2021 when the pairing process was added. It allows a pre-programmed MKL02 to initialize the IMXRT1062 chip without needing the PJRC test fixture.
When you run the 3 setup programs for code security, step #1 sets fuses with your encryption key. After step #1, your board can run both encrypted .ehex and also regular plaintext .hex. In this mode you code is NOT secure even if encrypted. All 3 steps run checks, but step #2 is purely a verification which doesn't set any fuses. Step #3 sets the fuses needed to permanently set secure mode. Once in secure mode, your board will only run encrypted .ehex files created with your key.pem file.
PJRC signed a non-disclosure agreement with NXP, so I can't talk about some aspects of the fuses and secure mode which NXP considers confidential.
But I will again mention the most important thing in practice: make backup copies of your key.pem file. If you lose your key, there is no recovery method. You need your key.pem file to create new .ehex files which work on all the boards you initialized with those 3 steps.
It still unclear to me what is different about the lockable Teensy 4s. Is it that you have configured them differently when they are made? Im making a custom Teensy 4 and need it to be lockable.
Basically the Unlocked ship with some fuses NOT preconfigured as required for a commercial product that would allow the end user to make changes that could render the device unusable for no good reason. As noted in p#2 - once set these fuses cannot be altered.
When you buy an Unlocked version those fuses needed to allow the encryption based locking are not set so that the locking feature can be activated, by a purchaser that requested that feature and knows what to do with it.
Defragster's explanation is correct. If you really want to dive into the details, you'll need the IMXRT1062 reference manual. It's linked from the Teensy 4.1 product page under "Technical Information" (scroll down near the end of that very long page).
First turn to page 1317 and look at Figure 23-2 "OTP Memory Footprint" for a visual representation of the fuse memory. This small memory starts with the bits as zeros. Writing to the fuses permanently changes 0 bits to 1 bits. Once a fuse has been changed to 1, it can never be returned to the original 0 state. It is truly permanent 1-time programmable memory.
The "LOCK" part is 32 fuses which controls whether the other portions of the fuse memory (represented with different colors in Figure 23-2) are writable. When specific bits in the LOCK fuses are written to 1, other sections of the fuse memory become forever fixed. The hardware simply does not allow writing to fuse regions of the associated bit within the LOCK fuses has been written to 1.
The critically important fuses are BOOT_CFG. You can find some details in the big fuse table on page 1302-1306, but sadly some info is "reserved" and only available from NXP under non-disclosure agreement. PJRC has signed that NDA, so much as I might like to say more, I really can't discuss details of anything marked "reserved".
But I can tell you the main difference between standard Teensy and lockable Teensy is whether those BOOT_CFG fuses are writable. With standard Teensy, the bit within the LOCK fuses that forever prohibits changes to BOOT_CFG is set. Your program can never alter those critical BOOT_CFG fuses. Standard Teensy will always boot as intended (though you can of course create programs which don't work) because you simply can not mess up the BOOT_CFG fuses.
On lockable Teensy, and on a DIY PCB where those LOCK fuses are in their original condition as NXP ships, you can indeed write to the BOOT_CFG. You should only do so with the published programs. If you write to the wrong fuses within BOOT_CFG, you could permanently configure your IMXRT1062 chip to attempt to boot in a way that does not work for your hardware. Of course, you can also have things go badly if you use those programs as intended, and then lose your key.pem file. Your key is needed to create new .ehex files. So even if you never write to BOOT_CFG incorrectly, if you lose your key.pem you will forever be unable to create new firmware which runs on all the lockable Teensy and DIY PCBs you've locked into secure mode with your (lost) key.pem. This is why the Teensy 4 Security dialog box and all the code secuity documentation and every message I write about lockable Teensy has strong advise to make backup copies of your key.pem file!
Standard Teensy is meant to be safe for experimenting and prototyping. That's why it ships with the BOOT_CFG permanently read-only. You simply can not alter its critically important boot configuration fuses. Teensy has a special restore process (that only works on unlocked boards), triggered by holding the pushbutton for 15 seconds, which fully wipes the flash memory and writes a known-good LED blink program. Together with the forever fixed BOOT_CFG, as long as the hardware is undamanged, you can always recover Standard Teensy to a known-good workgin condition from any wrong program or configuration by using that restore process.
How would I produce a Standard Teensy on a DIY PCB?
I understand that the fuses for BOOT_CFG are permanently set to read-only in Standard Teensy. Is this the only difference in the initial setup/production of the DIY PCB?
I am guessing that the Standard Teensy for sale has been pre-configured by PJRC after manufacture (or during manufacture) but before delivery to the customer. In contrast, the Lockable has not been pre-configured. I.e., once the MKL_02 and IMXRT are paired and the initial blink sketch is transferred, the Lockable Teensy is ready to ship, leaving the fused OTP prepared for a key and configuration to secure mode.
You mention that you should only program the fuses with published programs. Are you referring to the sketches produced by PJRC to enable secure mode or some other program for programming chips?
Are there published sketches that will configure the fused OTP in a way that results in a Standard Teensy? Or is it just advised to prevent OTP manipulation by activating secure mode?
PJRC T_4.x products as sold Standard or Lockable are ready to run and tested. For general use a Lockable is no different than the other - except those fuses are still open to adjustment.
The PJRC bootloader chips as noted do a one time pairing with a factory compatible NXP 1062, and the bootloader as bought knows what to do with regard to the fuses set for Standard usage or configure specific to leaving it Lockable when first properly powered up.
When Locking is an option, it is an NXP NDA controlled process that PJRC has managed to present with the Arduino provided specific sketches. Only those prepared sketches know and understand the process for creating the key.pem file and presenting it in sketch #1, then to prepare the #2 sketch to load and test is buildable to see that the key is prepared while still unlocked, then sketch #3 to commit the locking that only allows .eHex properly encoded to execute on that processor. {going by memory on the three steps}
<edit> sketch that will take a Lockable 1062 safely into Standard configuration ... see p#9, though it seems PJRC could develop that to Lock out the ability to alter the fuses in a way that would make it Locked to a key.pem file when that is not desired.
I can say that during beta testing before the sketches #1,2,3 were perfected it took a simple PJRC change to prevent the user from bricking a Teensy, so these sketches are very exacting and specific in what they do with "NDA Reserved - undocumented" areas. They expose only what is needed and with no user adjustable parts and run as a normally built Arduino sketch.
If you look at the <webpage> where the MKL02 bootloader controller for the T4 is available for purchase, search for the section titled "Disabling Boot Configuration Changes". There you will find a snippet of code (see below) for locking out any changes to the boot & security settings. Based on the statement that appears there with the code ("If this program is run before secure mode is set, it will forever prevent locking secure mode. Changes to other fuses which might affect boot are also prohibited."), it should hold true that executing this code on a lockable T4 before doing any of the steps that activate & configure the code locking mechanism (as discussed in earlier posts) should result in a normal (non-lockable) T4.
  /* Prevent changes to boot & security configuration */
  IMXRTfuseWrite(&HW_OCOTP_LOCK, 0x00400004);
Hope that helps . . .
Mark J Culross
KD5RXT
I have a question regarding the locking process. We finished the prototyping stage and starting with the production, obviously the idea is to ship the boards locked with a key that we generated. I want to create a workflow to lock the teensys as quick and easy as possible, not having to go to the security tab every time. Can I export the compiled binary of the sketches and then upload them in the correct sequence? if so, the key.pem have to be in a certain folder for everything to work or it's embeded on the code when the compiling is done?
@toyosm, Walk through the steps and take notes from the source files presented, and the resultant (e)HEX files created for use.
The Key.PEM is only needed on the Build machine.
But the first step(s) note in the sources that the PEM is essentially included in them before they are .eHex encoded IIRC
The three uploads can be handed off without the PEM or source .INO - but those first Hex files need to be secure AFAIK as they could be read and found to contain the needed key information.
Have worked with the process since it went Beta - but it has been some time - though it seems HEX is required until the PEM key is locked in for eHex usage, so it seems the transition could be vulnerable - the source file certainly are as it seems would be an unencrypted Hex file.
Hi Paul
I own a small one-man guitar pedal company, and i am working on a really exciting new product using teensy.
I have quickly realised that this is beyond my depth in terms of coding and digital pcb design/layout, especially considering I want to make my own layout without the PJRC bootloader, as I plan to have this commercially manufactured.
I would imagine you are too busy to be available to hire on this project (but let me know if you are!) however, if you would know someone you could send my way to help get this project polished up and factory ready i would really appreciate it. I have a decent budget to work with, the priority is making the best possible product for users.
Cheers
Hi Paul
Cheers
The boot loader is what makes it a Teensy. You don’t need to use it, can program directly to the mcu, but then you don’t get the Teensy code framework.
Not strictly true; PJRC's chip isn't a bootloader (it doesn't execute anything when the device is turned on), it's mostly just there to handle the power-up sequence and enable re-programming in an easy way. You can write a program using the Teensy libraries and as long as you have some way of getting it onto an attached flash chip (and the fuses on the IMXRT are set correctly to boot from it), it will work. Just like people have done the reverse, building a program using NXP's SDK and running it on Teensy.
OK, thanks guys, I have a lot to learn, I've gotten pretty far, but i'd rather have a specialist to consult with, so that the final offering is the best it could possibly be, not just the best that I can do. if anyone out there would be open to consulting i'd love to have a chat.
there's quite a few layers involved, such as lithium battery charging, analog audio front end, display screen, low latency recording etc.. and when it comes to audio, pcb design and analog/digital grounding practices need to be on point.
Hi Paul
Cheers
@Strange I would guess that Paul does not make custom PCB's, but feel free to message me and maybe I could help you out? I've done many Teensy based designs by now.
