TheQuestor
Never having worked with smd components before, how do you substitute resistors?
For what? With these things I just add them either inline or on the PCB that I attach the teensy to
Yes, ask the nocdemcu forum. We're using Teensy in this forum.
Are you sure you are using two separate Chip Selects ? One for the SD card and a second one for the TFT Display. Both CS pins need separate pullups.
That's not a problem with the display, it is a software-problem. Perhaps a problem with the SPI-Driver or whatever is used to access SPI. Do you have pullups on all chipselects ?
#include <Adafruit_GFX.h>
#include <Arduino.h>
#include <Adafruit_ILI9341.h>
#define TFT_DC D1
#define TFT_CS D2
#define SD_CS D8
//here i use hardware SPI
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
tft.begin();
tft.fillScreen(ILI9341_RED);
if (!SD.begin(SD_CS)){
Serial.println("fail");
//just to see if screen works
tft.fillScreen(ILI9341_BLUE);
SD & TFT card test
// include the SD library:
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your microprocessor IO pins !!!!!
// The numbers below reflect the Arduino and Teensy Standard numbering system
#define SD_CS 4
#define TFT_CS 20
#define TFT_DC 21
delay (2000); // Give Windoze USB Serial time to reconnect after upload
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("ILI9341 TFT using OnBoard SD Test");
tft.begin();
delay(2000); // give me a chance to look at tft screen !!
Serial.println("\n\nInitializing SD card...");
tft.println("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
//if (!SD.begin(SD_CS)) { // This seems to init the card but NO card info is read later !!
if (!card.init(SPI_FULL_SPEED, SD_CS)) { // this alternate init WORKS OK
Serial.println("initialization failed. Things to check:");
tft.println("SD initialization failed.");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
Serial.println("Wiring is correct and a card is present.");
tft.println("Wiring correct and card present.");
// print the type of card
Serial.print("\nCard type: ");
tft.print("\nCard type: ");
switch (card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
tft.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
tft.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
tft.println("SDHC");
default:
Serial.println("Unknown");
tft.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
tft.println("Could not find FAT16/FAT32 partition.");
return;
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("\nVolume type is FAT");
Serial.println(volume.fatType(), DEC);
tft.print("\nVolume type is FAT");
tft.println(volume.fatType(), DEC);
tft.println();
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
if (volumesize < 8388608ul) {
Serial.print("Volume size (bytes): ");
Serial.println(volumesize * 512); // SD card blocks are always 512 bytes
tft.print("Volume size (bytes): ");
tft.println(volumesize * 512); // SD card blocks are always 512 bytes
Serial.print("Volume size (Kbytes): ");
tft.print("Volume size (Kbytes): ");
volumesize /= 2;
Serial.println(volumesize);
Serial.print("Volume size (Mbytes): ");
tft.println(volumesize);
tft.print("Volume size (Mbytes): ");
volumesize /= 1024;
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
tft.println("\nSee Serial Terminal for\n Listing of Files found on SD Card.");
root.openRoot(volume);
// list all files in the card with date and size to Serial
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
//just loop forever... we said everything in setup !!
SD_CS: any free digital pin
SD_MOSI: 11
SD_MISO 12
SD_SCK: 13
F_CS: this is the chip select for the not populated flash memory chip
I've modified my ili9341 display a little bit.
The display is now 3.3V only - max voltage for VCC is 3.3V!
- The resistors R1, R2 and R3 are replaced with 0R resistors,
- ~10k pull-up resistors for SD_CS, TFT_CS and TFT_D/C
- the solder jumper J1 is closed.
I take it that since I have a Teensy 4.1 with a built in SD (Thanx so much Paul for helping me get the SD up and running) I should have no concerns about SD cards and the display working, as long as I connect the display to the pins shown in the device description and use the suggested libraries. Is this right??
