Here is a fourth beta test for Teensyduino 1.59.
Arduino 2.0.x, all systems platforms:
use Boards Manager to install Teensy version 0.59.4
(to refresh versions, Shift-Ctrl-P and click "Arduino: Update Package Index")
Arduino 1.8.x, Linux 32 bit:
Arduino 1.8.x, Linux 64 bit:
Arduino 1.8.x, Linux ARM:
Arduino 1.8.x, Linux ARM64:
Arduino 1.8.x, MacOS (Catalina to Ventura)
Arduino 1.8.x, Old MacOS (Mojave)
Arduino 1.8.x, Windows:
PlatformIO, DIY beta support:
Changes since Teensyduino 1.59-beta3:
Publish Arduino IDE 2.x.x packages using zstd compression
SD/SdFat Workaround for old version 1 cards with SDIO on Teensy 4.1
SD/SdFat Handle cards which falsely claim high speed support (tompilot)
FlexIO_t4 add setClock(), setClockUsingAudioPLL(), setClockUsingVideoPLL()
FlexIO_t4 fix minor issues and update examples
HardwareSerial base class
SoftwareSerial fix for MicroMod (KurtE)
SPI fix constinit for Teensy 3.x
Don't allow writing to ITCM after startup on Teensy 4.x
Update Stream parseInt and parseFloat for LookaheadMode
USB MIDI add realtime send functions (same API as MIDI library)
Add alternate names for FlexIO register bit fields
Fix Serial2 on MicroMod (KurtE)
Fix vprintf on Teensy 2.0
Fix pulldown on half duplex serial (KurtE)
Use namespace "teensy" for inplace_function
IPAddress compare operators are const (ssilverman)
ILI9431 fix DemoSauce example
ILI9488_t3 for clearChangedRange() on Teensy 3.2 (mjs513)
LittleFS fix wrote info in example (karelv)
USBHost_t36 fix race condition in MIDI read()
USBHost_t36 fix sustained fast MIDI receive
USBHost_t36 improve USBDriverTimer to fix fast transmit to 3+ USB devices
USBHost_t36 fix USBHIDDumper example (KurtE)
USBHost_t36 fix typos and spelling mistakes in comments (KurtE)
USBHost_t36 update virtual function defs (pr8x)
Show warning if IDE 2.x.x package used on IDE 1.8.x
