This is our GFX example for the Adafruit ILI9488 Breakout and Shield
----> http://www.adafruit.com/products/1651
Check out the links above for our tutorials and wiring diagrams
These displays use SPI to communicate, 4 or 5 pins are required to
interface (RST is optional)
products from Adafruit!
MIT license, all text above must be included in any redistribution
#include "SPI.h"
#include "ILI9488_t3.h"
#ifdef __MK66FX1M0__
#define __C64__ 1
#else
// Connection konfiguration of ILI9341 LCD TFT
#if defined(__C64__)
//const int cardPin = BUILTIN_SDCARD; //18; // pin that the SD is connected to (d8 for SparkFun MicroSD shield)
#define SCK 14
#define MISO 39
#define MOSI 28
#define TFT_RST 255
#define TFT_DC 20
#define TFT_CS 21
ILI9488_t3 tft = ILI9488_t3(TFT_CS, TFT_DC, TFT_RST, MOSI, SCK, MISO );
#else
// For the Adafruit shield, these are the default.
#define TFT_DC 9
#define TFT_CS 10
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
ILI9488_t3 tft = ILI9488_t3(TFT_CS, TFT_DC, 23);
uint32_t gtSum = 0;
tft.begin();
tft.fillScreen(ILI9488_BLACK);
tft.setTextColor(ILI9488_YELLOW);
tft.setTextSize(2);
tft.println("Waiting for Arduino Serial Monitor...");
while (!Serial) ; // wait for Arduino Serial Monitor
Serial.println("ILI9488 Test!");
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(ILI9488_RDMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9488_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9488_RDPIXFMT);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9488_RDIMGFMT);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9488_RDSELFDIAG);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
Serial.println(F("Benchmark Time (microseconds)"));
Serial.print(F("Screen fill "));
Serial.println(testFillScreen());
delay(200);
Serial.print(F("Text "));
Serial.println(testText());
delay(600);
Serial.print(F("Lines "));
Serial.println(testLines(ILI9488_CYAN));
delay(200);
Serial.print(F("Horiz/Vert Lines "));
Serial.println(testFastLines(ILI9488_RED, ILI9488_BLUE));
delay(200);
Serial.print(F("Rectangles (outline) "));
Serial.println(testRects(ILI9488_GREEN));
delay(200);
Serial.print(F("Rectangles (filled) "));
Serial.println(testFilledRects(ILI9488_YELLOW, ILI9488_MAGENTA));
delay(200);
Serial.print(F("Circles (filled) "));
Serial.println(testFilledCircles(10, ILI9488_MAGENTA));
Serial.print(F("Circles (outline) "));
Serial.println(testCircles(10, ILI9488_WHITE));
delay(200);
Serial.print(F("Triangles (outline) "));
Serial.println(testTriangles());
delay(200);
Serial.print(F("Triangles (filled) "));
Serial.println(testFilledTriangles());
delay(200);
Serial.print(F("Rounded rects (outline) "));
Serial.println(testRoundRects());
delay(200);
Serial.print(F("Rounded rects (filled) "));
Serial.println(testFilledRoundRects());
Serial.print(F("\n TEST SUM us = "));
Serial.println(gtSum);
delay(200);
Serial.println(F("Done!"));
void loop(void) {
for (uint8_t rotation = 0; rotation < 4; rotation++) {
tft.setRotation(rotation);
testText();
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(ILI9488_RED);
tft.fillScreen(ILI9488_GREEN);
tft.fillScreen(ILI9488_BLUE);
gtSum += micros() - start;
return micros() - start;
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(ILI9488_WHITE); tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(ILI9488_YELLOW); tft.setTextSize(2);
tft.println(1234.56);
tft.setTextColor(ILI9488_RED); tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.setTextColor(ILI9488_GREEN);
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for (x2 = 0; x2 < w; x2 += 6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for (y2 = 0; y2 < h; y2 += 6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
unsigned long start;
int x, y, w = tft.width(), h = tft.height();
start = micros();
for (y = 0; y < h; y += 5) tft.drawFastHLine(0, y, w, color1);
for (x = 0; x < w; x += 5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
int n, i, i2,
cx = tft.width() / 2,
cy = tft.height() / 2;
n = min(tft.width(), tft.height());
start = micros();
for (i = 2; i < n; i += 6) {
i2 = i / 2;
tft.drawRect(cx - i2, cy - i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
unsigned long start, t = 0;
int n, i, i2,
cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
n = min(tft.width(), tft.height()) - 1;
for (i = n; i > 0; i -= 6) {
i2 = i / 2;
start = micros();
tft.fillRect(cx - i2, cy - i2, i, i, color1);
// Outlines are not included in timing results
tft.drawRect(cx - i2, cy - i2, i, i, color2);
gtSum += t;
return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
start = micros();
for (x = radius; x < w; x += r2) {
for (y = radius; y < h; y += r2) {
tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
int x, y, r2 = radius * 2,
w = tft.width() + radius,
h = tft.height() + radius;
// Screen is not cleared for this one -- this is
// intentional and does not affect the reported time.
start = micros();
for (x = 0; x < w; x += r2) {
for (y = 0; y < h; y += r2) {
tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
int n, i, cx = tft.width() / 2 - 1,
n = min(cx, cy);
start = micros();
for (i = 0; i < n; i += 5) {
tft.drawTriangle(
cx , cy - i, // peak
cx - i, cy + i, // bottom left
cx + i, cy + i, // bottom right
tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
int i, cx = tft.width() / 2 - 1,
start = micros();
for (i = min(cx, cy); i > 10; i -= 5) {
start = micros();
tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(0, i, i));
tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(i, i, 0));
gtSum += t;
return t;
unsigned long testRoundRects() {
int w, i, i2,
w = min(tft.width(), tft.height()) - 1;
start = micros();
for (i = 0; i < w; i += 6) {
i2 = i / 2;
tft.drawRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
int i, i2,
start = micros();
for (i = min(tft.width(), tft.height()) - 1; i > 20; i -= 6) {
i2 = i / 2;
tft.fillRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(0, i, 0));
