Teensyduino 1.52 Beta #6
Paul
Administrator
Staff member
Here is a sixth (and hopefully last) beta test for Teensyduino 1.52.
My hope is to release 1.52 within the next 24-48 hours. Please give this last beta a try with any large or complex libraries and programs you may have.
Linux 32 bit:
https://www.pjrc.com/teensy/td_152-beta6/TeensyduinoInstall.linux32
Linux 64 bit:
https://www.pjrc.com/teensy/td_152-beta6/TeensyduinoInstall.linux64
Linux ARM:
https://www.pjrc.com/teensy/td_152-beta6/TeensyduinoInstall.linuxarm
Linux ARM64:
https://www.pjrc.com/teensy/td_152-beta6/TeensyduinoInstall.linuxaarch64
MacOS 10.10 to 10.15:
https://www.pjrc.com/teensy/td_152-beta6/Teensyduino_MacOS_Catalina.zip
MacOS 10.8 to 10.14:
https://www.pjrc.com/teensy/td_152-beta6/TeensyduinoInstall.dmg
Windows:
https://www.pjrc.com/teensy/td_152-beta6/TeensyduinoInstall.exe
Changes since Teensyduino 1.52-beta5:
Increase PSRAM clock to 88 MHz & fix error in writing clock setting
Use strong drive & hysteresis for FlexSPI2 pins
Disable non-working Audio PWM output on Teensy 4.x
Minor improvement in OctoWS2811 for Teensy 4.x
Win 10 install over 1.8.12 Good!
IDE Compile of recent T_4.1 PSRAM logger - using two buffers of 3.14 Million Bytes with 200,000 _isr() timer updates per second running without error where loop() does validation check on full data buffer each 983 ms during _isr() logging
Same here installed on a Win10x64 over 1.8.12 no problem.
Ran the memtest sketch @1.008Ghz successfully - all tests passed. Also ran flashtes6 which tests the FLASH (SPIFFS) along with PSRAM at 1.008GHz and no issues.
What beta #5 gives, b #6 taketh away!
The text munging at 24 MHz CPU speed https://forum.pjrc.com/threads/60864-Teensyduino-1-52-Beta-5?p=239150&viewfull=1#post239150 that b5 fixed 6 has reverted.
This https://forum.pjrc.com/threads/5732...ferent-regions?p=238989&viewfull=1#post238989 shows the issue directly. I don't care about the debug optimization but the 24 MHz would be nice for low power but I don't think I can trust it.
I don't think it's a terminal problem because:
(all 24MHz, fastest)
1. compiled loaded and ran in b5 into T4.1 result ok
2. unplug t4.1, quit b5, quit tdb5
3. start b6, plug in T4 and open terminal window still ok
4. recompile (settings will all stay the same) and run result bad
5. leave the bad in T4
6. quit b6 tdb6 and open b5 result still bad
7. try to compile and load. result compiles but won't load until the T4 button is pressed. Is this Frank's button pressing problem?
  • memory.zip
Modified your sketch and ran it on a T4.1 at 24Mhz with IDE1.8.12 and 1.52-b6. Had no issues running the modified sketch but did have an issue with your sketch in the zip. Main difference is that I am using @Frank B's library since he has changed it recently and for using the T4.1:
extern "C" uint32_t set_arm_clock(uint32_t frequency);
static uint32_t t0;
#define MHZ_MHZ 1000000
#include "T4_PowerButton.h"
   while (!Serial && millis() < 4000);
   //set_arm_clock(24 * MHZ_MHZ);
   flexRamInfo();
  // Serial.println(memfree());
Try this and see if it works for you.
I compiled the sketch from zip at 24 Mhz w/1.52b6 and there was some upload grief and print issue - though using TyComm 'GUI Bootloader button' {same USB toggle as IDE AFAIK} as not in IDE just now. Using whatever T4_PowerButton.h that was here - seems to work.
24 Mhz has been an edge case IIRC - not expected to work? Garbage spew in prints is common since T_4?
I edited build.txt to support 26 Mhz and that seems to look better. Not sure where the 'jump in function / power is'
teensy41.menu.speed.26=26 MHz
teensy41.menu.speed.26.build.fcpu=26000000
Adding this at 24 Mhz this misses some chars and sometime garb char - at 26 Mhz it scrolls perfectly:
  flexRamInfo();
Again a quick FYI - I updated to beta 6, and on the T4.1 beta thread posted a external memory allocator sketch, quick and very dirty.
Installed beta 6 over Teensyduino 1.50.
I'm getting a connection error connecting a serial terminal via USB to grblHAL built for a Teensy 4.0 with 1.52 beta 6 and using the PJRC USB library.
I can connect no problem to grblHAL built with Teensyduino 1.50 using the PJRC USB Library. Same USB cable in both cases. Teensy 4.0 in both cases.
grblHAL can also use the arduino USB class library and a serial terminal can connect to it when built with 1.52 beta 6. No problem connecting.
Since grblHAL is huge, I'm willing to do some digging to figure this out. I'm not the author of this code but am working with him. Any suggest of what to look for?
In summary:
built with 1.50, using PJRC USB Library - serial terminal connects
built with 1.52#6, using PJRC USB Library - serial terminal fails to connect
built with 1.52#6, using Arduino USB Class library - serial terminal connects
[edit] built with 1.50, using Arduino USB Class Library - serial terminal connects[/edit]
grblHAL can be found here.
Are PJRC USB Library and Arduino USB Class library referring to IDE Serial monitors or other 'libraries'?
cross post - answered below ...
Here is the source for the interface to the PJRC USB code. C++ first, .h second. Note that USB_SERIAL_GRBL == 2 causes this code to be compiled. This code remains unchanged between 1.50 and 1.52#6.
  usb_serial_pjrc.c - driver code for IMXRT1062 processor (on Teensy 4.0 board) : USB serial port wrapper, PJRC version
  Part of GrblHAL
  Copyright (c) 2018-2020 Terje Io
  Grbl is free software: you can redistribute it and/or modify
  it under the terms of the GNU General Public License as published by
  the Free Software Foundation, either version 3 of the License, or
  (at your option) any later version.
  Grbl is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  GNU General Public License for more details.
  You should have received a copy of the GNU General Public License
  along with Grbl.  If not, see <http://www.gnu.org/licenses/>.
//#include "avr/pgmspace.h"
#include "usb_serial.h"
#include "driver.h"
#if USB_SERIAL_GRBL == 2
#define BLOCK_RX_BUFFER_SIZE 20
static stream_block_tx_buffer_t txbuf = {0};
static char rxbuf[BLOCK_RX_BUFFER_SIZE];
static stream_rx_buffer_t usb_rxbuffer, usb_rxbackup;
void usb_serialInit(void)
//    usb_serial_configure(); // Done somewhere already - do not call again
    txbuf.max_length = usb_serial_write_buffer_free(); // 6144
    txbuf.max_length = (txbuf.max_length > BLOCK_TX_BUFFER_SIZE ? BLOCK_TX_BUFFER_SIZE : txbuf.max_length) - 20;
// Returns number of characters in serial input buffer
uint16_t usb_serialRxCount (void)
    uint_fast16_t tail = usb_rxbuffer.tail, head = usb_rxbuffer.head;
    return (uint16_t)BUFCOUNT(head, tail, RX_BUFFER_SIZE);
// Returns number of free characters in serial input buffer
uint16_t usb_serialRxFree (void)
    return (uint16_t)((RX_BUFFER_SIZE - 1) - BUFCOUNT(head, tail, RX_BUFFER_SIZE));
// Flushes the serial input buffer (including the USB buffer)
void usb_serialRxFlush (void)
    usb_serial_flush_input();
    usb_rxbuffer.tail = usb_rxbuffer.head;
// Flushes and adds a CAN character to the serial input buffer
void usb_serialRxCancel (void)
    usb_rxbuffer.data[usb_rxbuffer.head] = CMD_RESET;
    usb_rxbuffer.head = (usb_rxbuffer.tail + 1) & (RX_BUFFER_SIZE - 1);
// Writes a character to the serial output stream
bool usb_serialPutC (const char c)
    usb_serial_putchar(c);
    return true;
// Writes a null terminated string to the serial output stream, blocks if buffer full
void usb_serialWriteS (const char *s)
    if(*s == '\0')
        return;
    size_t length = strlen(s);
    if((length + txbuf.length) < BLOCK_TX_BUFFER_SIZE) {
        memcpy(txbuf.s, s, length);
        txbuf.length += length;
        txbuf.s += length;
        if(s[length - 1] == ASCII_LF || txbuf.length > txbuf.max_length) {
            size_t txfree;
            txbuf.s = txbuf.data;
            while(txbuf.length) {
                if((txfree = usb_serial_write_buffer_free()) > 10) {
                    length = txfree < txbuf.length ? txfree : txbuf.length;
                    usb_serial_write(txbuf.s, length); //
                    txbuf.length -= length;
                    txbuf.s += length;
                if(txbuf.length && !hal.stream_blocking_callback()) {
                    txbuf.length = 0;
                    return;
// Writes a null terminated string to the serial output stream followed by EOL, blocks if buffer full
void usb_serialWriteLn (const char *s)
    usb_serialWriteS(s);
    usb_serialWriteS(ASCII_EOL);
// Writes a number of characters from string to the serial output stream followed by EOL, blocks if buffer full
void usb_serialWrite (const char *s, uint16_t length)
    char *ptr = (char *)s;
    while(length--)
        usb_serialPutC(*ptr++);
// serialGetC - returns -1 if no data available
int16_t usb_serialGetC (void)
    uint16_t bptr = usb_rxbuffer.tail;
    if(bptr == usb_rxbuffer.head)
        return -1; // no data available else EOF
    char data = usb_rxbuffer.data[bptr++];              // Get next character, increment tmp pointer
    usb_rxbuffer.tail = bptr & (RX_BUFFER_SIZE - 1);    // and update pointer
    return (int16_t)data;
// "dummy" version of serialGetC
static int16_t serialGetNull (void)
    return -1;
bool usb_serialSuspendInput (bool suspend)
    if(suspend)
        hal.stream.read = serialGetNull;
    else if(usb_rxbuffer.backup)
        memcpy(&usb_rxbuffer, &usb_rxbackup, sizeof(stream_rx_buffer_t));
    return usb_rxbuffer.tail != usb_rxbuffer.head;
// This function get called from the systick interrupt handler,
// used here to get characters off the USB serial input stream and buffer
// them for processing by grbl. Real time command characters are stripped out
// and submitted for realtime processing.
void usb_execute_realtime (uint_fast16_t state)
    char c, *dp;
    int avail, free;
    if((avail = usb_serial_available())) {
        dp = rxbuf;
        free = usb_serialRxFree();
        free = free > BLOCK_RX_BUFFER_SIZE ? BLOCK_RX_BUFFER_SIZE : free;
        avail = usb_serial_read(rxbuf, avail > free ? free : avail);
        while(avail--) {
            c = *dp++;
            if(c == CMD_TOOL_ACK && !usb_rxbuffer.backup) {
                memcpy(&usb_rxbackup, &usb_rxbuffer, sizeof(stream_rx_buffer_t));
                usb_rxbuffer.backup = true;
                hal.stream.read = usb_serialGetC; // restore normal input
            } else if(!hal.stream.enqueue_realtime_command(c)) {
                uint32_t bptr = (usb_rxbuffer.head + 1) & (RX_BUFFER_SIZE - 1); // Get next head pointer
                if(bptr == usb_rxbuffer.tail)                                   // If buffer full
                    usb_rxbuffer.overflow = On;                                 // flag overflow,
                else {
                    usb_rxbuffer.data[usb_rxbuffer.head] = c;                   // else add character data to buffer
                    usb_rxbuffer.head = bptr;                                   // and update pointer
  usb_serial.h - driver code for IMXRT1062 processor (on Teensy 4.0 board)
  Part of GrblHAL
#ifndef _USB_SERIAL_H_
#define _USB_SERIAL_H_
#include <stdbool.h>
#include <stdint.h>
extern void usb_execute_realtime (uint_fast16_t state);
#define usb_serial_poll() usb_execute_realtime(0)
void usb_serialInit(void);
int16_t usb_serialGetC(void);
bool usb_serialPutC(const char c);
void usb_serialWriteS(const char *s);
void usb_serialWriteLn(const char *s);
void usb_serialWrite(const char *s, uint16_t length);
bool usb_serialSuspendInput (bool suspend);
uint16_t usb_serialTxCount(void);
uint16_t usb_serialRxCount(void);
uint16_t usb_serialRxFree(void);
void usb_serialRxFlush(void);
void usb_serialRxCancel(void);
  • usb_serial_pjrc.c
  • usb_serial_pjrc.h
For what it's worth, here is the arduino code wrapper that does work correctly when built with 1.52#6
C++ file:
  usb_serial_ard.cpp - driver code for IMXRT1062 processor (on Teensy 4.0 board) : USB serial port wrapper
  Part of GrblHAL
#include <string.h>
#include "Arduino.h"
#include "driver.h"
#if USB_SERIAL_GRBL == 1
#ifdef __cplusplus
extern "C" {
    SerialUSB.begin(BAUD_RATE);
#if USB_SERIAL_WAIT
    while(!SerialUSB); // Wait for connection
    txbuf.max_length = SerialUSB.availableForWrite(); // 6144 bytes
    SerialUSB.flush();
    SerialUSB.write(c);
    return true;
// Writes a null terminated string to the serial output stream, blocks if buffer full.
// Buffers locally up to 40 characters or until the string is terminated with a ASCII_LF character.
// NOTE: grbl always sends ASCII_LF terminated strings!
    if(*s == '\0')
        return;
        txbuf.s += length;
            size_t txfree;
                if((txfree = SerialUSB.availableForWrite()) > 10) {
                    SerialUSB.write((uint8_t *)txbuf.s, length); // doc is wrong - does not return bytes sent!
                    txbuf.s += length;
                    txbuf.length = 0;
                    return;
    while(length--)
    return -1;
    if(suspend)
    char c, *dp;
    int avail, free;
    if((avail = SerialUSB.available())) {
        dp = rxbuf;
        avail = SerialUSB.readBytes(rxbuf, avail > free ? free : avail);
        while(avail--) {
            c = *dp++;
                else {
#ifdef __cplusplus
.h file:
  usb_serial_ard.h - driver code for IMXRT1062 processor (on Teensy 4.0 board)
  Part of GrblHAL
#include <stdint.h>
Win10, Arduino 1.8.12, TD 1.52 beta6, T4.1 and Teensy audio shield version D, 2 PSRAM chips, using EXTRAM as part of the audio buffering --> works with partitioned convolution filtering
 * (c) DD4WH 15/05/2020
 * Real Time PARTITIONED BLOCK CONVOLUTION FILTERING (STEREO)
 * thanks a lot to Brian Millier and Warren Pratt for your help!
 * using a guitar cabinet impulse response with up to about 20000 coefficients per channel
 * uses Teensy 4.1  and Teensy audio shield rev D, uses PSRAM chip(s) soldered to underside of T4.1
 * inspired by and uses code from wdsp library by Warren Pratt
 * https://github.com/g0orx/wdsp/blob/master/firmin.c
   GNU GPL LICENSE v3
   This program is free software: you can redistribute it and/or modify
   This program is distributed in the hope that it will be useful,
   along with this program.  If not, see <http://www.gnu.org/licenses/>
#include <arm_math.h>
#include <arm_const_structs.h> // in the Teensy 4.0 audio library, the ARM CMSIS DSP lib is already a newer version
#include <utility/imxrt_hw.h> // necessary for setting the sample rate, thanks FrankB !
#include <T4_PowerButton.h> // for flexRamInfo
// USER DEFINES
// Choose only one of these impulse responses !
//#define IR1  // 512 taps // MG impulse response from bmillier github @44.1ksps
//#define IR2  // 4096 taps // impulse response @44.1ksps
//#define IR3  // 7552 taps // impulse response @44.1ksps
//#define IR4    // 17920 taps // impulse response 400ms @44.1ksps
//#define IR5    // 21632 taps // impulse response 490ms @44.1ksps
//#define IR6 // 5760 taps, 18.72% load vs. 15.00%
//#define IR7 // 22016 taps, 50.62% load, 93.48% RAM1, 32064 bytes free
//#define IR8 // 25552 taps, too much !
// about 25000 taps is MAXIMUM --> about 0.5 seconds
//#define LPMINPHASE512 // 512 taps minimum phase 2.7kHz lowpass filter
//#define LPMINPHASE1024 // 1024 taps minimum phase 2.7kHz lowpass filter
#define LPMINPHASE2048PASSTHRU // 2048 taps minimum phase 19.0kHz lowpass filter
//#define LPMINPHASE4096 // 4096 taps minimum phase 2.7kHz lowpass filter
const float32_t PROGMEM audio_gain = 2.5; // has to be adjusted from 1.0 to 10.0 depending on the filter gain / impulse resonse gain
#if defined(IR1)
#include "impulse_response_1.h"
const int nc = 512; // number of taps for the FIR filter
#elif defined(IR2)
#include "impulse_response_2.h"
const int nc = 4096; // number of taps for the FIR filter
#elif defined(IR3)
#include "impulse_response_3.h"
const int nc = 7552; // number of taps for the FIR filter
#elif defined(IR5)
#include "impulse_response_5.h"
const int nc = 21632; // number of taps for the FIR filter
#elif defined(IR6)
#include "impulse_response_6.h"
const int nc = 5760; // number of taps for the FIR filter,
#elif defined(IR7)
#include "impulse_response_7.h"
const int nc = 22016; // number of taps for the FIR filter,
#elif defined(IR8)
#include "impulse_response_8.h"
const int nc = 25552; // number of taps for the FIR filter,
#elif defined(LPMINPHASE512)
#include "lp_minphase_512.h"
const int nc = 512;
#elif defined(LPMINPHASE1024)
#include "lp_minphase_1024.h"
const int nc = 1024;
#elif defined(LPMINPHASE2048PASSTHRU)
#include "lp_minphase_2048passthru.h"
const int nc = 2048;
#elif defined(LPMINPHASE4096)
#include "lp_minphase_4096.h"
#else
#include "impulse_response_4.h"
const int nc = 17920; // number of taps for the FIR filter
//#define LATENCY_TEST
const double PROGMEM FHiCut = 2500.0;
const double PROGMEM FLoCut = -FHiCut;
// define your sample rate
const double PROGMEM SAMPLE_RATE = 44100;
// the latency of the filter is meant to be the same regardless of the number of taps for the filter
// partition size of 128 translates to a latency of 128/sample rate, ie. to 2.9msec with 44.1ksps
// latency can even be reduced by setting partitionsize to 64
// however, this only works, if you set AUDIO_BLOCK_SAMPLES to 64 in AudioStream.h
const int PROGMEM partitionsize = 128;
#define DEBUG
#define FOURPI  (2.0 * TWO_PI)
#define SIXPI   (3.0 * TWO_PI)
#define BUFFER_SIZE partitionsize
int32_t sum;
int idx_t = 0;
int16_t *sp_L;
int16_t *sp_R;
uint8_t PROGMEM FIR_filter_window = 1;
const uint32_t PROGMEM FFT_L = 2 * partitionsize;
float32_t mean = 1;
uint8_t first_block = 1;
const uint32_t PROGMEM FFT_length = FFT_L;
const int PROGMEM nfor = nc / partitionsize; // number of partition blocks --> nfor = nc / partitionsize
//float DMAMEM cplxcoeffs[nc * 2]; // this holds the initial complex coefficients for the filter BEFORE partitioning
float32_t DMAMEM maskgen[FFT_L * 2];
//float32_t DMAMEM fmask[nfor][FFT_L * 2]; //
EXTMEM float32_t fmask[nfor][FFT_L * 2]; //
float32_t DMAMEM fftin[FFT_L * 2];
float32_t accum[FFT_L * 2];
float fftout[nfor][FFT_L * 2]; //
int buffidx = 0;
int k = 0;
//int idxmask = nfor - 1;
uint32_t all_samples_counter = 0;
uint8_t no_more_latency_test = 0;
const uint32_t N_B = FFT_L / 2 / BUFFER_SIZE;
uint32_t N_BLOCKS = N_B;
float32_t DMAMEM float_buffer_L [BUFFER_SIZE * N_B];
float32_t DMAMEM float_buffer_R [BUFFER_SIZE * N_B];
float32_t DMAMEM last_sample_buffer_L [BUFFER_SIZE * N_B];
float32_t DMAMEM last_sample_buffer_R [BUFFER_SIZE * N_B];
// complex FFT with the new library CMSIS V4.5
const static arm_cfft_instance_f32 *S;
// complex iFFT with the new library CMSIS V4.5
const static arm_cfft_instance_f32 *iS;
// FFT instance for direct calculation of the filter mask
// from the impulse response of the FIR - the coefficients
const static arm_cfft_instance_f32 *maskS;
// this audio comes from the codec by I2S
AudioInputI2S            i2s_in;
AudioRecordQueue         Q_in_L;
AudioRecordQueue         Q_in_R;
AudioMixer4              mixleft;
AudioMixer4              mixright;
AudioPlayQueue           Q_out_L;
AudioPlayQueue           Q_out_R;
AudioOutputI2S           i2s_out;
AudioConnection          patchCord1(i2s_in, 0, Q_in_L, 0);
AudioConnection          patchCord2(i2s_in, 1, Q_in_R, 0);
AudioConnection          patchCord3(Q_out_L, 0, mixleft, 0);
AudioConnection          patchCord4(Q_out_R, 0, mixright, 0);
AudioConnection          patchCord9(mixleft, 0,  i2s_out, 1);
AudioConnection          patchCord10(mixright, 0, i2s_out, 0);
AudioControlSGTL5000     codec;
  while(!Serial);
  AudioMemory(10);
  codec.enable();
  codec.adcHighPassFilterDisable(); //
  codec.inputSelect(AUDIO_INPUT_LINEIN); // AUDIO_INPUT_MIC
  codec.volume(0.6);
  set_arm_clock(600000000);
     Audio Setup
  mixleft.gain(0, 1.0);
  mixright.gain(0, 1.0);
  setI2SFreq(SAMPLE_RATE);
     properly initialise variables in DMAMEM
  for(unsigned jj = 0; jj < nfor; jj++)
    for(unsigned ii = 0; ii < FFT_L * 2; ii++)
      fftout[jj][ii] = 0.1;
      fmask[jj][ii] = 0.0;
/*  for (unsigned i = 0; i < FFT_length * 2; i++)
      cplxcoeffs[i] = 0.0;
     init complex FFTs
  switch (FFT_length)
    case 128:
      S = &arm_cfft_sR_f32_len128;
      iS = &arm_cfft_sR_f32_len128;
      maskS = &arm_cfft_sR_f32_len128;
    case 256:
      S = &arm_cfft_sR_f32_len256;
      iS = &arm_cfft_sR_f32_len256;
      maskS = &arm_cfft_sR_f32_len256;
     Calculate the FFT of the FIR filter coefficients once to produce the FIR filter mask
    init_partitioned_filter_masks();
    flexRamInfo();
    Serial.print("AUDIO_BLOCK_SAMPLES:  ");     Serial.println(AUDIO_BLOCK_SAMPLES);
     begin to queue the audio from the audio library
  Q_in_L.begin();
  Q_in_R.begin();
} // END OF SETUP
  elapsedMillis msec = 0;
  elapsedMicros usec = 0;
  // are there at least N_BLOCKS buffers in each channel available ?
    if (Q_in_L.available() > N_BLOCKS + 0 && Q_in_R.available() > N_BLOCKS + 0)
      // get audio samples from the audio  buffers and convert them to float
      for (unsigned i = 0; i < N_BLOCKS; i++)
        sp_L = Q_in_L.readBuffer();
        sp_R = Q_in_R.readBuffer();
        // convert to float one buffer_size
        // float_buffer samples are now standardized from > -1.0 to < 1.0
        arm_q15_to_float (sp_L, &float_buffer_L[BUFFER_SIZE * i], BUFFER_SIZE); // convert int_buffer to float 32bit
        arm_q15_to_float (sp_R, &float_buffer_R[BUFFER_SIZE * i], BUFFER_SIZE); // convert int_buffer to float 32bit
        Q_in_L.freeBuffer();
        Q_in_R.freeBuffer();
          Digital convolution
      //  basis for this was Lyons, R. (2011): Understanding Digital Processing.
      //  "Fast FIR Filtering using the FFT", pages 688 - 694
      //  numbers for the steps taken from that source
      //  Method used here: overlap-and-save
      // ONLY FOR the VERY FIRST FFT: fill first samples with zeros
      if (first_block) // fill real & imaginaries with zeros for the first BLOCKSIZE samples
        for (unsigned i = 0; i < partitionsize * 4; i++)
          fftin[i] = 0.0;
        first_block = 0;
      {  // HERE IT STARTS for all other instances
        // fill FFT_buffer with last events audio samples
        for (unsigned i = 0; i < partitionsize; i++)
          fftin[i * 2] = last_sample_buffer_L[i]; // real
          fftin[i * 2 + 1] = last_sample_buffer_R[i]; // imaginary
      // copy recent samples to last_sample_buffer for next time!
        last_sample_buffer_L [i] = float_buffer_L[i];
        last_sample_buffer_R [i] = float_buffer_R[i];
      // now fill recent audio samples into FFT_buffer (left channel: re, right channel: im)
        fftin[FFT_length + i * 2] = float_buffer_L[i]; // real
        fftin[FFT_length + i * 2 + 1] = float_buffer_R[i]; // imaginary
#if defined(LATENCY_TEST)
        if(msec > 2000 && !no_more_latency_test)
        // latency test
        fftin[42] = 10.0; fftin[44] = -10.0;
        fftin[43] = 10.0; fftin[45] = -10.0;
        no_more_latency_test = 1;
        if(no_more_latency_test == 1) all_samples_counter += partitionsize;
          Complex Forward FFT
      // calculation is performed in-place the FFT_buffer [re, im, re, im, re, im . . .]
      arm_cfft_f32(S, fftin, 0, 1);
      for(unsigned i = 0; i < partitionsize * 4; i++)
          fftout[buffidx][i] = fftin[i];
          Complex multiplication with filter mask (precalculated coefficients subjected to an FFT)
          this is taken from wdsp library by Warren Pratt firmin.c
      k = buffidx;
          accum[i] = 0.0;
      for(unsigned j = 0; j < nfor; j++)
          for(unsigned i = 0; i < 2 * partitionsize; i= i + 4 )
            // doing 8 of these complex multiplies inside one loop saves a HUGE LOT of processor cycles
              accum[2 * i + 0] +=  fftout[k][2 * i + 0] * fmask[j][2 * i + 0] -
                                   fftout[k][2 * i + 1] * fmask[j][2 * i + 1];
              accum[2 * i + 1] +=  fftout[k][2 * i + 0] * fmask[j][2 * i + 1] +
                                   fftout[k][2 * i + 1] * fmask[j][2 * i + 0];
              accum[2 * i + 2] +=  fftout[k][2 * i + 2] * fmask[j][2 * i + 2] -
                                   fftout[k][2 * i + 3] * fmask[j][2 * i + 3];
              accum[2 * i + 3] +=  fftout[k][2 * i + 2] * fmask[j][2 * i + 3] +
                                   fftout[k][2 * i + 3] * fmask[j][2 * i + 2];
              accum[2 * i + 4] +=  fftout[k][2 * i + 4] * fmask[j][2 * i + 4] -
                                   fftout[k][2 * i + 5] * fmask[j][2 * i + 5];
              accum[2 * i + 5] +=  fftout[k][2 * i + 4] * fmask[j][2 * i + 5] +
                                   fftout[k][2 * i + 5] * fmask[j][2 * i + 4];
              accum[2 * i + 6] +=  fftout[k][2 * i + 6] * fmask[j][2 * i + 6] -
                                   fftout[k][2 * i + 7] * fmask[j][2 * i + 7];
              accum[2 * i + 7] +=  fftout[k][2 * i + 6] * fmask[j][2 * i + 7] +
                                   fftout[k][2 * i + 7] * fmask[j][2 * i + 6];
          k = k - 1;
          if(k < 0)
            k = nfor - 1;
      } // end nfor loop
      buffidx = buffidx + 1;
      if(buffidx >= nfor)
          buffidx = 0;
          Complex inverse FFT
      arm_cfft_f32(iS, accum, 1, 1);
          Overlap and save algorithm, which simply means yóu take only half of the buffer
          and discard the other half (which contains unusable time-aliased audio).
          Whether you take the left or the right part is determined by the position
          of the zero-padding in the filter-mask-buffer before doing the FFT of the
          impulse response coefficients
          //float_buffer_L[i] = accum[partitionsize * 2 + i * 2 + 0];
          //float_buffer_R[i] = accum[partitionsize * 2 + i * 2 + 1];
          float_buffer_L[i] = accum[i * 2 + 0] * audio_gain;
          float_buffer_R[i] = accum[i * 2 + 1] * audio_gain;
          Serial print the first output samples in order to check for latency
          no_more_latency_test = 2;
          for(unsigned i = 0; i < partitionsize; i++)
            if(accum[i * 2 + 0] * audio_gain > 0.1 || accum[i * 2 + 0] * audio_gain < -0.1)
              Serial.print(i + all_samples_counter - 21); Serial.print("   left:   "); Serial.println(accum[i * 2 + 0]);
              Serial.print(i + all_samples_counter - 21); Serial.print("  right:   "); Serial.println(accum[i * 2 + 1]);
          CONVERT TO INTEGER AND PLAY AUDIO - Push audio into I2S audio chain
      for (int i = 0; i < N_BLOCKS; i++)
          sp_L = Q_out_L.getBuffer();
          sp_R = Q_out_R.getBuffer();
          arm_float_to_q15 (&float_buffer_L[BUFFER_SIZE * i], sp_L, BUFFER_SIZE);
          arm_float_to_q15 (&float_buffer_R[BUFFER_SIZE * i], sp_R, BUFFER_SIZE);
          Q_out_L.playBuffer(); // play it !
          Q_out_R.playBuffer(); // play it !
          PRINT ROUTINE FOR ELAPSED MICROSECONDS
#ifdef DEBUG
      sum = sum + usec;
      idx_t++;
      if (idx_t > 400) {
        mean = sum / idx_t;
        if (mean / 29.00 / N_BLOCKS * SAMPLE_RATE / AUDIO_SAMPLE_RATE_EXACT < 100.0)
          Serial.print("processor load:  ");
          Serial.print (mean / 29.00 / N_BLOCKS * SAMPLE_RATE / AUDIO_SAMPLE_RATE_EXACT);
          Serial.println("%");
          Serial.println("100%");
        Serial.print (mean);
        Serial.print (" microsec for ");
        Serial.print (N_BLOCKS);
        Serial.print ("  stereo blocks    ");
        Serial.print("FFT-length = "); Serial.print(FFT_length);
        Serial.print(";   FIR filter length = "); Serial.println(nc);
        Serial.print("k = "); Serial.println(k);
        Serial.print("buffidx = "); Serial.println(buffidx);
        idx_t = 0;
        sum = 0;
    } // end of audio process loop
          Add button check etc. here
void init_partitioned_filter_masks()
    for(unsigned j = 0; j < nfor;j++)
      // fill with zeroes
          maskgen[i] = 0.0;
      // take part of impulse response and fill into maskgen
        // THIS IS FOR REAL IMPULSE RESPONSES OR FIR COEFFICIENTS
        // FOR COMPLEX USE THE PART BELOW
          // the position of the impulse response coeffs (right or left aligned)
          // determines the useable part of the audio in the overlap-and-save (left or right part of the iFFT buffer)
          maskgen[i * 2 + partitionsize * 2] = guitar_cabinet_impulse[i + j * partitionsize];
 *     THIS COMMENTED OUT PART IS FOR COMPLEX FILTER COEFFS
 *     // take part of impulse response and fill into maskgen
      for (unsigned i = 0; i < partitionsize * 2; i++)
          maskgen[i + partitionsize * 2] = guitar_cabinet_impulse[i + j * partitionsize * 2];
      // perform complex FFT on maskgen
      arm_cfft_f32(maskS, maskgen, 0, 1);
      // fill into fmask array
          fmask[j][i] = maskgen[i];
void setI2SFreq(int freq) {
  // thanks FrankB !
  // PLL between 27*24 = 648MHz und 54*24=1296MHz
  int n1 = 4; //SAI prescaler 4 => (n1*n2) = multiple of 4
  int n2 = 1 + (24000000 * 27) / (freq * 256 * n1);
  double C = ((double)freq * 256 * n1 * n2) / 24000000;
  int c0 = C;
  int c2 = 10000;
  int c1 = C * c2 - (c0 * c2);
  set_audioClock(c0, c1, c2, true);
       | CCM_CS1CDR_SAI1_CLK_PRED(n1-1) // &0x07
       | CCM_CS1CDR_SAI1_CLK_PODF(n2-1); // &0x3f
//Serial.printf("SetI2SFreq(%d)\n",freq);
// lowpass minimum phase filter 2048 taps
// built with Filterbuilder in MATLAB
// F6dB = 19000Hz
// Fs = 44100Hz
const float32_t guitar_cabinet_impulse [2048] =
{0.188376212697746,
0.609744257768420,
0.432502990817439,
-0.260851507457041,
-0.0716236237630232,
0.214323991136647,
-0.161365374641131,
0.0237767814580456,
0.0928163219842420,
-0.135118698255703,
0.103116320519838,
-0.0295475144538609,
-0.0446533915503357,
0.0888262290404382,
-0.0911557750322311,
0.0580364100591744,
-0.00742446990385644,
-0.0399165548550217,
0.0679648332075189,
-0.0697754031374546,
0.0480606089930208,
-0.0126844536056776,
-0.0235427462390931,
0.0492115912631957,
-0.0575291638393862,
0.0476912543045393,
-0.0243353796495332,
-0.00446813256775726,
0.0299137392110943,
-0.0450136699826800,
0.0463381524541060,
-0.0345851763595976,
0.0139767592045872,
0.00921741105173279,
-0.0285424251285965,
0.0390814455730213,
-0.0386119874843127,
0.0279589451090431,
-0.0105352974980706,
-0.00873524800102179,
0.0247861485096508,
-0.0336996884106026,
0.0336093796781321,
-0.0250239730705730,
0.0105412989482191,
0.00592966947488590,
-0.0202118528304379,
0.0288966106796321,
-0.0301253546919541,
0.0239475252971108,
-0.0121990874902116,
-0.00203728046261946,
0.0152353479811855,
-0.0242860919886000,
0.0272108262665234,
-0.0235692958460962,
0.0144860387273242,
-0.00231115168235606,
-0.00998538048902091,
0.0195315549136629,
-0.0242126167350033,
0.0231240726044307,
-0.0167259265912168,
0.00667834387745169,
0.00458806243996135,
-0.0144571785487827,
0.0207282579672892,
-0.0220968857078188,
0.0184137473816448,
-0.0106734168617837,
0.000747690181822247,
0.00906601851378224,
-0.0165730148886592,
0.0201661337829325,
-0.0191616844641809,
0.0139185196381061,
-0.00572271718460774,
-0.00352757333862824,
0.0117603244746568,
-0.0171903577031558,
0.0187012128221475,
-0.0160678963934138,
0.00997786710378808,
-0.00185292405369186,
-0.00648240726192207,
0.0132089639932368,
-0.0169068150647420,
0.0168505248746309,
-0.0131455748731331,
0.00668184799448849,
0.00107994459006863,
-0.00843785705464697,
0.0138202345969508,
-0.0161185858566201,
0.0149120519808907,
-0.0105389797836274,
0.00400494272305699,
0.00324846982046374,
-0.00966106825148907,
0.0138880530425993,
-0.0150795366710582,
0.0130481315355333,
-0.00829237191844751,
0.00187496951293478,
0.00481459402457996,
-0.0103602110852002,
0.0136174334337516,
-0.0139474658309171,
0.0113395629550761,
-0.00639908586492490,
0.000207086090721632,
0.00591611171589314,
-0.0106917262533880,
0.0131482272913238,
-0.0128170709957136,
0.00981948598120196,
-0.00482887263438223,
-0.00108049672811815,
0.00666453698583931,
-0.0107705657114569,
0.0125740258889085,
-0.0117424013581045,
0.00849413355438199,
-0.00354270088492919,
-0.00206013781719028,
0.00714753194769072,
-0.0106798867713560,
0.0119562128097787,
-0.0107517711463428,
0.00735532778085626,
-0.00250044402264655,
-0.00279298808840412,
0.00743276303887444,
-0.0104791044236197,
0.0113340455174083,
-0.00985751239547072,
0.00638787214310574,
-0.00166459799921573,
-0.00332934500175505,
0.00757182511072265,
-0.0102101837505212,
0.0107317425869680,
-0.00906228041684714,
0.00557382609659900,
-0.00100183077000674,
-0.00370987984305920,
0.00760370956078989,
-0.00990239741537146,
0.0101634042045163,
-0.00836308872246020,
0.00489489448176051,
-0.000483384635128046,
-0.00396711569277497,
0.00755767367808610,
-0.00957585416435412,
0.00963640006631904,
-0.00775386170946838,
0.00433368977848434,
-8.49040713301339e-05,
-0.00412686623812680,
0.00745553047938764,
-0.00924408543252659,
0.00915368748410902,
-0.00722702602650273,
0.00387433061402738,
0.000213995016015720,
-0.00420951561195576,
0.00731343756551010,
-0.00891592767304978,
0.00871538869336734,
-0.00677448214170173,
0.00350265810184821,
0.000430244744305489,
-0.00423110387770272,
0.00714327644611003,
-0.00859688574692890,
0.00831985781727594,
-0.00638817894834733,
0.00320623991702628,
0.000577845889882329,
-0.00420422230755352,
0.00695370755938820,
-0.00829011734114946,
0.00796439752431786,
-0.00606043638620441,
0.00297426365918490,
0.000668348067738725,
-0.00413873908641934,
0.00675097315619145,
-0.00799714208210711,
0.00764573592597484,
-0.00578411000098383,
0.00279737911659205,
0.000711272928189012,
-0.00404238114143664,
0.00653950660822658,
-0.00771835140486314,
0.00736033997901889,
-0.00555265826099363,
0.00266752385574190,
0.000714476907993315,
-0.00392119731512019,
0.00632239401439889,
-0.00745337439688967,
0.00710461772490716,
-0.00536015161618996,
0.00257775099398084,
0.000684456742274376,
-0.00377992546588345,
0.00610172373667268,
-0.00720133977424443,
0.00687504544702174,
-0.00520124827663377,
0.00252206899814197,
0.000626603728509190,
-0.00362228263502862,
0.00587885104685003,
-0.00696106295745854,
0.00666824441793309,
-0.00507115248542723,
0.00249529787694065,
0.000545413608088387,
-0.00345119405404649,
0.00565459856053961,
-0.00673117920845564,
0.00648102418965294,
-0.00496556508123985,
0.00249294308260706,
0.000444658832080773,
-0.00326897374262742,
0.00542940811343292,
-0.00651023793088230,
0.00631040396868109,
-0.00488063228965999,
0.00251108667628781,
0.000327529401254785,
-0.00307746691677087,
0.00520345593515642,
-0.00629676912583160,
0.00615362002329018,
-0.00481289629441447,
0.00254629457534224,
0.000196747573196137,
-0.00287816221080032,
0.00497673997234402,
-0.00608932979524788,
0.00600812437302589,
-0.00475924942045787,
0.00259553815911336,
5.46610972381561e-05,
-0.00267228014389187,
0.00474914613364723,
-0.00588653605217872,
0.00587157841475042,
-0.00471689289810231,
0.00265612855887354,
-9.66812386163079e-05,
-0.00246084278009891,
0.00452049849250868,
-0.00568708500629865,
0.00574184383476222,
-0.00468330049903172,
0.00272566193562468,
-0.000255468572375195,
-0.00224472851273542,
0.00429059726429047,
-0.00548976937787382,
0.00561697236353525,
-0.00465618698441342,
0.00280197420639850,
-0.000420078836367184,
-0.00202471503723905,
0.00405924742868738,
-0.00529348694273263,
0.00549519533963690,
-0.00463348108244507,
0.00288310383116996,
-0.000589039371764448,
-0.00180151292262031,
0.00382628018295628,
-0.00509724635730816,
0.00537491371378213,
-0.00461330264516409,
0.00296726146886425,
-0.000760995596880393,
-0.00157579165752979,
0.00359156884866079,
-0.00490017040570248,
0.00525468880114547,
-0.00459394354860407,
0.00305280545526029,
-0.000934686288504388,
-0.00134819962693978,
0.00335504044502553,
-0.00470149741625753,
0.00513323392771536,
-0.00457385187844132,
0.00313822217382763,
-0.00110892430118308,
-0.00111937922612877,
0.00311668390535645,
-0.00450058141655805,
0.00500940705368441,
-0.00455161901549750,
0.00322211058354557,
-0.00128258182067582,
-0.000889977980124677,
0.00287655559895149,
-0.00429689135364692,
0.00488220430706699,
-0.00452596921519763,
0.00330317023368520,
-0.00145457935847506,
-0.000660656408952999,
0.00263478269596198,
-0.00409000961923940,
0.00475075434675688,
-0.00449575128517523,
0.00338019218725197,
-0.00162387784219265,
-0.000432093225022521,
0.00239156479879718,
-0.00387963006725214,
0.00461431348209284,
-0.00445993207597534,
0.00345205238854140,
-0.00178947330163546,
-0.000204988307861821,
0.00214717412175967,
-0.00366555559253704,
0.00447226139824981,
-0.00441759145225292,
0.00351770707776175,
-0.00195039371239266,
1.99361922551272e-05,
0.00190195444374008,
-0.00344769532250594,
0.00432409735900015,
-0.00436791846953438,
0.00357618984849006,
-0.00210569760864032,
0.000241936281792610,
0.00165631903327309,
-0.00322606146501196,
0.00416943678148925,
-0.00431020852391110,
0.00362661007639303,
-0.00225447417267019,
0.000460247860766867,
0.00141074768548761,
-0.00300076581476315,
0.00400800805479338,
-0.00424386126186337,
0.00366815245041371,
-0.00239584454299186,
0.000674089559460540,
0.00116578296214420,
-0.00277201591267578,
0.00383964949693832,
-0.00416837905492251,
0.00370007736420543,
-0.00252896412056793,
0.000882666512215588,
0.000922025718001928,
-0.00254011082857845,
0.00366430631010560,
-0.00408336583058901,
0.00372172194263338,
-0.00265302563225449,
0.00108517488761338,
0.000680130029255795,
-0.00230543658988340,
0.00348202749761621,
-0.00398852615926779,
0.00373250155087642,
-0.00276726283044735,
0.00128080706506403,
0.000440797550493291,
-0.00206846122548356,
0.00329296261339980,
-0.00388366442008415,
0.00373191160767161,
-0.00287095463971551,
0.00146875733946131,
0.000204771378375336,
-0.00182972941477046,
0.00309735829331381,
-0.00376868394552629,
0.00371952955826872,
-0.00296342962768478,
0.00164822803629794,
-2.71705316225228e-05,
-0.00158985674027927,
0.00289555449090756,
-0.00364358601502350,
0.00369501687450128,
-0.00304407065165419,
0.00181843593617329,
-0.000254222319018842,
-0.00134952355758917,
0.00268798039044371,
-0.00350846863714505,
0.00365812097604112,
-0.00311231959176735,
0.00197861892336681,
-0.000475557515812779,
-0.00110946846917659,
0.00247514992320915,
-0.00336352500576895,
0.00360867695926182,
-0.00316768203793703,
0.00212804275527246,
-0.000690336602332254,
-0.000870481434291353,
0.00225765688649181,
-0.00320904158490612,
0.00354660903556421,
-0.00320973184267005,
0.00226600786956117,
-0.000897714771561881,
-0.000633396535397445,
0.00203616963724316,
-0.00304539576539728,
0.00347193163017351,
-0.00323811546271120,
0.00239185616018906,
-0.00109684986025156,
-0.000399084409077812,
0.00181142533488899,
-0.00287305302865428,
0.00338475001818441,
-0.00325255597094193,
0.00250497761252151,
-0.00128691034645716,
-0.000168444404762536,
0.00158422375348886,
-0.00269256360585783,
0.00328526048330481,
-0.00325285669383629,
0.00260481674075210,
-0.00146708337588551,
5.76035068455486e-05,
0.00135542066949194,
-0.00250455860308875,
0.00317374992697006,
-0.00323890439552313,
0.00269087875679839,
-0.00163658274885384,
0.000278127032707282,
0.00112592081866850,
-0.00230974555762463,
0.00305059487422428,
-0.00321067192636367,
0.00276273536717927,
-0.00179465678022168,
0.000492189991197148,
0.000896670487736927,
-0.00210890345773505,
0.00291625986763938,
-0.00316822030891345,
0.00282003016349443,
-0.00194059598346008,
0.000698860845755975,
0.000668649740619196,
-0.00190287719753795,
0.00277129520515672,
-0.00311170018702853,
0.00286248351911511,
-0.00207374049160058,
0.000897221255194017,
0.000442864347256569,
-0.00169257151412131,
0.00261633403004166,
-0.00304135262489355,
0.00288989695342873,
-0.00219348717898428,
0.00108637461492771,
0.000220337431859401,
-0.00147894438569319,
0.00245208872678438,
-0.00295750918246272,
0.00290215687706305,
-0.00229929636871001,
0.00126545447465140,
2.10092212065279e-06,
-0.00126299996583902,
0.00227934666293417,
-0.00286059126901612,
0.00289923768158793,
-0.00239069809028886,
0.00143363278448857,
-0.000210813137481784,
-0.00104578107821535,
0.00209896528535871,
-0.00275110876326812,
0.00288120415001753,
-0.00246729782777897,
0.00159012791201566,
-0.000417381375625844,
-0.000828361310374796,
0.00191186657255369,
-0.00262965787078947,
0.00284821312266044,
-0.00252878169059202,
0.00173421235587139,
-0.000616597899563247,
-0.000611836750970100,
0.00171903086887882,
-0.00249691820574776,
0.00280051437697256,
-0.00257492092783812,
0.00186522004562668,
-0.000807483025708662,
-0.000397317476683252,
0.00152149017814263,
-0.00235364915697378,
0.00273845075147838,
-0.00260557579236088,
0.00198255323591437,
-0.000989091913406546,
-0.000185918779961979,
0.00132032089701677,
-0.00220068547801858,
0.00266245741914861,
-0.00262069863665647,
0.00208568884349580,
-0.00116052296143840,
2.12477125691420e-05,
0.00111663610553657,
-0.00203893220389939,
0.00257306038107856,
-0.00262033627380124,
0.00217418424295477,
-0.00132092596235774,
0.000223083037085222,
0.000911577410537076,
-0.00186935884746691,
0.00247087410892524,
-0.00260463150359041,
0.00224768239306050,
-0.00146950987438703,
0.000418509856559851,
0.000706306459295395,
-0.00169299298628783,
0.00235659840023048,
-0.00257382383134186,
0.00230591629494663,
-0.00160555018929426,
0.000606481369926604,
0.000501996151823632,
-0.00151091323301473,
0.00223101442181552,
-0.00252824932950802,
0.00234871269524472,
-0.00172839579446589,
0.000785990055733125,
0.000299821647115624,
-0.00132424166722916,
0.00209497998657631,
-0.00246833963772019,
0.00237599500686053,
-0.00183747527019835,
0.000956076172632336,
0.000100951239315356,
-0.00113413579804877,
0.00194942409595531,
-0.00239462011463343,
0.00238778541676121,
-0.00193230256939718,
0.00111583595883902,
-9.34628308079320e-05,
-0.000941780090171882,
0.00179534077021721,
-0.00230770711972953,
0.00238420613136310,
-0.00201248199622436,
0.00126442941725240,
-0.000282293522894000,
-0.000748377168274348,
0.00163378224107288,
-0.00220830447101214,
0.00236547976678932,
-0.00207771246259200,
0.00140108765277887,
-0.000464448046779919,
-0.000555138734051347,
0.00146585152943555,
-0.00209719907095118,
0.00233192883775786,
-0.00212779094087045,
0.00152511964744328,
-0.000638876702290915,
-0.000363276310568136,
0.00129269450415261,
-0.00197525575620896,
0.00228397436898895,
-0.00216261510025939,
0.00163591843565438,
-0.000804581448079798,
-0.000173991874683324,
0.00111549145523233,
-0.00184341139323808,
0.00222213361108633,
-0.00218218507291035,
0.00173296659693110,
-0.000960624098187486,
1.15315175784317e-05,
0.000935448293991771,
-0.00170266828600774,
0.00214701689422472,
-0.00218660434608419,
0.00181584102516521,
-0.00110613408575673,
0.000192139046707458,
0.000753787416815930,
-0.00155408693157111,
0.00205932362310761,
-0.00217607974762636,
0.00188421691224188,
-0.00124031570687911,
0.000366713286535143,
0.000571738340750424,
-0.00139877818730210,
0.00195983744258290,
-0.00215092051137686,
0.00193787089220512,
-0.00136245476110017,
0.000534183106178842,
0.000390528200123893,
-0.00123789494139866,
0.00184942063373018,
-0.00211153645209318,
0.00197668333933658,
-0.00147192454976748,
0.000693532256147867,
0.000211372167834863,
-0.00107262332250910,
0.00172900775321373,
-0.00205843521921376,
0.00200063975064977,
-0.00156819113380346,
0.000843807521760560,
3.54639239984359e-05,
-0.000904173572336532,
0.00159959861112284,
-0.00199221869215088,
0.00200983123984183,
-0.00165081783754176,
0.000984126405509245,
-0.000136033775770629,
-0.000733770614645501,
0.00146225059844705,
-0.00191357850022756,
0.00200445407931848,
-0.00171946890338217,
0.00111368421364702,
-0.000301998299382757,
-0.000562644460262456,
0.00131807048754098,
-0.00182329074568377,
0.00198480834051689,
-0.00177391230528757,
0.00123176052334086,
-0.000461356060300356,
-0.000392020491994706,
0.00116820572929885,
-0.00172220993914445,
0.00195129559515489,
-0.00181402164824586,
0.00133772493194401,
-0.000613091042256133,
-0.000223109746575025,
0.00101383535734535,
-0.00161126221855423,
0.00190441571597266,
-0.00183977714818220,
0.00143104203139691,
-0.000756252850393931,
-5.70992923476780e-05,
0.000856160583059822,
-0.00149143791867612,
0.00184476280801277,
-0.00185126568782621,
0.00151127558377822,
-0.000889964226130819,
0.000104857230992199,
0.000696395155684493,
-0.00136378354450091,
0.00177302029166164,
-0.00184867992751158,
0.00157809182859177,
-0.00101342793912873,
0.000261648806339588,
0.000535755575474543,
-0.00122939321903299,
0.00168995517886303,
-0.00183231647479185,
0.00163126188954322,
-0.00112593298208299,
0.000412215868194025,
0.000375451276860843,
-0.00108939970367350,
0.00159641160617380,
-0.00180257314111792,
0.00167066326320188,
-0.00122686002015127,
0.000555558698097878,
0.000216674849023119,
-0.000944965060231650,
0.00149330367651757,
-0.00175994529469449,
0.00169628036843158,
-0.00131568603212921,
0.000690745295002342,
6.05924022977017e-05,
-0.000797271046413678,
0.00138160767594101,
-0.00170502134979096,
0.00170820414829734,
-0.00139198810076994,
0.000816918649712736,
-9.16658345434020e-05,
-0.000647509337066696,
0.00126235373811103,
-0.00163847742951364,
0.00170663072391484,
-0.00145544631073710,
0.000933303345574874,
-0.000239014590137417,
-0.000496871663576527,
0.00113661703832840,
-0.00156107125222132,
0.00169185911523085,
-0.00150584572682584,
0.00103921142687706,
-0.000380422214985805,
-0.000346539968691366,
0.00100550859879606,
-0.00147363530368902,
0.00166428805049061,
-0.00154307743573274,
0.00113404747840351,
-0.000514918853619526,
-0.000197676662878969,
0.000870165791299811,
-0.00137706935143732,
0.00162441188605997,
-0.00156713863076541,
0.00121731285897107,
-0.000641604034402021,
-5.14150914133227e-05,
0.000731742637047601,
-0.00127233238648892,
0.00157281569241642,
-0.00157813175682296,
0.00128860906344747,
-0.000759653626428525,
9.11497168400558e-05,
0.000591399982242034,
-0.00116043405561291,
0.00151016953638601,
-0.00157626270690655,
0.00134764016929881,
-0.000868326074798318,
0.000228969916656933,
0.000450295653712353,
-0.00104242567147836,
0.00143722202054055,
-0.00156183809302863,
0.00139421434381913,
-0.000966967865375598,
0.000361053244472949,
0.000309574689879127,
-0.000919390894196611,
0.00135479314983940,
-0.00153526162352727,
0.00142824440576757,
-0.00105501816138774,
0.000486470867110590,
0.000170359746343780,
-0.000792436177861570,
0.00126376659861295,
-0.00149702963174339,
0.00144974744893774,
-0.00113201259041353,
0.000604364625907471,
3.37417420984307e-05,
-0.000662681048416368,
0.00116508142954225,
-0.00144772577386191,
0.00145884349964673,
-0.00119758610982729,
0.000713953571117969,
-9.92291229597288e-05,
-0.000531248349425964,
0.00105972338295267,
-0.00138801498638724,
0.00145575326787426,
-0.00125147496707373,
0.000814539764067264,
-0.000227551931742202,
-0.000399254511062966,
0.000948715792411918,
-0.00131863673463246,
0.00144079498331614,
-0.00129351770880298,
0.000905513270008403,
-0.000350283090281084,
-0.000267799960007765,
0.000833110229864334,
-0.00124039763545992,
0.00141438036537664,
-0.00132365524389978,
0.000986356297289276,
-0.000466543770502085,
-0.000137959763941642,
0.000713976981069488,
-0.00115416353670673,
0.00137700978102876,
-0.00134192998075128,
0.00105664646948041,
-0.000575526707666961,
-1.07745767641816e-05,
0.000592395418192709,
-0.00106085110854094,
0.00132926661559475,
-0.00134848401888293,
0.00111605917290967,
-0.000676502256036406,
0.000112757997092214,
0.000469444396843653,
-0.000961419060732242,
0.00127181094558312,
-0.00134355645393896,
0.00116436898851638,
-0.000768823683027487,
0.000231691566392697,
0.000346192741514619,
-0.000856859048049688,
0.00120537255397545,
-0.00132747979680338,
0.00120145017807606,
-0.000851931621114070,
0.000345138540873378,
0.000223689940953746,
-0.000748186383347534,
0.00113074338864712,
-0.00130067558104340,
0.00122727625274777,
-0.000925357678036410,
0.000452277102570230,
0.000102957112056718,
-0.000636430619138664,
0.00104876951299587,
-0.00126364917510980,
0.00124191860881226,
-0.000988727139241529,
0.000552357471337524,
-1.50216532421029e-05,
-0.000522626117648580,
0.000960342655832593,
-0.00121698388270298,
0.00124554426937522,
-0.00104176077010630,
0.000644707421131218,
-0.000129307492238469,
-0.000407802691700999,
0.000866391436311578,
-0.00116133438282170,
0.00123841275855064,
-0.00108427569589365,
0.000728737000184590,
-0.000239014443364420,
-0.000292976409123360,
0.000767872359765572,
-0.00109741959071642,
0.00122087215032766,
-0.00111618537139706,
0.000803942418783560,
-0.000343316526984709,
-0.000179140641246118,
0.000665760660403769,
-0.00102601499625366,
0.00119335432359574,
-0.00113749862747795,
0.000869909057718182,
-0.000441454147073551,
-6.72574651680260e-05,
0.000561041110449280,
-0.000947944590413191,
0.00115636950711101,
-0.00114831784433366,
0.000926313604487218,
-0.000532739787741292,
4.17505307360025e-05,
0.000454698854899098,
-0.000864072433434103,
0.00111050014317413,
-0.00114883624699316,
0.000972925274682861,
-0.000616562925390159,
0.000147007926987542,
0.000347710395454734,
-0.000775293982086686,
0.00105639417158967,
-0.00113933439015138,
0.00100960614618346,
-0.000692394142759168,
0.000247693596996108,
0.000241034786729180,
-0.000682527243769892,
0.000994757785162431,
-0.00112017585746418,
0.00103631059512812,
-0.000759788399151499,
0.000343047195689907,
0.000135605141243735,
-0.000586703857975554,
0.000926347744220793,
-0.00109180223487667,
0.00105308385623016,
-0.000818387437101733,
0.000432374957296644,
3.23205238822443e-05,
-0.000488760194579383,
0.000851963335020951,
-0.00105472742115395,
0.00106005973698705,
-0.000867921319106833,
0.000515054760796427,
-6.79616933056587e-05,
-0.000389628552301354,
0.000772438048305727,
-0.00100953133001733,
0.00105745750865632,
-0.000908209075058714,
0.000590540405541599,
-0.000164432931574560,
-0.000290228560981843,
0.000688631085813660,
-0.000956853079102576,
0.00104557803962625,
-0.000939158493976822,
0.000658365090692593,
-0.000256339919972748,
-0.000191458847027888,
0.000601418756758660,
-0.000897383715876238,
0.00102479919728049,
-0.000960765048385673,
0.000718144055929873,
-0.000342990551612894,
-9.41890567922852e-05,
0.000511685865530700,
-0.000831858569065285,
0.000995570580663502,
-0.000973109979124018,
0.000769576361960528,
-0.000423759020987623,
7.47674009255649e-07,
0.000420317195142116,
-0.000761049330912880,
0.000958407671343980,
-0.000976357597983724,
0.000812445840836740,
-0.000498090236383143,
9.25617687134534e-05,
0.000328189135570331,
-0.000685755918440407,
0.000913885437301910,
-0.000970751814753698,
0.000846621182401278,
-0.000565503439863131,
0.000180513680611250,
0.000236161570699114,
-0.000606798230834139,
0.000862631490621889,
-0.000956611963646774,
0.000872055197737216,
-0.000625595037150047,
0.000263919756968448,
0.000145070076292613,
-0.000525007858523441,
0.000805318846595854,
-0.000934327950852837,
0.000888783246735074,
-0.000678040584201582,
0.000342157403409571,
5.57185475119292e-05,
-0.000441219881152038,
0.000742658419762617,
-0.000904354842050037,
0.000896920918904361,
-0.000722595988905713,
0.000414669575132826,
-3.11277436209477e-05,
-0.000356264765685995,
0.000675391266025821,
-0.000867206884637578,
0.000896660937950153,
-0.000759097858508003,
0.000480968493376045,
-0.000114748531178838,
-0.000270960510422622,
0.000604280716454429,
-0.000823451091929042,
0.000888269382632123,
-0.000787463053715871,
0.000540638604593054,
-0.000194474361357694,
-0.000186105077157140,
0.000530104457816367,
-0.000773700442352323,
0.000872081263777798,
-0.000807687456914398,
0.000593338759534745,
-0.000269691769599871,
-0.000102469185255881,
0.000453646638499354,
-0.000718606763235004,
0.000848495502057089,
-0.000819843968120180,
0.000638803590524567,
-0.000339847771195942,
-2.07895494039735e-05,
0.000375690097627492,
-0.000658853394878594,
0.000817969387934502,
-0.000824079782220827,
0.000676844100815445,
-0.000404453644711684,
5.82373843174885e-05,
0.000297008788903831,
-0.000595147712926964,
0.000781012587226665,
-0.000820612987056977,
0.000707347478436932,
-0.000463087985492271,
0.000133961156577536,
0.000218360467368454,
-0.000528213580250500,
0.000738180760681151,
-0.000809728527317579,
0.000730276146880271,
-0.000515399008691873,
0.000205782413605523,
0.000140479712834131,
-0.000458783811412582,
0.000690068865964042,
-0.000791773585159772,
0.000745666070727370,
-0.000561106085365192,
0.000273157375616782,
6.40713669361738e-05,
-0.000387592740694911,
0.000637304238923744,
-0.000767152454330754,
0.000753624369396000,
-0.000600000528349283,
0.000335601639385704,
-1.01955706686618e-05,
-0.000315368955731914,
0.000580539515951984,
-0.000736320964257945,
0.000754326271113311,
-0.000631945632916913,
0.000392693290121792,
-8.16935387030475e-05,
-0.000242828260408976,
0.000520445463551803,
-0.000699780502242398,
0.000748011430628734,
-0.000656875961432833,
0.000444075271057753,
-0.000149841416596581,
-0.000170666979939790,
0.000457703840302133,
-0.000658071762165737,
0.000734979720887916,
-0.000674795956454404,
0.000489457067889812,
-0.000214108961003483,
-9.95556012144273e-05,
0.000393000296749796,
-0.000611768217934431,
0.000715586487014560,
-0.000685777843240696,
0.000528615638155606,
-0.000274020575488659,
-3.01328725683906e-05,
0.000327017447838386,
-0.000561469457244702,
0.000690237376642782,
-0.000689958911031570,
0.000561395638877267,
-0.000329158433436391,
3.69996255855600e-05,
0.000260428149778270,
-0.000507794415362536,
0.000659382782048884,
-0.000687538188378873,
0.000587708940515261,
-0.000379164909017987,
0.000101282365426875,
0.000193889077520598,
-0.000451374610996274,
0.000623511991883925,
-0.000678772591841515,
0.000607533481476982,
-0.000423744340177517,
0.000162202208766184,
0.000128034625643256,
-0.000392847420931919,
0.000583147085087077,
-0.000663972566627468,
0.000620911454823322,
-0.000462664087741533,
0.000219296128792530,
6.34712236514219e-05,
-0.000332849491385928,
0.000538836664426311,
-0.000643497300969825,
0.000627946883712083,
-0.000495754910131432,
0.000272154304958382,
7.72106527668276e-07,
-0.000272010354057353,
0.000491149502992288,
-0.000617749582557563,
0.000628802636357016,
-0.000522910683481695,
0.000320422588247682,
-5.95274317629924e-05,
-0.000210946285219040,
0.000440668152280284,
-0.000587170337721956,
0.000623696903360808,
-0.000544087459931726,
0.000363804305826698,
-0.000116934239517115,
-0.000150254493399819,
0.000387982603373066,
-0.000552232942079756,
0.000612899209617793,
-0.000559301912489865,
0.000402061415877053,
-0.000171000951348116,
-9.05076748989731e-05,
0.000333684054065826,
-0.000513437358573535,
0.000596726005184733,
-0.000568629190172413,
0.000435015015075047,
-0.000221329039918761,
-3.22489898592615e-05,
0.000278358854007759,
-0.000471304174622651,
0.000575535899607900,
-0.000572200224853782,
0.000462545207407146,
-0.000267571261661645,
2.40124939087561e-05,
0.000222582689463424,
-0.000426368611555910,
0.000549724605391889,
-0.000570198543345074,
0.000484590367570885,
-0.000309433497982653,
7.78058703324559e-05,
0.000166915047971033,
-0.000379174552410618,
0.000519719635757651,
-0.000562856610671117,
0.000501145799394512,
-0.000346675964826455,
0.000128701919629218,
0.000111894042739982,
-0.000330268682009116,
0.000485974848713848,
-0.000550451789147975,
0.000512261851445500,
-0.000379113827209615,
0.000176316097044542,
5.80316104154263e-05,
-0.000280194767246492,
0.000448964870971188,
-0.000533301935027270,
0.000518041495684628,
-0.000406617196508756,
0.000220310939159943,
5.80915527426502e-06,
-0.000229488165889445,
0.000409179494591505,
-0.000511760720627247,
0.000518637437591681,
-0.000429110556339805,
0.000260397900582641,
-4.43263497407220e-05,
-0.000178670597273732,
0.000367118089566103,
-0.000486212725664940,
0.000514248789883496,
-0.000446571627203143,
0.000296338609758977,
-9.19657663315663e-05,
-0.000128245231457169,
0.000323284100904909,
-0.000457068361981575,
0.000505117364194213,
-0.000459029704236157,
0.000327945551907999,
-0.000136740681408659,
-7.86921329207721e-05,
0.000278179678557902,
-0.000424758686433972,
0.000491523622246400,
-0.000466563491089488,
0.000355082175246678,
-0.000178325755239739,
-3.04641198829631e-05,
0.000232300516742108,
-0.000389730181368257,
0.000473782367435070,
-0.000469298493835844,
0.000377662464049699,
-0.000216440543217957,
1.60169622465051e-05,
0.000186130922527491,
-0.000352439534402233,
0.000452238198545104,
-0.000467403988435141,
0.000395649970721416,
-0.000250850760019768,
6.03634905321185e-05,
0.000140139190548981,
-0.000313348501248095,
0.000427260816724576,
-0.000461089635880700,
0.000409056361095609,
-0.000281369016884544,
0.000102224847936856,
9.47732982388040e-05,
-0.000272918880767624,
0.000399240210603392,
-0.000450601767088031,
0.000417939478674959,
-0.000307855011936882,
0.000141289692345961,
5.04569875750264e-05,
-0.000231607683806753,
0.000368581811670834,
-0.000436219421068369,
0.000422400995612942,
-0.000330215222211920,
0.000177287738433970,
7.58623513911096e-06,
-0.000189862512413271,
0.000335701642468964,
-0.000418250160775089,
0.000422583664915979,
-0.000348402092790901,
0.000209991022350125,
-3.34738475853319e-05,
-0.000148117211647312,
0.000301021528160587,
-0.000397025730213148,
0.000418668225237926,
-0.000362412753188837,
0.000239214658568675,
-7.23916561305031e-05,
-0.000106787837021786,
0.000264964429404187,
-0.000372897621646563,
0.000410870019361637,
-0.000372287310013837,
0.000264817114244931,
-0.000108871292907130,
-6.62689480413706e-05,
0.000227949918110932,
-0.000346232570978058,
0.000399435341994498,
-0.000378106715422049,
0.000286699981523114,
-0.000142654272732914,
-2.69302939374010e-05,
0.000190389879835580,
-0.000317408077864799,
0.000384637607612263,
-0.000379990287628163,
0.000304807306201063,
-0.000173520773834363,
1.08861177975202e-05,
0.000152684448844907,
-0.000286807965735765,
0.000366773356769903,
-0.000378092901125374,
0.000319124471048734,
-0.000201290414447190,
4.68685378107449e-05,
0.000115218228395930,
-0.000254818041692141,
0.000346158161569649,
-0.000372601890885614,
0.000329676668116906,
-0.000225822563992293,
8.07375583155444e-05,
7.83568287152220e-05,
-0.000221821904253685,
0.000323122480761650,
-0.000363733721480666,
0.000336526990548596,
-0.000247016203515952,
0.000112247757234614,
4.24437540437656e-05,
-0.000188196945189192,
0.000298007521030389,
-0.000351730473773133,
0.000339774191812132,
-0.000264809365574582,
0.000141188912377077,
7.79764595656689e-06,
-0.000154310567659399,
0.000271161134387602,
-0.000336856179207288,
0.000339550132427436,
-0.000279178156638569,
0.000167386772657694,
-2.52900827146534e-05,
-0.000120516672531367,
0.000242933810446189,
-0.000319393064810153,
0.000336016967644785,
-0.000290135403063641,
0.000190703405227062,
-5.65572201793840e-05,
-8.71524305321173e-05,
0.000213674800597969,
-0.000299637744974060,
0.000329364111972449,
-0.000297728945661717,
0.000211037122960751,
-8.57723273161247e-05,
-5.45353733109249e-05,
0.000183728410933103,
-0.000277897408945772,
0.000319805024856528,
-0.000302039611319325,
0.000228322015780829,
-0.000112735897263987,
-2.29608209385437e-05,
0.000153430506030549,
-0.000254486049228494,
0.000307573862686030,
-0.000303178905912279,
0.000242527100213937,
-0.000137281117111114,
7.30033523579021e-06,
0.000123105249949880,
-0.000229720770505216,
0.000292922038724463,
-0.000301286459640106,
0.000253655117779784,
-0.000159274229215575,
3.60034845920927e-05,
9.30621167690355e-05,
-0.000203918222030338,
0.000276114740327413,
-0.000296527270429427,
0.000261741011042686,
-0.000178614516206882,
6.29317835053456e-05,
6.35931853423578e-05,
-0.000177391176527107,
0.000257427429370752,
-0.000289088772606025,
0.000266850094912291,
-0.000195233905942410,
8.78972584955165e-05,
3.49707508874002e-05,
-0.000150445309823505,
0.000237142384856679,
-0.000279177783598086,
0.000269075971428415,
-0.000209096229889560,
0.000110741537327149,
7.44526608530055e-06,
-0.000123376200135580,
0.000215545326216810,
-0.000267017374832038,
0.000268538224122432,
-0.000220196166615947,
0.000131336227696372,
-1.87563955743337e-05,
-9.64665624043059e-05,
0.000192922131808071,
-0.000252843685497536,
0.000265379913813642,
-0.000228557874872624,
0.000149582935323636,
-4.34323301785881e-05,
-6.99837507791663e-05,
0.000169555701416514,
-0.000236902727086258,
0.000259764914425040,
-0.000234233348698301,
0.000165412932789527,
-6.64066381031749e-05,
-4.41775582148218e-05,
0.000145723008065119,
-0.000219447235191615,
0.000251875150700741,
-0.000237300550497779,
0.000178786528283539,
-8.75301399492884e-05,
-1.92782936186099e-05,
0.000121692324639181,
-0.000200733565328068,
0.000241907733045669,
-0.000237861309107664,
0.000189692110701649,
-0.000106680732130426,
4.50481013032483e-06,
9.77207024091708e-05,
-0.000181018711655215,
0.000230072074234532,
-0.000236039069272536,
0.000198144940810403,
-0.000123763442717051,
2.69848983345917e-05,
7.40516688244340e-05,
-0.000160557434864838,
0.000216586977792589,
-0.000231976475561013,
0.000204185674783137,
-0.000138710154973346,
4.79984606869687e-05,
5.09132049997089e-05,
-0.000139599566916384,
0.000201677774145669,
-0.000225832869939003,
0.000207878683238877,
-0.000151479056895540,
6.74060053942129e-05,
2.85159790346672e-05,
-0.000118387481783846,
0.000185573498558612,
-0.000217781700629465,
0.000209310165667662,
-0.000162053801388181,
8.50924152924897e-05,
7.05186956453470e-06,
-9.71537792265648e-05,
0.000168504168072874,
-0.000208007895912176,
0.000208586105310435,
-0.000170442417095546,
0.000100967004728756,
-1.33072212552245e-05,
-7.61191957458708e-05,
0.000150698183918165,
-0.000196705240633591,
0.000205830105356773,
-0.000176676000024605,
0.000114963305824497,
-3.24102791839204e-05,
-5.54907418569306e-05,
0.000132379865371671,
-0.000184073766363031,
0.000201181115979662,
-0.000180807193536547,
0.000127038575228745,
-5.01277953367820e-05,
-3.54600972052203e-05,
0.000113767161034625,
-0.000170317206171403,
0.000194791104551260,
-0.000182908504338874,
0.000137173062053058,
-6.63521154583115e-05,
-1.62022492551869e-05,
9.50695339833217e-05,
-0.000155640518881772,
0.000186822677670859,
-0.000183070457050786,
0.000145369031533720,
-8.09975051500945e-05,
2.12559048589932e-06,
7.64860654053013e-05,
-0.000140247538908800,
0.000177446714536424,
-0.000181399650296004,
0.000151649599016530,
-9.39999736435878e-05,
1.93848288223896e-05,
5.82037575782806e-05,
-0.000124338739968729,
0.000166840006490354,
-0.000178016706090723,
0.000156057365543311,
-0.000105316838685233,
3.54560566637589e-05,
4.03960768917472e-05,
-0.000108109166276448,
0.000155182962654831,
-0.000173054175672365,
0.000158652908641844,
-0.000114926079134319,
5.02393771313967e-05,
2.32217195289552e-05,
-9.17465217580026e-05,
0.000142657380597930,
-0.000166654405394924,
0.000159513134913013,
-0.000122825474135530,
6.36544847717181e-05,
6.82361260221398e-06,
-7.54294443736157e-05,
0.000129444315385494,
-0.000158967394375891,
0.000158729522599144,
-0.000129031549353854,
7.56405031096346e-05,
-8.67183733331277e-06,
-5.93259871475699e-05,
0.000115722081146003,
-0.000150148690895136,
0.000156406301163626,
-0.000133578377322378,
8.61556239564951e-05,
-2.31552845431723e-05,
-4.35922803312279e-05,
0.000101664365247479,
-0.000140357307314415,
0.000152658551633607,
-0.000136516206059851,
9.51765124188815e-05,
-3.65347254584677e-05,
-2.83714352266867e-05,
8.74385286051978e-05,
-0.000129753738476453,
0.000147610311414145,
-0.000137910006150880,
0.000102697559609732,
-4.87355955071818e-05,
-1.37926245695630e-05,
7.32040363770285e-05,
-0.000118498031457477,
0.000141392641188929,
-0.000137837883078596,
0.000108729931404002,
-5.97006177255799e-05,
2.95846827881819e-08,
5.91111032202778e-05,
-0.000106748004651542,
0.000134141749064100,
-0.000136389460224527,
0.000113300506204820,
-6.93894923277792e-05,
1.29957272178115e-05,
4.52994876363378e-05,
-9.46575540414564e-05,
0.000125997125227105,
-0.000133664181277609,
0.000116450656817408,
-7.77783755578806e-05,
2.50217037892235e-05,
3.18974960068090e-05,
-8.23751187460442e-05,
0.000117099753299065,
-0.000129769601548325,
0.000118234933763554,
-8.48591948961380e-05,
3.60388494941422e-05,
1.90211827901564e-05,
-7.00423007388360e-05,
0.000107590413116842,
-0.000124819687744192,
0.000118719677768838,
-9.06388284136985e-05,
4.59938262807270e-05,
6.77372748869314e-06,
-5.77926338854438e-05,
9.76080699072671e-05,
-0.000118933129140552,
0.000117981563868806,
-9.51381479763870e-05,
5.48483402868338e-05,
-4.75500178988882e-06,
-4.57505109770968e-05,
8.72883675851576e-05,
-0.000112231675123534,
0.000116106089321701,
-9.83909332885501e-05,
6.25786747835931e-05,
-1.54886815154860e-05,
-3.40303032480609e-05,
7.67622694617877e-05,
-0.000104838553179924,
0.000113186063714312,
-0.000100442712686734,
6.91750948342575e-05,
-2.53646062913600e-05,
-2.27356340152867e-05,
6.61548177336021e-05,
-9.68769464433398e-05,
0.000109320085550577,
-0.000101349518894484,
7.46411071782343e-05,
-3.43335844271261e-05,
-1.19588346592544e-05,
5.55840476099060e-05,
-8.84685705272249e-05,
0.000104611048898905,
-0.000101176601847389,
7.89926162502628e-05,
-4.23596903087532e-05,
-1.78055484407792e-06,
4.51600345946115e-05,
-7.97323373243405e-05,
9.91646702789666e-05,
-9.99970894123996e-05,
8.22569630858602e-05,
-4.94198535533731e-05,
7.73044783014208e-06,
3.49841095865886e-05,
-7.07831454761339e-05,
9.30880819402389e-05,
-9.78906453573534e-05,
8.44718937672007e-05,
-5.55033255994904e-05,
1.65173663256915e-05,
2.51482237433532e-05,
-6.17307903966461e-05,
8.64884924197881e-05,
-9.49421291897842e-05,
8.56844670951370e-05,
-6.06110354372092e-05,
2.45352627654101e-05,
1.57344547334473e-05,
-5.26789906302710e-05,
7.94719141941528e-05,
-9.12402599175422e-05,
8.59498994336594e-05,
-6.47548241883523e-05,
3.17508302046613e-05,
6.81468147959116e-06,
-4.37245646773611e-05,
7.21420003100827e-05,
-8.68763318239560e-05,
8.53303968378907e-05,
-6.79566093148694e-05,
3.81420395083240e-05,
-1.54960784393911e-06,
-3.49567335027389e-05,
6.45989734913665e-05,
-8.19429696885905e-05,
8.38939685342046e-05,
-7.02474737089914e-05,
4.36976700550079e-05,
-9.30737030014720e-06,
-2.64565565390446e-05,
5.69386604445289e-05,
-7.65329416302733e-05,
8.17132365458137e-05,
-7.16666904680223e-05,
4.84167260159093e-05,
-1.64179195193185e-05,
-1.82965146307303e-05,
4.92516511006942e-05,
-7.07380548955613e-05,
7.88642753829743e-05,
-7.22607213605023e-05,
5.23077773574168e-05,
-2.28507279641721e-05,
-1.05402127869497e-05,
4.16225651072354e-05,
-6.46481232575567e-05,
7.54254718691516e-05,
-7.20821792034151e-05,
5.53882142108408e-05,
-2.85851072733613e-05,
-3.24221991439569e-06,
3.41294451881241e-05,
-5.83500305492881e-05,
7.14764344047816e-05,
-7.11887845402872e-05,
5.76834426668659e-05,
-3.36097889932510e-05,
3.55197069788484e-06,
2.68432705002762e-05,
-5.19268901082108e-05,
6.70969555046596e-05,
-6.96423242940776e-05,
5.92260297735991e-05,
-3.79224107325946e-05,
9.80585939986252e-06,
1.98275973779508e-05,
-4.54573155161122e-05,
6.23660525079285e-05,
-6.75076418589765e-05,
6.00548319901233e-05,
-4.15289437831710e-05,
1.54917710787129e-05,
1.31382944524579e-05,
-3.90147728293356e-05,
5.73610566606221e-05,
-6.48516314344463e-05,
6.02140778167643e-05,
-4.44430304989604e-05,
2.05905650447362e-05,
6.82341282385755e-06,
-3.26670589779793e-05,
5.21568005987864e-05,
-6.17422867908078e-05,
5.97524547790278e-05,
-4.66852764763862e-05,
2.50912610969713e-05,
9.23160502731698e-07,
-2.64758863732271e-05,
4.68248935945603e-05,
-5.82478042189226e-05,
5.87222070084887e-05,
-4.82825093384025e-05,
2.89905936458929e-05,
-4.53002646962241e-06,
-2.04965696755587e-05,
4.14330852462044e-05,
-5.44357437174647e-05,
5.71782504808843e-05,
-4.92670122653822e-05,
3.22925049826769e-05,
-9.51132865537019e-06,
-1.47778028906065e-05,
3.60447080699851e-05,
-5.03722408607885e-05,
5.51773003208649e-05,
-4.96757259197749e-05,
3.50075662195750e-05,
-1.40032863881818e-05,
-9.36155133474686e-06,
3.07182279102158e-05,
-4.61213025226825e-05,
5.27770432545914e-05,
-4.95494513761928e-05,
3.71523564677863e-05,
-1.79954670322576e-05,
-4.28303862522960e-06,
2.55068928494401e-05,
-4.17441865985924e-05,
5.00353667550297e-05,
-4.89320728625287e-05,
3.87488235476092e-05,
-2.14840808670344e-05,
4.29193943820314e-07,
2.04584580969955e-05,
-3.72988447269434e-05,
4.70096230007786e-05,
-4.78697791998594e-05,
3.98236057035167e-05,
-2.44715266846507e-05,
4.75313751237594e-06,
1.56150074875582e-05,
-3.28394518581882e-05,
4.37559560586719e-05,
-4.64103133361077e-05,
4.04073408753056e-05,
-2.69658852855969e-05,
8.67308334245886e-06,
1.10128731101717e-05,
-2.84160325289578e-05,
4.03287079018627e-05,
-4.46022717899888e-05,
4.05339917886075e-05,
-2.89803964272556e-05,
1.21793484050168e-05,
6.68261101925047e-06,
-2.40741434418611e-05,
3.67798674704759e-05,
-4.24944218360976e-05,
4.02401563530905e-05,
-3.05328879751869e-05,
1.52679255814066e-05,
2.64906892578061e-06,
-1.98546500069739e-05,
3.31586003724534e-05,
-4.01350730764233e-05,
3.95643976090557e-05,
-3.16451866320707e-05,
1.79400817749700e-05,
-1.06847019347601e-06,
-1.57935892057936e-05,
2.95108600554460e-05,
-3.75715125639281e-05,
3.85466101129540e-05,
-3.23425344797131e-05,
2.02019327946803e-05,
-4.45609890257817e-06,
-1.19220894766209e-05,
2.58790554584687e-05,
-3.48494828768016e-05,
3.72274052793807e-05,
-3.26529946747502e-05,
2.20639775630144e-05,
-7.50503210654737e-06,
-8.26636711758603e-06,
2.23017934457658e-05,
-3.20127206009306e-05,
3.56475328440866e-05,
-3.26068631902281e-05,
2.35406085444957e-05,
-1.02113047743536e-05,
-4.84778781083232e-06,
1.88136910518458e-05,
-2.91025561506954e-05,
3.38473435685448e-05,
-3.22360940887413e-05,
2.46496043386581e-05,
-1.25754232045394e-05,
-1.68299577898747e-06,
1.54452654393360e-05,
-2.61575893232091e-05,
3.18663145824847e-05,
-3.15737659182695e-05,
2.54116387705280e-05,
-1.46020097336118e-05,
1.21593376076612e-06,
1.22228540450536e-05,
-2.32133905948690e-05,
2.97425852017874e-05,
-3.06535352341131e-05,
2.58497493827160e-05,
-1.62993795776686e-05,
3.84125227748637e-06,
9.16863744021602e-06,
-2.03023065692612e-05,
2.75125868145283e-05,
-2.95091642466831e-05,
2.59888539674946e-05,
-1.76791380620272e-05,
6.18929154249461e-06,
6.30068374802497e-06,
-1.74532946041181e-05,
2.52106988923676e-05,
-2.81740622439520e-05,
2.58552619692626e-05,
-1.87557516364141e-05,
8.26017199065317e-06,
3.63305085334796e-06,
-1.46918190969495e-05,
2.28689607360518e-05,
-2.66808678004884e-05,
2.54762054152313e-05,
-1.95461139975496e-05,
1.00574832730159e-05,
1.17593443289160e-06,
-1.20398028974600e-05,
2.05168375221023e-05,
-2.50610745666737e-05,
2.48793945371205e-05,
-2.00691137200834e-05,
1.15879423934172e-05,
-1.06414156847778e-06,
-9.51563485898980e-06,
1.81810475931188e-05,
-2.33447144069641e-05,
2.40926193930910e-05,
-2.03452312763585e-05,
1.28610633619747e-05,
-3.08413000396668e-06,
-7.13419175493583e-06,
1.58854062780980e-05,
-2.15600508674769e-05,
2.31433477794885e-05,
-2.03961132127523e-05,
1.38887825085080e-05,
-4.88420149585254e-06,
-4.90693973616174e-06,
1.36507573899247e-05,
-1.97333598521286e-05,
2.20584019716092e-05,
-2.02442100782731e-05,
1.46851289725802e-05,
-6.46751145286717e-06,
-2.84202588361863e-06,
1.14949056725800e-05,
-1.78887153437735e-05,
2.08636372278522e-05,
-1.99124066292791e-05,
1.52658735505728e-05,
-7.83992995227965e-06,
-9.44420822187621e-07,
9.43260982898625e-06,
-1.60478387704375e-05,
1.95836797695954e-05,
-1.94237007097493e-05,
1.56482103841807e-05,
-9.00978623649399e-06,
7.83935171525027e-07,
7.47559434188931e-06,
-1.42299775536068e-05,
1.82416981707318e-05,
-1.88009128682218e-05,
1.58504607159106e-05,
-9.98762184626575e-06,
2.34397923979176e-06,
5.63258285698431e-06,
-1.24518164027521e-05,
1.68592128359527e-05,
-1.80664326865193e-05,
1.58918048894794e-05,
-1.07859578789703e-05,
3.73936902154455e-06,
3.90935492255855e-06,
-1.07274297870248e-05,
1.54559601577405e-05,
-1.72420263899694e-05,
1.57920740103668e-05,
-1.14191116148137e-05,
4.97635752757253e-06,
2.30879343896842e-06,
-9.06824899987317e-06,
1.40497925507715e-05,
-1.63486953125997e-05,
1.55715983257221e-05,
-1.19030650926603e-05,
6.06370470402950e-06,
8.30918840263758e-07,
-7.48304360703323e-06,
1.26566195715797e-05,
-1.54065957222224e-05,
1.52511255347221e-05,
-1.22553973042141e-05,
7.01263066199327e-06,
-5.27082777352689e-07,
-5.97794100561358e-06,
1.12904325578539e-05,
-1.44350800553639e-05,
1.48518830033058e-05,
-1.24953609862035e-05,
7.83688974868656e-06,
-1.77090615013304e-06,
-4.55643346870285e-06,
9.96338395092646e-06,
-1.34528523657699e-05,
1.43957928743317e-05,
-1.26441201123289e-05,
8.55297713240174e-06,
-2.90924368516500e-06,
-3.21940168225997e-06,
8.68597881265877e-06,
-1.24783204737776e-05,
1.39059369573861e-05,
-1.27252423867432e-05,
9.18053946157448e-06,
-3.95400162400142e-06,
-1.96518267115819e-06,
7.46746833689904e-06,
-1.15302896023228e-05,
1.34074519140775e-05,
-1.27656335795821e-05,
9.74314819775609e-06,
-4.92071364573165e-06,
-7.89667830093251e-07,
6.31652156619124e-06,
-1.06291506895824e-05,
1.29290502220271e-05,
-1.27971007825138e-05,
1.02695560607792e-05,
-5.82915212092074e-06,
3.13414308251919e-07,
5.24248964105051e-06,
-9.79900452764784e-06,
1.25056655617670e-05,
-1.28590029701837e-05,
1.07957464296650e-05,
-6.70420248231589e-06,
1.35179297681228e-06,
4.25780302111296e-06,
-9.07149451284387e-06,
1.21830882765184e-05,
-1.30027582486976e-05,
1.13682439504335e-05,
-7.57699294323568e-06,
2.33294728637344e-06,
3.38263268891172e-06,
-8.49286708977784e-06,
1.20262029291099e-05,
-1.32995252750538e-05,
1.20493020612022e-05,
-8.48586098462860e-06,
3.25978434029312e-06,
2.65452191613282e-06,
-8.13766917263592e-06,
1.21342735686686e-05,
-1.38536956203430e-05,
1.29249345064615e-05,
-9.47578755905232e-06,
4.11974512253393e-06,
2.14919930540155e-06,
-8.13654050316106e-06,
1.26703746372138e-05,
-1.48269616572805e-05,
1.41162808512093e-05,
-1.05911145259137e-05,
4.85614683002586e-06,
2.02861897580210e-06,
-8.73619719903648e-06,
1.39208631902521e-05,
-1.64816070082674e-05,
1.57909355674412e-05,
-1.18430416023770e-05,
5.28808185753392e-06,
2.66094124771436e-06,
-1.04386263683022e-05,
1.64215975327003e-05,
-1.92549125409221e-05,
1.81482847160588e-05,
-1.30808136873314e-05,
4.86560151127938e-06,
4.95120163609831e-06,
-1.43520955794852e-05,
2.12334518816518e-05,
-2.38484307014892e-05,
2.12227652221487e-05,
-1.34538992145464e-05,
1.81620815985303e-06,
1.13759543984696e-05,
-2.31531129861752e-05,
3.04792287756776e-05,
-3.09507101925077e-05,
2.34736968392414e-05,
-8.76736432618021e-06,
-1.04535730643650e-05,
2.97298720115906e-05,
-4.35934020642341e-05,
4.67552223855731e-05,
-3.56182455059900e-05,
9.88930618457279e-06,
2.60263717555172e-05,
-6.22569633814163e-05,
8.38585089834099e-05,
-7.31798787850616e-05,
1.56918903602002e-05,
8.74751988628250e-05,
-0.000192683277298794,
0.000154400644547547,
0.000410523562181980,
0.000128991905841930};
@DD4wh: What is this for? :)
You have used PROGMEM for several simple variables and even consts - I wouldn't do that.
This moves 4 Bytes from the fast RAM1 to the slower RAM2. They may be cached.. but ... if you use the EXTMEM (uses the same small 32kB cache) extensively the chance is not very high.
Overall it might be not a big difference in the code above, but It's a good Idea o keep such things in mind for other projects.
Edit: This comment was wrong... :)
Has anyone tested DMA-based ILI9341 or ILI9488 or similar displays with this last beta?
I'm going to test lots of libs here today. My hope is to finalize 1.52 soon, maybe even later today if everything is looking good.
Tried it @KurtE's ILI9341_t3n lib and the ILI9488 lib by setting the framebuffer to use - DMAMEM uint16_t tft_frame_buffer[ILI9488_TFTWIDTH * ILI9488_TFTHEIGHT];
Seems to working with no issues with and doing some heavy graphics stuff.
I have my ILI9488_t3 library hacked to run with display in EXTMEM and so far so good.
I have not tried ILI9341 yet with this beta. T4.1? or others as well?
Hm, now that I see the usage of PROGMEM above I wonder if there is any alignment... it should be minimum 4, but I don't see anything obvious in the files.
We should verify this.
If not, it would be a high-priority issue that needs a fix asap.
@FrankB:
* the sketch is for guitar cabinet emulation: combines applying large impulse responses to audio together with minimizing latency. (and it consumes a lot of processor power and a lot of memory, so is ideal for showing T4.1 its limits ;-)). For test purposes I did not use a real impulse response, but a minimum phase FIR lowpass filter with a cutoff at 19kHz, so actually a passthru . . . just to judge acoustically whether the file processing is correct :)
* Maybe using PROGMEM here seems wrong for such small variable sizes . . . my intention was to absolutely minimize use of RAM1, because I need that RAM1 space for a very large array of float32_t
* I thought PROGMEM would be exactly the same as "const"!?
Win10, T4.0 with ADC PCM1808 and DAC PCM5102a and Ili9341_t3n (@70MHz) runs well with TD 1.52 beta6. Same setup also plays mp3 from SD card (flying wires soldered to a µSD-card adapter) with FrankBs codec lib [Teensy Convolution SDR].
